Jul 01, 2019, 08:42 AM
t00nz843z's Avatar
Mini-Review
SJRC F11 Pro Folding Brushless-Long Flying-Very High Resolution GPS Camera Drone
This might currently be the best GPS camera drone in the under $200 price range (as of July 2019) . Brushless motors, accurate and steady GPS/GLONASS, over 20 minutes flight time, super high resolution camera, and nearly everything seems to work as advertised (unusual in this price range)! Find it here.
And here is its flight demonstration.
SJRC F11 Pro Folding Brushless-Long Flying-Very High Resolution Camera Drone Flight Test Review (44 min 31 sec)
Pros
- Folding drone for maximum portability and protection of the drone during travel. Optional storage and transportation bag is available for extra cost.
- 1806 brushless motors.
- GPS/GLONASS system for rapid satellite lockon and improved location accuracy. Drone can automatically return to home and land at its takeoff point on command, loss of signal, and low battery.
- Includes a very high resolution 4MP HD camera (2592 x 1520 pixels at 25 FPS). Video is recorded to an onboard SD card. Lower resolution 720p video is also simultaneously recorded to your phone via 5Ghz WiFi. This video is also good (for 720p) with minimal (if any) frame dropping. Camera lens can be remotely adjusted up or down via the drone's controller.
- 11.1V 2500mah battery provides well over 20 minutes of flight time (I got 22 1/2 minutes flight time in this video with aggressive flying).
- FPV video range of over 400 meters. Line of sight control range thought the controller is much further, and is advertised at 1200 meters.
- Controller includes circle position and remote up/down control of camera lens. Controller also has a built-in rechargeable 300mah battery (AA's not needed with this controller).
- In flight video can be viewed and recorded to your smartphone using the "SJ GPS Pro" app available on Google Play here and iTunes here. App provides FPV viewing and recording capability, gesture camera control, along with circle position, GPS and optical follow me, and waypoints. The app has been updated since my original January 2019 review of the original SJRC F11, with nearly all features now working perfectly. Waypoints (now with working Google Maps/Satellite View!) and GPS follow me work particularly well with this app. The drone transitions smoothly from waypoint to waypoint without stopping. And the follow me algorithm has been updated to smooth the drone's flight when using this feature (original was very jerky in movement).
Cons
- Uses 802.11ac WiFi. Not everyone has such WiFi on their phone. As always, I strongly recommend that you first verify that your phone is indeed 802.11ac WiFi capable before purchasing. Google search your phone model name, along with the term 802.11. See if 802.11ac shows up in the results for your phone's specifications.
- Although it has a very high resolution camera, its resolution is unusual at 2592 x 1520 pixels. Some video editing programs may have problems editing it. The camera also has some fisheye effect from its 120 degree wide angled lens, and its white balance is somewhat cool with blueing (white balance is easily corrected with video editing software). For those experiencing editing problems, may I suggest the powerful free video editor that I use for all of my YouTube videos (VSDC available here http://www.videosoftdev.com/free-video-editor). Although free, it is a very feature rich and powerful video editor. But it is not very intuitive and does have a learning curve. Fortunately, there are very many YouTube tutorials for it to get you started.
- If only this had a stabilized gimbal, or a good onboard processor with electronic video stabilization (like the Tello). Such features would make this a near perfect drone (but unfortunately would also likely increase its price).
Jul 02, 2019, 03:02 AM
Pixelpeter's Avatar
Judging from your video QC101, this is indeed a good one, with ample flighttime which is great (20+ mins!). With 3 flightbatteries for 208
Although it's nice to have a wide angle lens on your quad's camera, I kinda get the feeling that this particular one seems to tip into the opposite direction and getting maybe a bit too wide imo. Also kinda looks like the camera cannot be pointed straight ahead; if that's indeed true, they probably did that to prevent the props from getting into view too much with this very wide view. As you said: some form of stabilisation would make this indeed an awesome quad although it would raise its price.
Jul 20, 2019, 07:40 PM
I see on a lot of unboxing videos for F11 pr F11 Pro Drone and the underside of the box top is "dirty" looking right where the drone is located, as if the black finish of the drone has rubbed off onto the underside of the box top.
Is there any sign of the finish rubbing off (showing on hands or fingers) or showing signs of fading?
I am just puzzled as to why the underside of the lid, right where the Drone is located in the foam, is always blackish/dirty looking!
Thanks! Oh, I have this on order and is currently in shipped status! I cant wait for it to arrive!
Sep 17, 2019, 08:54 AM
Srjc f11 GPS go app with Google maps
I purchased this drone based on glowing reviews and admit the drone has a ton to offer at this price point. BUT I can't for the life of me get the flight app to work with Google maps. If I select wavepoints the map background is blank, just a grey field with a small "Google" in bottom left corner. Flight data doesn't show any map features as well. It's like the GPS go app can't bring Google maps into it, just weird. I've got a new phone, pixel 3 and it's not had any other issue. I've read where others have had this same issue but no where do I see a fix. That's a big issue is you ask me as it cuts some big features from being able to be used. God forbid you lose the drone. You sure won't be able to use the app to find where in Google maps it went down/missing. If anyone has a fix for this I'd appreciate the info.
New Product SJRC F11 GPS 5G Wifi FPV With 1080P Camera Brushless Selfie RC Drone - Free Reviewing BGKevin Multirotor Drone Talk 72 Jun 06, 2019 11:12 AM
New Product Competitor of SJRC F11? SG906 Folding Brushless GPS 1080P / 4K RC Drone GeekBuying Geekbuying.com 6 Apr 26, 2019 09:20 PM
Discussion SJRC F11 GPS 5G WiFi FPV Foldable Brushless RC Drone QIU Multirotor Drone Talk 1 Dec 26, 2018 05:38 PM
