Jul 12, 2019, 12:27 PM
Garland
Ghia's Avatar
I want a nano rx, Spartan flybarless heli gyro, and a tattle tell to all talk togethe
I'm at lunch break so quick post.
I have a XPS module A9 and I'm sure I can get nano to ppm talk into the gyro. Ok.
I want to failsafe the signal on nano channel 6 off for the tatlell to flash green if ever signal loss . can I do these things?
Manual talks of 2 extreme modes for nano rx What are they? They sound much better then the ppm mode!
Jul 12, 2019, 04:23 PM
You can program the Nano's channel mapping, failsafe, etc. using our XDP (or our SerialLink with another Nano emulating the XDP).
Xtreme mode is our custom serial protocol. It provides all of the channels in a serial datastream like SBUS, but 2.5 times faster.
Jul 13, 2019, 09:00 PM
Garland
Ghia's Avatar
Can I have ppm into the heli gyro and a servo channel free pwm for the tatletell?
So when I see extreme mode speak un the manuals it is meant to be paired with a x10 ? I wonder if I need a x10 on my heli also
Jul 14, 2019, 01:14 AM
Yes, the Xtreme mode is output by our receivers (Nano and RFU). The X10+ and X24 both understand Xtreme mode.
With the Nano you can output normal PWM channels, PPM mode, Xtreme mode, or Mixed mode. Mixed mode is Xtreme mode output on output port 6 and normal PWM output on output ports 1 through 5. There is no option to output PPM and PWM or Xtreme together. It takes every bit of CPU time to output the PPM mode.
Does your Gyro except SBUS, Spektrum, etc? If so, then our RFU could be used to output one of those protocols into the gyro. The X10+ could then be used (via Y-cable) for any other servo outputs that you might need. If the gyro handles ALL of the channels (some do), the you would just need a RFU and that's it. That is the most common setup for Heli guys using our radio system.
Jul 15, 2019, 05:42 AM
Garland
Ghia's Avatar
Thanks JD!
I went ahead and installed a RFU in this nitro heli My FBL spartan gyro can take sbus and all servos go into the FBL gyro. I just always thought the rfu was over kill in a heli due to its long range antenna.
Discussion With all the talk and all I`m surprised this didn`t make the forum until now. DLGjunkyard Life, The Universe, and Politics 45 Jun 26, 2016 09:05 AM
Discussion talk about three flybarless gyros i have used yelong98 Electric Heli Talk 3 Aug 30, 2014 06:05 AM
Question Talk about any New Flybarless Heli on the Market ! All Welcome. rolex0071 Coaxial Helicopters 36 Apr 14, 2011 05:10 PM
Discussion FLYIN BRICK is a tattle tell sissy la la.... parkzonekid Pusher Prop Jet Models 2 Dec 29, 2005 03:13 AM
