Jul 08, 2019, 10:12 PM
FrSky-MKT
New Product
FrSky New Arrival - R9M Lite Pro module and R9 OTA series receivers release
R9M Lite PRO
The R9M Lite Pro is the upgraded 900MHz Lite module. It has a high-speed digital interface, supports up to 1W RF power, and is fully encased in a CNC aluminum protective shell which also aids in heat dissipation when using high RF power. Designed with the new ACCESS firmware, it also supports spectrum analyzer functions. The module is perfectly compatible with FrSky new ACCESS radios like Taranis X-Lite PRO and X9 Lite.
Name: R9M Lite Pro1.jpg
Description:
SPECIFICATIONS
  • Dimensions: 62.4mm 30mm 18.4mm (LWH)
  • Weight: 34g
  • Channel: 16CH
  • RF Operating Frequency: 868MHz / 915MHz
  • RF Power (Non-LBT): 10mW / 100mW / 500mW / 100mW~1W (Self-adaptive)
  • RF Power (LBT): Telemetry mode (25mW) / Non-Telemetry mode (200mW / 500mW)
  • Compatibility: R9 (ACCESS / ACCST protocol) and TD series receivers
FEATURES
  • Long range, low latency, and high precision
  • High-speed digital module interface
  • Supports spectrum analyzer function
  • Supports up to 1W RF power
  • Telemetry data transmission supported
  • Antenna detection with accurate SWR indicator
  • CNC aluminum protective shell
  • Perfectly compatible with ACCESS protocol and new FrSky radio models
    (e.g. Taranis X-Lite PRO and new upcoming models)
MORE DETAILS: https://www.frsky-rc.com/product/r9m-lite-pro/
R9 MM-OTA
The 900MHz R9 MM-OTA receiver implements the ACCESS protocol and brings the user improved performance and features. The R9 MM-OTA supports wireless firmware updates over the air making binding to receivers even easier. As well as the convenience of checking the current receiver firmware version. The R9 MM’s compact form factor design is also carried over to the OTA version, and the R9 MM-OTA supports inverted S.Port as well.
Name: R9 MM-OTA 1-1.jpg
Description:
SPECIFICATIONS
  • Dimension: 16*10*2.8mm (LWH)
  • Weight: 0.7g (without antenna)
  • Number of Channels:
    Non-LBT Version: 4/16CH (Telemetry)
    LBT Version: 4/16CH (Telemetry) / 4/16CH (No Telemetry)
  • Operating Voltage Range: DC 3.5V – 10V
  • Operating Current: [email protected]
  • Operating Range: Up to 10km or above
  • Compatibility: R9 series module (ACCESS protocol)
FEATURES
  • 915MHz (Non-LBT Version)/ 868MHz (LBT Version)
  • Mini size and super lightweight
  • Supports OTA firmware update
  • Supports firmware version check
  • S.Port enabled and support telemetry data transmission
    (Support F.Port, download firmware to support the function)
  • Inverted S.Port enabled
  • Low latency and high precision
  • With RSSI output in SBUS
  • Battery voltage detection supported
  • Detachable Ipex connector antenna
MORE DETAILS: https://www.frsky-rc.com/product/r9-mm-ota/
R9 Mini-OTA
The 900MHz R9 Mini-OTA receiver implements the ACCESS protocol and brings the user improved performance and features. The R9 Mini-OTA supports wireless firmware updates over the air making binding to receivers even easier. As well as the convenience of checking the current receiver firmware version. The R9 Mini’s compact form factor design is also carried over to the OTA version, and the R9 Mini-OTA supports redundancy function as well.
Name: R9 Mini-OTA 1-1.jpg
Description:
SPECIFICATIONS
FEATURES
  • 915MHz (Non-LBT Version) / 868MHz (LBT Version)
  • Supports redundancy function
MORE DETAILS: https://www.frsky-rc.com/product/r9-mini-ota/
R9 MM-FC-OTA
FrSky R9 MM-FC-OTA is the ultra mini 900MHz receiver which can be easily connected with our dedicated FrSky flight controller boards using a flexible flat cable. The R9 MM-FC-OTA supports wireless over the air firmware updates, and features an inverted S.Port output that makes it compatible with more devices. In addition, it can also be used as a standalone receiver.
