Aug 19, 2019, 12:47 PM
Quad Erat Demonstrandum
scousethief's Avatar
Dont worry, i think Hawkeye are still finalising the best firmware, i have had a few chats with them via Face book regarding very minor issues ( none that hamper performance ) which is one of the reasons i havent uploaded sample video ( Ive been ill in bed fighting death and i will be accused of "faking" the video due to the corrupted exif data )
Aug 21, 2019, 12:54 PM
angelo.p's Avatar
Arrived!
Inviato dal mio Redmi Note 5 utilizzando Tapatalk
Aug 21, 2019, 06:49 PM
angelo.p's Avatar
test in progress.
For now here is my latency test
24 hundredths of a second.
Aug 23, 2019, 06:19 AM
Ill test mine once it gets a new firmware, the lag on mine is a little too much to race with. It would be perfectly fine on a plane or on a cheap AP quad as an extra camera but atm i wouldnt use this as a main flying camera
Aug 23, 2019, 10:05 AM
How can you turn off the OSD ?
Sorry - have found the menu ;-)
Aug 25, 2019, 01:07 AM
angelo.p's Avatar
I started the test on a quad.
- using 4k the FPV feed is unflyable. I notice lag and it's not good. Using 1080p60 I can fly. But I want to do more test and there are a lot of combinations to use: WDR, EIS and so on
- after some flight I decided to do some ground footage to compare video quality. After some changes (I don't remember now but I hav the dvr from my goggles) the video disappeared and the cam doesn't power up. If I press the power button I see the blu led flashing once, a beep and after shut down.
Now I'm looking for a way to reset.
Aug 25, 2019, 01:46 AM
angelo.p's Avatar
Solved: after flashing again the last firmware the cam is working.
My last operation before the issue was choosing "Auto Power OFF". After this I was not able to power on the cam...
Aug 25, 2019, 03:16 AM
angelo.p's Avatar
It has appened again: I changed to 1080p120 and when I get out from the menu the board powered off.
So my previous fault wasn't the auto power off but I only see the last action on the menu before leaving it.
No my board power off after powering on and I have to flash it again to restore!
Aug 25, 2019, 04:15 PM
angelo.p's Avatar
My first video is resdy
Hawkeye Firefly Split 4K - Recensione - Menu - Test di volo (22 min 29 sec)
I didn't added 4k footage in this video. I will post some other video later.
My first considerations:
- first impression of 4k fpv feed is bad for a lot of latency. I will try more combination in the next video (WDR on/off, EIS on/off, and so on)
- with 1080 or 720 the FPV feed is OK. And video footage is very good
- a lot of configurations are available
- the dimension (30mm mount for the board and not micro cam) is a limit: I cannot use on my last build (geprc-cx3 a 3 inch frame)
- the only way to change configuration is with the micro board. It's OK in the real life when you need only to click on record and stop. But when you need to experiment the lack of WiFi is a CONS.
- Finally the shutdown issue. As I wrote in my previous post, during the configuration my board is powered off and I cannot power on (only one beep with led and after power off again). The first time I thought I choose a wrong configuration. The second time I was only changing the resolution and after exiting the menu I noticed the issue again.
To reset the board I must flash firmware again. I like to understand if my board is fault or there is a bug. I will try an older firmware...
Aug 25, 2019, 06:32 PM
I bought one, it has a problem:
When powered down the last file is corrupt beyond repair.
The description of the firefly 4k is that it auto repairs the last files upon repowering up the board with the SD card in.
