This thread is privately moderated by Kmot, who may elect to delete unwanted replies.
Jul 08, 2019, 12:30 AM
Grumpa Tom
Kmot's Avatar
Restored a vintage gasser.
This is a "Rocket Victor .45" from 1945. It was manufactured by the May Motor Company. George May was the proprietor and designer.
It was probably a "budget" motor back in the day as it is made from low cost materials and methods. Such as, a stamped steel connecting rod, three piece stamped steel crankshaft, steel piston with a sheet metal baffle bolted to the top. It has no bushings, let alone bearings. The needle valve is aluminum with what looks like a tapered nail. But, it is cool looking! The exhaust stack is classic! And the points adjusting lever looks like an old fashioned gearshifter.
This engine had a lot of field repairs done to it. Most of the screws are not original. There was a hole drilled into the top of the fuel tank and later plugged and epoxy glue applied. There was some epoxy glue on the backplate too. Two of the cylinder hold down screw holes are stripped and drilled out and larger screws and nuts in place.
I disassembled it and cleaned all the parts. The back plate has a sheet metal rotor staked to a drum and it broke off because the drum was stuck inside the back plate with dried castor oil. I repaired it, It needs a spark plug. In the mean time it has a glow plug installed. It has good compression and pops nicely when flipped over.
I just happened to have a vintage, custom made motor mount that I got years ago. Never knew what it was designed for. Well, it fits the Rocket like it was made for it. Coincidence?
It's a great addition to me model engine collection.
Latest blog entry: Felony
Aug 18, 2019, 09:51 PM
Grumpa Tom
Kmot's Avatar
Vintage Rocket Motor "Victor" .46 Cu. In. Gas Motor Bench Test (5 min 4 sec)
The Actual Moment of Reverse Running (0 min 19 sec)
Question Restoring unknown vintage RC sailboat keaton85 Sailboats 32 Oct 07, 2017 05:20 PM
Gallery This is a vintage 1970 sailboat I bought and now restoring BillKuhn Vintage & Old-Timer Boats 14 Dec 02, 2016 09:49 AM
Help! Looking for help in restoring two vintage sailboats in the Portland, Oregon area klautzsch Scale Sailboats 2 Jun 13, 2016 12:10 PM
Help! Need Vintage Xtal for Transmitter Restoration Mr.RC-CAM Vintage & Old-Timer Designs 25 Dec 21, 2015 08:43 AM
