Jul 23, 2019, 08:42 AM
Originally Posted by maple_antenna
The attachment is a DWG format pcb layout, which is easy to implement using 1mm FR4 common material.
The antenna working frequency is 5180-5400MHz, I wish you good luck.
Anywhere to buy this nice antennas ?
Jul 23, 2019, 06:28 PM
In the days to come, you can find it at banggood. But not yet in the time, we just finished testing and need to continue to improve it.
If you are more urgent, try making it with cad data and we have posted it upstairs.
Thank you for your support!
Jul 28, 2019, 12:50 PM
Thank you very much for the pictures, could you please make a picture with antenna wire attached?
Best regards, Norbert
Jul 30, 2019, 03:12 AM
Different antenna combinations have different effects, the nominal distances are conservative, they usually perform better
Jul 30, 2019, 03:14 AM
After our long-term testing, EZ-wifibroadcast HD images performed well
Later we will try open HD
Jul 30, 2019, 07:38 AM
PetruSoroaga's Avatar
Can you please tell us what network cards and data rates you used to get 5km on 5dbm omnididirectional dipoles on TX/RX? I get like 3km on datarate 1 and 2km on datarate 2 & 3. So I'm really curious how you achieve 5km without any kind of TX booster or RX LNA.
Jul 30, 2019, 02:44 PM
Can I build your 20db RX antenna too ? Or it`s secret ?
Nice tests you have !
Jul 31, 2019, 08:11 AM
Sorry, we didn't notice the change in bit rate, only concerned about the fluency of HD. The flight is smooth within 5km and the video is smooth. When it reaches 8km, it won't work.
The real test results are very surprising. When we first used the AC56 Network card, it was very unexpected for its 500mw transmit power and -93dBm receive sensitivity.
Jul 31, 2019, 08:22 AM
After completing the flight, we calculated the signal attenuation link, which is theoretically correct. We are used to using this empirical formula to calculate wireless signal attenuation.
33+20log(5km)+20log(5180MHZ) ≈121dBm
TX power 500mw =27dBm TX Antenna Gain 5dB RX Antenna Gain 5dB
121-27-5-5 = 84dBm
Network card receiving sensitivity -94dBm
The above calculation results show that there is no problem in achieving 5km communication distance, and the actual test also proves its correctness.
Jul 31, 2019, 08:30 AM
Sorry, you can build a 5dB transmit antenna. It is very difficult to build a 20dB receive antenna. It is a large antenna array and cannot be easily manufactured.
Jul 31, 2019, 10:40 AM
Thanks anyway !!!!
Jul 31, 2019, 10:41 AM
121-27-5-5 = 84dBm
So you are using an Asus AC56 as a transmit card with Ez-wifibroadcast 1.6RC6?
Jul 31, 2019, 07:26 PM
Yes, we tested a lot of different network cards, their distance performance is very different, and finally chose ac56 performance is very stable
Note: Do not remove the NIC case, it will affect the sensitivity! ! !
Aug 01, 2019, 09:28 AM
@maple_antenna
For TX antenna, it has to be a 1mm pcb, or it's OK to build it with 1.6 mm too?
Thanks.
Aug 01, 2019, 09:31 AM
the drawings are done
Discussion Open.HD DIY 135ms Latency DIY DIGITAL HD FPV Discussion Htcohio FPV Equipment 2671 Feb 17, 2024 03:51 AM
Download EZ-WifiBroadcast, cheap digital HD transmission made easy! Rodizio FPV Equipment 7810 Oct 03, 2023 05:20 PM
Discussion EZ-Wifibroadcast RTL8812/RTL8814 support thread DaddyK00l FPV Equipment 152 Feb 27, 2021 01:57 PM
Discussion Fat Shark BASE HD Beta Test Thread/Discussion skinnyshark FPV Equipment 139 Jun 23, 2019 10:50 PM
Discussion A history of HD FPV, list of Wifibroadcast forks and other systems DaddyK00l FPV Equipment 0 Nov 24, 2018 10:07 AM