Name: R9 MM-FC-OTA 1-1.jpg
Description:
SPECIFICATIONS
  • Dimension: 12.4*12.8*3mm (LWH)
  • Weight: 0.6g (without antenna)
    Non-LBT Version: 16CH (Telemetry)
    LBT Version: 16CH (Telemetry) / 16CH (No Telemetry)
  • Operating Voltage Range: DC 4V~6V
FEATURES
  • F.Port enabled and supported telemetry data transmission
MORE DETAILS: https://www.frsky-rc.com/product/r9mm-fc-ota/
Jul 10, 2019, 02:48 AM
Does this mean that current R9 Mini and R9MM even with ACCESS firmware have no OTA updates enabled?
I hope it's not like this..
Jul 10, 2019, 04:00 AM
Happy FPV flyer
Kilrah's Avatar
Yes, FrSky previously announced that OTA would only come with new hardware. Not enough memory on old stuff.
Jul 10, 2019, 06:59 PM
I kill batteries!
So we could assume that the existing rx's that have been pushed to access by user firmware upgrades (rxsr, xm+ etc) won't be ota compatible.
Jul 11, 2019, 12:00 AM
3djc's Avatar
Yes
Jul 20, 2019, 06:52 AM
R9m Lite Pro has received the goods, but the insertion of x-lite-pro can not be used on frequency. Should be no corresponding firmware, in the frsky official website can not find firmware, trouble frsky technicians see me send a firmware download address!
Jul 21, 2019, 04:19 PM
flying and braking frames
does the r9m lite pro function with the first generation xlite?
Jul 21, 2019, 11:02 PM
FrSky-MKT
The LBT firmware isn't available yet. Please pay attention to the product page update, thanks for your understanding.
R9M Lite Pro: https://www.frsky-rc.com/product/r9m-lite-pro/
Yes, the standard X-Lite will support R9M Lite Pro.
Jul 21, 2019, 11:26 PM
And the standard xlite has the power delivery to output 1W?
im asking to avoid the fiasco of the nirvana
Jul 22, 2019, 04:24 AM
The problem has been solved temporarily. We hope to improve the firmware of remote controller and R9m Lite Pro as soon as possible.
Aug 02, 2019, 06:57 PM
CM17x's Avatar
Hi there!
I'm about to start with my first build and i just got lost with this new stuff. When i bought my X-Lite (No pro) it comes with the R9 Lite module, hence i bought a R9MM for use it. But, how can i update my receiver if i can't do it Over the air? My receiver didn't came with any cables or stuff to connect it to my TX, just two set of pins which i have no idea what do do with them (Picture attached).
I'll appreciate your help and insights. Thank you.
Aug 03, 2019, 02:45 AM
Happy FPV flyer
Kilrah's Avatar
The R9MM is made to be as small as possible, meaning you DIY and solder any cables/connectors you might want or need. To update firmware you need to wire up -/+/S-port to the s-port connector on the radio.
Aug 13, 2019, 10:40 AM
Monsieur's Avatar
868 MHz antenna
@ Andrea from Frsky: Could you encourage vendors like Banggood to sell frsky r9 receivers and modules with the option to choose between 915 MHz and 868 MHz? Otherwise here in Europe we have to buy the 915 MHz version and buy a separate 868 MHz antenna which is kind of annoying. I know this is already the case with the newest r9 ota receivers but not with the other stuff like this r9m lite pro set.
Aug 14, 2019, 05:42 AM
And the new X9D 2019 edition? will be a new full size module available?
Aug 16, 2019, 01:45 PM
R9M Lite Pro and original X-Lite
Just wanted mention it here because I have been wondering for a while. R9M Lite Pro works with the original X-lite on optentx 2.3 nightlies. I confirmed this myself.
What does this mean?
If you run R9 with the original X-lite, you don't need to upgrade to X-lite pro to get all the R9M Lite Pro/ACCESS goodness. It even has the spectrum analyzer tool!
Cheers!
New Product FrSky New Arrival R9&R9M long range RC system AndreaHuang FrSky 6178 Yesterday 01:21 PM
New Product FrSky New Arrival - R9M Lite module AndreaHuang FrSky 0 May 11, 2018 02:40 AM
New Product FrSky New Arrival R9&R9M Long Range RC System AndreaHuang FrSky 2 Oct 01, 2017 11:41 AM
