Jul 11, 2019, 02:30 PM
Omg! Diatone KababFPV Collabs: GTB 339 BOB Joint Design & others!
Omg!
I didn't know Bob Roogi a.k.a KababFPV was working on a collab with Diatone!
I have ordered the 3s, 3 inch version!
Updated product image (adjustable cam mount and Runcam nano I believe, will try to find better quality image...):
Description:
For transparency I am highlighting that I have Affiliate links below (use code RISHI for 15% off):
1) Diatone GTB339 3inch 120mm 3S BOB Joint Design PNP FPV Racing RC Drone
https://www.banggood.com/Diatone-GTB...097411201211@A
Specification:
Brand: Diatone
Item Name:GTB 339 BOB Joint Design
Prop: 3 inch
Lipo: 3S
Wheelbase: 120mm
Weight: 55g
Camera: NewBeeDrone Camera
Antenna: Copper pipe antenna
VTX: TBS UNIFY PRO32 NANO
FC: MAMBA F411NANO
ESC: MAMBA 124 /12A 4S Dshot 600
Motor: MAMBA Racing MB1105 5500KV /
Package Included:
1 X GTB 339 BOB Joint Design RC Drone
Description:
2) Diatone GTB239 105mm 2.5Inch 3S BOB Joint Design PNP FPV Racing RC Drone
https://m.banggood.com/Diatone-GTB23...097411201211@A
Specification:
Brand: Diatone
Item Name:GTB 239 BOB Joint Design
Prop: 2.5 inch
Lipo: 3S
Wheelbase: 105mm
Weight: 43 g
FC: MAMBA F411NANO
Motor: MAMBA Racing MB1103 6500KV (Optional)
Package Included:
1 X GTB 239 BOB Joint Design RC Drone
Description:
3)Diatone GTB229 105mm 2.5Inch 2S 8500KV/1000KV BOB Joint Design PNP FPV Racing RC Drone 8500KV
Specification:
Brand: Diatone
Item Name:GTB 229 BOB Joint Design
Prop: 2.5 inch
Lipo: 2S
Wheelbase: 105mm
Weight: 43 g
FC: MAMBA F411NANO
Motor: MAMBA Racing MB1103 8500KV /10000KV (Optional)
Package Included:
GTB 229 BOB Joint Design RC Drone
Description:
Jul 11, 2019, 04:03 PM
Ugly as hell and that cheap newbeedrone camera mount will break on the first crash.
Jul 11, 2019, 04:22 PM
I agree it doesn't look aesthetically pleasing at all, but Diatone have been doing well recently with the products they've been releasing so I'm willing to try this out to see if it performs well, given it also has Bob involved in the design.
Jul 11, 2019, 06:42 PM
Are we not men? We are DEVO!
xanuser's Avatar
nekid links
120mm 3inch 3s
https://www.banggood.com/Diatone-GTB...p-1530338.html
105mm 2.5Inch 3S
https://banggood.com/Diatone-GTB239-...p-1530341.html
105mm 2.5Inch 2s
https://www.banggood.com/Diatone-GTB...p-1530342.html
I do agree its ugly as !
BUT you all do realise the arms are vertical profile right? That's potentially a pretty big thing. Will be interesting to see how that frame holds up and if that type of profile takes off.
Jul 11, 2019, 07:43 PM
GoatZilla's Avatar
Welp, if Bob wants to take the credit, he can also take the blame.
Jul 11, 2019, 08:15 PM
The problem I see with those frames is you have to be very careful flying around trees. Other than that, he should just use the bigger frame for all 3 quads so that we can also put the 3" props on the 2s version.
Jul 12, 2019, 12:42 AM
Originally Posted by xanuser
nekid links
Brain fade moment: What does 'vertical profile arms' mean?
Jul 12, 2019, 12:50 AM
xanuser's Avatar
the width is less than the thickness.
micro frames are typically 1.5 to 3mm thick with arms usually over 4-5+ mm wide.
this looks to be the opposite and then some.
(guessing) 1-2.5mm wide but 4mm(+) thick. ?
this would be very cool if it works durability wise. the 'ugly' shape may be part of that trade off.
Jul 12, 2019, 01:13 AM
GoatZilla's Avatar
It looks like 3mm thick, with 1mm wide arms most of the way.
It's a neat idea but uh I wouldn't want to beta test this.
The 3" version is clearly very light.
But the 65mm versions are strictly average specs. After you add the RX and route the antennas, there's no apparent gain.
Ultimate let down: he didn't switch them over to 3-hole motor mount. He probably could have made it happen.
Jul 12, 2019, 01:22 AM
xanuser's Avatar
if its over 4mm thick and 1.5mm or less in width i'm interested.
after i wash the vomit from my mouth on the looks.
Jul 12, 2019, 02:06 AM
Registered User Friendly
ValHeli's Avatar
That's ok since you wouldn't be staring at it for long when you start flying. LOL
I saw the vertical frame design first on the karearea a while back. I've seen a similar design like this on YT used in drone racing.
the design makes sense from an aerodynamic standpoint. The thinner profile provides less turbulence, more thrust, and (should) maximize efficiency of the motors.
Jul 12, 2019, 03:13 AM
xanuser's Avatar
Originally Posted by ValHeli
That's ok since you wouldn't be staring at it for long when you start flying. .
point taken.
the vertical arms was my thinking on my toothless frame.
unfortunately/fortunately im just really bad at fusion. ill be done some time in 2025.
Jul 12, 2019, 03:24 AM
ValHeli's Avatar
point taken.
I'm just starting in fusion, but I'm well versed in sketchup. If you want, email me your sketch with measurements and I'll see what I can do.
Jul 12, 2019, 03:32 AM
xanuser's Avatar
fantastic
Ill fax you the cocktail napkins stat.
(OR, I'll just let the kababettes do all the beta testing )
Jul 12, 2019, 04:27 AM
Haters or just envious and grumpy old men?
Olol
New Product Diatone GTB 229/329/339 KababFPV edition Flycry Micro Multirotor Drones 72 May 11, 2020 06:39 PM
New Product Omg! Diatone KababFPV Collabs: GTB 339 BOB Joint Design & others! Rishi Banggood.com 2 Jul 17, 2019 04:10 PM
Discussion OMG omg omg omg OMG!! BE77 Pilot Life, The Universe, and Politics 19 May 05, 2018 03:46 PM
Help! how to design and manufacture the joint connect the wing and fuselage lee_chengze Electric Plane Talk 12 Jul 07, 2016 02:50 AM
Discussion Optimum 'T' Joint Design rcgroupie Composites Fabrication 8 Jun 28, 2010 02:41 PM
