Jul 01, 2019, 05:05 PM
propnator's Avatar
Help!
Can't program throttle from center
I have a Taranis plus radio mode 2 and am trying to set the throttle stick to run forwards at up position and backwards pulling stick down from center. I've been studying curve settings until I fall asleep. So far I can get the forward to work, but nothing happens pulling the stick down???
Jul 02, 2019, 02:45 AM
Does the ESC have reverse?
Jul 02, 2019, 08:04 AM
propnator's Avatar
No. But it can be reversed (accidentally).
Jul 02, 2019, 03:41 PM
Just Plane Nutts
AirDOGGe's Avatar
Reversibility in programming is not the same as having forward/reverse capability in operation.
Jul 02, 2019, 03:46 PM
propnator's Avatar
Yeah, I just found out the ESC in this (Vector 70) is FORWARD ONLY.
^&*??!! The time I wasted!!
Jul 02, 2019, 07:21 PM
Just Plane Nutts
AirDOGGe's Avatar
Nah! Time well invested in learning something new. That's my story and I'm sticking to it.
One of these should get you going and provide some headroom for a hotter motor if one is in your future: https://hobbyking.com/en_us/turnigy-...t-esc-70a.html
Happy wake-making!
Jul 03, 2019, 04:03 AM
You are now more experienced. Officially.
Jul 03, 2019, 04:41 PM
Latitudes vs Attitudes
Bob Gaito's Avatar
As I can see from the Vector 70 ads-it has a flex shaft meaning it must stay fwd only because if you run the flex shaft backwards it will want to unwind and bind up so you can't change just change out the ESC to one that has reverse..(apologies if someone else already mentioned this)
Latest blog entry: Mark V Navy Seal SOC
Jul 04, 2019, 09:19 AM
propnator's Avatar
Thanks guys, I was doing this for a friend. I'm stricktly aircraft (some times float fly).
Bob's comment is absolutely right and now I can tell my whining friend to check out what he buys more carefully.
Help! How to program a Taranis X9DPlus so left throttle stick reads zero at center position Bill Allman Sailplane Talk 6 Aug 13, 2018 07:27 PM
Help! How to program a Taranis X9DPlus so left throttle stick reads zero at center position Bill Allman Multirotor Drone Talk 4 Aug 13, 2018 12:12 PM
Help! Program Taranis X9DPlus so left throttle stick reads zero at center position. Bill Allman Electric Plane Talk 3 Aug 12, 2018 05:14 PM
Discussion Can't program throttle on HURC 50A ESC whitehawk80 Power Systems 2 Jun 16, 2013 10:10 PM
Discussion Can't set brake on Hyperion Titan from TX programming? Kiba Power Systems 4 Apr 28, 2010 04:03 PM
