Jul 14, 2019, 05:58 AM
'n boer maak 'n plan
yufasa's Avatar
FAQ
Graupner MZ-32 and MZ-16 Tips and Tutorials
Please, Please, Please do NOT post questions here but rather ask them in our Questions thread.
In this thread we will capture Tips, Tricks and Tutorials that will help you get the most out of your radio.
To start with go to the Graupner channel and watch some really nice videos for these radio’s:
https://www.youtube.com/channel/UCji...nSR5MIg/videos
Then go to my channel and get some insight into some commonly asked questions:
https://www.youtube.com/user/yufasa1..._as=subscriber
I am constantly working on new videos so keep an eye out for more.
Jul 14, 2019, 07:10 AM
yufasa's Avatar
Working on menu flow diagram and will update as I go:
Jul 14, 2019, 10:26 AM
yufasa's Avatar
So how do you set up a Delta Wing on this radio?
Not very obvious if you ask me but here we go:
Create a new model or change an existing model.
Go to Model Types in the base menu
Click on wing type
In left bottom you will see something that is supposed to represent a delta wing. See picture.
When you click on that you get the delta wing options.
Select your setup.
Make sure “ no tail” is set for tail type
Jul 21, 2019, 08:06 AM
yufasa's Avatar
If you have problems with radio lockup or just want a faster startup you want to look into upgrading the card in your radio to something somewhat faster.
Here is a quick video showing how to do it in a MZ-32
Replacing SD Card in MZ-32/MZ-16 (9 min 20 sec)
Jul 23, 2019, 03:16 PM
yufasa's Avatar
Setting up a new model on your MZ-16 or MZ-32?
See my document with some things you may have not tried to do yet and feel free to comment so I can expand it;
https://docs.google.com/document/d/1...it?usp=sharing
Jul 23, 2019, 03:26 PM
grcoop's Avatar
Thank you for taking time in doing this yufasa! Greatly appreciated!
Jul 23, 2019, 10:34 PM
Great stuff!
Please add the importance of having all receiver firmware updated and current especially when setting up a model with multiple receivers.
Version differences can lead to surprise....
Aug 13, 2019, 07:04 AM
FinnK
Understanding log files
Is there a document or "place" explaining the various data received via telemetry for RX ?
There are columns for Receiver named "RF RXSQ" - "Quality" - "Strength" - "LossPack". What are this datatypes representing - and what are good and bad values? What are the signs to look out for?
If I get the warning «Telemetry link inactive» during flight from my MZ-16 - is it correct that I still should have a good RC signal range because the telemetry signal from RX is transmitted with less power than the signal from the RC-transmitter?
Aug 13, 2019, 11:52 AM
LossPack is your number one data point to look for before diving into other areas.
When you start your radio most of the time your losspack is between 10-20ms.
2000ms indicates a total loss of radio signal.
Depending on flight conditions and RX antenna layout you can expect a losspack of anywhere between 20 to 200ms which is just fine. You can try to reduce that number by experimenting with antenna layouts and position.
Aug 14, 2019, 01:48 PM
k2k
k2k
k2k's Avatar
Is that 20-200 ms packloss figure based on some time frame? Like a 10 minute flight.
I am also interested to know if there is any documentation that exists regarding interpretation of data logs.
Aug 14, 2019, 07:00 PM
Time is not relevant in this case as packet loss will constantly change. You can start with 10ms, peak at 100ms and end the flight with 30ms.
You can find additional information in some of our manuals. The mz-24 PRO manual has more information on page 101.
https://s3.amazonaws.com/graupner.ma...1.2+Manual.pdf
There is quite a large set of data being recorded which we use exclusively for support purposes only.
Aug 15, 2019, 05:14 AM
yufasa's Avatar
Setting up a model from scratch on a Graupner MZ-32/MZ-16 (1 hr 9 min 32 sec)
Mar 30, 2020, 07:50 AM
reyaza's Avatar
Charging MZ-32
Hi Yufasa,
Can I charge my MZ-32 with a I-phone charger , specs 5v 2Amps ?
Or do I need to use another charger ?
Regards,
Reyaz
Mar 30, 2020, 11:32 AM
yufasa's Avatar
Absolutely, I use a 5V 2.4A one all the time.
Apr 10, 2020, 08:10 AM
What happened with the move, essentially all information is gone? !!!
News Graupner - MZ-16 16-CHANNEL 2.4 GHZ TELEMETRY RADIO Jim T. Graham Radios 78 Apr 06, 2021 08:13 PM
New Product Graupner mz-16 - 16-channel radio Graupner – Control Hobbies Radios 2 Jan 30, 2019 05:37 PM
Review Graupner mz-32 - 32 Channel HoTT Telemetry Radio - RCGroups Review Nikolei Zinsli Radios 7 Dec 10, 2018 03:21 AM
New Product Graupner mz-32 transmitter utorrent Radios 12 Feb 19, 2016 02:41 PM
New Product Graupner mz-32 brathering Radios 1 Aug 11, 2015 11:54 AM
