This thread is privately moderated by Bella Liu, who may elect to delete unwanted replies.
Jul 02, 2019, 02:47 AM
Cool
1-8S Voltage Indicator and Buzzer for RC Battery
Products Description:
1. Use for 1-8s Lipl/Li-ion/LiMn/Li-Fe.
Voltage detection pricision: 0.01V.
Unit voltage display range: 0.5V-4.5V.
Total voltage display range: 0.5V-36V.
1S test mode voltage range: 3.7v-30v.
Low voltage alarm mode for 2-8S.
Alarm set value range: OFF-2.7V-3.7V.
2. When the voltage is below the set value,it will buzzer with red LED light,pre-set value 3.3V.
3. Push key which can change the voltage settings and save.
4. Size: 3.9cm x 2.4cm x 0.9cm.
Appliable for: RC Quadcopter, helicopter, multicopter,car,boat and airplane,1S-8S / Lipo / Li-ion / Li Mn / Li-Fe battery.
Features:
-This product is using for detecting 1S-8S lithium battery
-Detect the voltage of each battery core automatically, support reverse connection protection.
-To know the working state of your battery anytime, protect the battery from overcharge and over discharge.
-The red LED will flash,the buzzer will beeping when the voltage is below the set point.
-The factory default setting is 3.3V, press the button to change the voltage setting, and it will save your current setting automatically.
Package Included:
1 x Voltage Buzzer Alarm
Web: www.dtn-tech.com
Email:[email protected]
Tel: +86-15818289223
Datton Electronic Tech. Co.,Ltd
Last edited by Bella Liu; Jul 02, 2019 at 02:48 AM. Reason: add detailed information
Discussion Alternatives to Low voltage buzzer/indicator harsh.k Batteries and Chargers 2 Mar 11, 2019 08:51 AM
Careful! 1-8S 2in1 RC Li-ion Low Voltage/Buzzer Test. Not Pretty! TheQuestor Multirotor Drone Electronics 6 Jun 24, 2018 10:59 AM
Discussion 1-8S Lipo Battery Low Voltage Buzzer Alarm Inconsistent Readings questech Batteries and Chargers 2 Jan 17, 2016 09:10 AM
Discussion 1-8S Lipo Battery Voltage Tester / Low Voltage Buzzer Alarm johnathansmith69 Beginner Multirotor Drones 16 Sep 15, 2015 03:30 PM
Help! Problem using Lipo Battery Low Voltage Tester Alarm Buzzer 1S-8S JoiCam Batteries and Chargers 0 Apr 07, 2015 02:16 PM