Originally Posted by BGKevin
Need Reviewers for Hawkeye Firefly Split 4K 160 Degree HD Recording DVR Mini FPV Camera WDR Single Board Built-in Mic Low Latency TV Output for RC Drone Airplane
Link Here: https://ban.ggood.vip/opMn
5 Quotas for Free Testing
Leave Request Below for Free Testing
Brief Introduction:
Brand name: Hawkeye
Model: Firefly Split
Product weight: 19g
Package weight: 380g
Camera Size: 19MM×19MM / 22×22MM
Product size (L x W x H): 38×69×32 MM
Package size (L x W x H): 99×69×32 MM
Pixel: 12 million
WDR: YES
Memory support: U3
Storage medum: MP4
Format: H.265/H.264
Video repair: YES
External memory storage(Maximum, not included): 128G
Memory: Micro SD Card
Gyro Image stabilization: YES
Sensor size (inch): 1/2.3
Sensor: CMOS
Sensor: 12mm
Image resolutions: 12M
Default resolution: 12M
Video Resolution: 4K 30FPS(16:9), 2.7K 60FPS(16:9), 2.7K 30FPS, 2.5K 60FPS(16:9), 2.5K 30FPS, 1080P 120FPS, 1080P 60FPS, 720P 240FPS, 720P 60FPS
Video Frame Rate: 4K 30FPS(16:9), 2.7K 60FPS(16:9), 2.7K 30FPS, 2.5K 60FPS(16:9), 2.5K 30FPS, 1080P 120FPS, 1080P 60FPS, 720P 240FPS, 720P 60FPS
FOV: 160 degree
White Balance: Auto, Daylight, Cloudy, Tungsten, Fluorescent, Diving mode
Scenes: Auto, Portrait, Landscape
Photometry mode: Multi, Center, Spot.
File format: MP4
ISO: Auto, 100, 200, 400, 800, 1600, 3200.
Exposure Compensation: -2.0 to + 2.0
TV System: NTSC/PAL
Latency of TV: 0.04S/PAL
Language: English/ Chinese/Multi
Microphone: Built-in
Loudspeaker: Beep
Interface: Micro HDMI/Micro USB
Frequency: 50/60HZ
Auto power off: YES
Power Sources: 2S-6S Battery
Current: 200MA @ 12V
External Trigger: YES
Aug 28, 2019, 05:37 PM
angelo.p's Avatar
After flashing again the power-off issue is disappeared and I made more test in different resolutions.
Flying slow in "cinematic way" also the 4K resolution is flyable.
Now I have to trasplant from the test quad to one of my Cinewhoop.
Here are the raw videos.
Raw video 4Kp30
Raw Video Hawkeye Firefly 4K Split cam 4Kp30 WDR ON EIS ON (1 min 18 sec)
Raw video 2KP60 WDR ON EIS ON
Raw Video Hawkeye Firefly 4K Split cam 2Kp60 WDR ON EIS ON (1 min 44 sec)
Raw video 2KP60 WDR OFF EIS OFF
Raw Video Hawkeye Firefly 4K Split cam 2Kp60 WDR OFF EIS OFF (1 min 38 sec)
Raw video 1080p120
Raw Video Hawkeye Firefly 4K Split cam 1080p120 WDR ON EIS ON (1 min 48 sec)
Raw video 1080p60
Raw Video Hawkeye Firefly 4K Split cam 1080p60 WDR ON EIS ON (1 min 36 sec)
Raw video 1080p30
Raw Video Hawkeye Firefly 4K Split cam 1080p30 WDR ON EIS ON (3 min 1 sec)
Aug 29, 2019, 10:54 AM
Hi, use keyboard, clik playback button, the bad video can be repaired.
Aug 29, 2019, 11:01 AM
Firmware Updated 0829
Dear All
http://www.cnfpv.com/portal.php?mod=view&aid=128
Update List:
1. Fixed camera hangs at H.265 &1080p 120fps .
2.Fixed camera hangs at HDMI output 720P when recording.
3.Add "Hawkeye 3" white balance for Hawkeye Large FOV Lens
4. Fixed HDMI output problem.
Aug 29, 2019, 11:08 AM
Double clik menu button, then go to system menu, you can find :OSD
Aug 29, 2019, 11:09 AM
Dear Sir, please update new firmware: http://www.cnfpv.com/portal.php?mod=view&aid=128
New Product Hawkeye Firefly Split Cam - another split type camera montis FPV Equipment 17 Today 07:25 AM
Mini-Review HawkEye Firefly 6S 4k (2160p) vs Firefly 5S 1080p Comparison Sunny_1 Aerial Photography 2 Nov 09, 2015 05:29 PM
