This thread is privately moderated by Qwinout, who may elect to delete unwanted replies.
Jul 11, 2019, 05:38 AM
Common problems and solutions for DIY RC Drones
Drone FAQ Analysis and Solutions
https://qwinout.com/blogs/news/drone...-and-solutions
Q:The motor cannot be started after power-on, no sound
R:Poor contact of power connector
A:Reinsert the connector or replace the connector
Q:The motor cannot be started after power-on, and the “哔-哔-, 哔-哔-, 哔-哔-” warning tone is issued (the interval between every two sounds is 1 second)
R:Battery pack voltage is abnormal
A:Check battery pack voltage
Q:The motor cannot be started after power-on, and a “哔-, 哔-, 哔-” warning tone is issued (the interval between each sound is 2 seconds)
R:Receiver throttle channel without throttle signal output
A:Check if the cooperation between the transmitter and the receiver is normal, and whether the throttle control channel wiring is tight.
Q:After the power is turned on, the motor can't start, and the "哔, 哔, 哔, 哔, 哔" sounds a single tone.
R:The throttle is not reset to zero or the throttle stroke is set too small
A:Put the throttle stick to the lowest position;
Reset throttle stroke
Q:After power-on, the motor will not start, and a “哔-哔-” beep will sound, then a “56712” special tone will sound.
R:Throttle channel "positive/reverse" error
A:Refer to the remote control manual to adjust the “positive/reverse” orientation of the throttle channel.
Q:Motor reversal
Q:Wire order error of ESC output line and motor line
A:Reverse any two of the three output lines
Q:The motor rotates in the middle of the rotation
R:Throttle signal loss protection
A:Check if the cooperation between the remote control and the receiver is normal, and check if the throttle channel wiring is in good contact.
Q:The battery voltage is insufficient and enters the low voltage protection state.
R:Recharge the battery
A:Poor wiring contact
Q:Check if the battery pack plug is normal, the ESC output line and the motor cable connection are stable and reliable.
R:Random restart and working condition
A:Extremely strong electromagnetic interference in the environment
The normal function of the ESC is subject to strong electromagnetic waves. When this happens, please refer to the instruction manual, try to restart the power to start the normal working state; when the fault occurs repeatedly, the electromagnetic interference in the use environment is too strong, please use the product in other places.
Q:The plane can't fly or flip together
R:The motor is turning backwards
R:The propeller is reversed
R:The ESC signal line and the flight control connection sequence are wrong.
A:Check the motor steering, the propeller front and back paddle installation, the correct connection sequence between the ESC signal line and the flight controller
Q:Motor jitter does not turn
R:Poor contact between the motor and one of the ESC wiring
A: Check if the motor and ESC are soldered to the banana head, and the wire is loose.
New Product RC Part DIY 5V LED Strip 500mm Flying Crossing Racing Gate Door for RC Drone FPV Merch Banggood.com 0 May 15, 2019 06:21 AM
Mini-HowTo Design solutions for a simple DIY pod & boom glider jnuk Slope 3 Aug 11, 2017 05:43 PM
Discussion More Demoncratic Solutions For Non-Problems Park_Flyer Life, The Universe, and Politics 5 Dec 28, 2015 06:41 AM
Discussion Common Sense Solutions! MtnGoat Life, The Universe, and Politics 10 Oct 02, 2015 08:12 PM
Idea Common Brushless Problems And Solutions - Look here before asking Piece Power Systems 12 Aug 19, 2012 07:10 PM
