Jul 08, 2019, 09:53 AM
Charging a Lead Calcium battery
I am restoring a tug boat. The battery that is in it is a rechargeable Lead Calcium 12 V 7 AH. It's a big battery 2-1/2" x 4" x 6". My charger does not list this type but does have Lead Acid (Pb) . Is a Lead Calcium the same, or close to, a Lead Acid? Can I use the Lead Acid setting to charge the Lead Calcium? If not how do I charge it?
John
Jul 08, 2019, 12:34 PM
Boats on the brain!!
green-boat's Avatar
It can be charged just like a Lead acid battery. Adding calcium to the electrodes in the battery, it gives it a longer service life and useable at lower temps.
Jul 08, 2019, 12:47 PM
Thanks Green Boat. One thing I have read is the voltage level is lower for charging of a lead acid than a lead calcium. So if I use the Pb charger the voltage would be lower. Would this effect the charge much? Maybe just not get a full charge?
Thanks again
John
Jul 08, 2019, 03:49 PM
green-boat's Avatar
Using a regular Pb charger will not get you a full charge but close. If you are using a computerized charger and are able to reset the cell voltage to 2.25 volts from 2.1, then you will get a full charge.
Jul 08, 2019, 04:53 PM
I believe I can reset the voltage, I'll give that a try
Thanks so much for the help
John
Discussion lead acid battery charging vini9213 Batteries and Chargers 1 Sep 15, 2015 05:22 AM
Question Can Thunder AC6 Charger charge Lead Calcium or Gel Cell? claycephus Batteries and Chargers 3 Jan 18, 2010 03:30 PM
Discussion Lead Calcium Battery (12v), how many charges of a 3200mah 3s lipo typical? markm75 Batteries and Chargers 12 May 17, 2007 01:37 PM
Lead Calcium Battery Charger Mike Rappold Batteries and Chargers 1 Feb 14, 2003 09:15 PM
