This thread is privately moderated by mdavies, who may elect to delete unwanted replies.
Jul 11, 2019, 06:46 PM
Trader Rating: 44
Michael
$60.00 USD
Buyer pays shipping
For Sale
GWS F-15 with 2 ducted fans 1/2 built
Part 1. I ordered this for myself, it arrived and my brain went into hyperdrive. Videos, blogs, and lots of research led me to conclude.
-foam doesn't fly as well as it could.
-apply 6 coats of Polyacrylic lightly sanded between coats (Scotch Brite Pad works), tacked between coats. Wet sand the final coat and spot fill and prep for the final paint work. Weight then decide on paint...liquidex or krylon fusion...Let cure then apply decals and a coat of Beacons Hobby Coat....
Right now, the foam is untreated and all the components fit together. If you want a project here it is !
I bought this off ebay and paid $59.00 for kit and shipping together.
-i glued the wing parts and carbon rods in place
-I set up the twin rudders...drilled and screwed in
-I set it up for the full flying stab,,,and it works
-I cut the ailerons and blue taped them on..no bevels
Twin Ducted Fan units are new and the ones that were set in the kit. I was opting for the "pusher configuration" and ordered a
HobbyStar C2808-1700KV brushless motor,,I am reversing the shaft.
-I have a 28mm motor mount from GWS for the pusher set up
-I have all the hardware ..mounts and other for the C2808 brushless.
-I have several 7.5 APC props
-I have a 30amp esc
-I paid $3.00 for a premade pilot bust
Shipping is at least $20. as I just paid it to get this kit
Sold Byron F-15 NIB with 2 Rossi 91 Ducted Fans Spawndn72 Aircraft - Fuel - Jets (FS/W) 7 Aug 08, 2017 07:41 PM
Sold 2 novarossi rx-21 f/ns race long stroke ducted fan r/c engines with 4 inch fan un G17staggerwing Aircraft - Fuel - Jets (FS/W) 4 Feb 12, 2017 08:42 PM
For Sale Freewing shroud with Delta-V 15 69mm EDF fan unit & BL15 Ducted Fan Motor, 3200Kv Robert Boudreau Aircraft - Electric - Jets (FS/W) 0 Dec 18, 2015 02:11 PM
Discussion Gws f-15 with jet screamer 4s and 2 xf fans booger Foamy EDFs 20 May 10, 2007 08:32 PM
For Sale F-15 Ducted fan with fan and motor rossi antslake Aircraft - Fuel - Jets (FS/W) 7 Oct 17, 2006 07:43 AM
