This thread is privately moderated by VicT, who may elect to delete unwanted replies.
Jul 08, 2019, 11:48 PM
Mini-HowTo
Turbo Timber top battery door mod
I have a blog for a top battery door for the original Timber but this is for the Turbo Timber. It might work for the original Timber but you are on your own.
Iíve had no structural problems with this TT mod. Iíve had about 100 flights and with no crashes it has held up. If you crash or damage the model in any way the whole aircraft must be inspected and fixed before the next flight. In my experience most flyers and especially beginners try and fly with a damaged model without fixing the crash damage. Then they blame their crashes on the models design. Enough Soap Box. Read on if you want,
The TT has 4 carbon fiber tubes that connect the motor mount to the main cabin area. The surrounding foam supports the tubes and acts as a wind fairing. By cutting away the top surface of the fairing the tubes are not compromised.
The top cowl and windshield are cut away with a new small size box cutter. Remove the ESC and any light wires to eliminate accidentally cutting those wires. See pics
