Mar 18, 2002, 06:48 PM
Can't figure out plan
How can this be?
This bipe has a full lower wing. Yet there is "structure" below. And the landing gear attaches under the lower wing.
There are wing holddowns, so I assume the lower wing can be removed.
Help!
James
Mar 18, 2002, 07:10 PM
I see the future.
Yukonho's Avatar
Looks to me like there is a box built on the bottom of the wing that remains attatched to the wing. The front of this box lines up with the cutout in the fuselage. As far as landing gear, my guess is that it remains attatched to the bottom of the fuse and you have to detach it from the wing to remove the wing. I know what I am thinking, I am just not sure I am explaining it clearly. Hope this helped.
Mar 18, 2002, 11:12 PM
Yes I see what you mean, but that seems a bit awkward to have to mess around with the landing gear attachment jest to remove a wing.
I think I'll keep looking for other plans.
James
Mar 18, 2002, 11:16 PM
I fly, therefore I crash
James,
My older brother built a Guillow's kit that looked similar to this bipe, and the bottom wings were built as two halves that attached to the fuse separately.
Mar 19, 2002, 04:33 AM
There are an awful lot of WW1-style bipes with the same setup. I suspect it's almost all of them. The front of the U/C hinges, the rear is usually fixed with 2 clips. Anyway it's a bipe, you already have to "mess around" with all the strut fixings to take the wings off. How much harder is it to undo a couple of extra clips ?
Steve
Question I can't figure this out...can anyone please explain this? whowhatwhere Parkflyers 0 Dec 05, 2016 10:00 AM
Help! Can't figure out what's wrong...Help! The Duke Of Zyr FPV Equipment 0 Nov 16, 2016 01:25 PM
Help! Just can't figure it out!! CptnCrashandBurn Beginner Multirotor Drones 26 Jul 12, 2016 01:16 PM
Discussion Somewhat "famous" stormchaser can't figure out DJI Phantom 3 P-51 fan Model Aircraft & Drone Advocacy 0 Apr 21, 2016 12:14 AM
Discussion I can't figure this out!!!! Fpv Seventhirtysharp Beginner Multirotor Drones 4 Mar 05, 2016 10:58 PM
