Jul 11, 2019, 01:46 PM
flyin' fool
goldguy's Avatar
Check out what Pat says in his comments under 'A Little About Deltas .......................
https://www.rcgroups.com/forums/show...erfly-E-Review
I think this applies to round too.
Jul 11, 2019, 02:18 PM
pull up -- PULL UP!!!
SuperFly -- my first plane after earning my wings with the ubiquitous Champ trainer. Still fly it.
Amazingly, you can still buy it too. Cheap.
https://www.ebay.com/itm/SuperFly-RC...AAAOSwymxVOnfe
Oct 10, 2019, 01:45 AM
UCreate 10 pk 20''x30'' Foam Boards-Assorted at Joann
Hi,
I think $Tree foamboard is the way to go, but I looked into the UCreate foam a bit ...
Found a 10 pack of 20"x30" at Joann's, but it's expensive
https://www.joann.com/ucreate-10-pk-.../16741142.html
Walmart has
15"x 20" in white for $1.77
https://www.walmart.com/ip/UCreate-F...-Each/21652305
22"x 28" in black for $0.67
https://www.walmart.com/ip/UCreate-F...Sheet/17203968
Mfg website for 15"x20" white
https://pacon.com/foam-board-350/car92006.html
Amazon white 20"x30", 10 sheets, $25
https://www.amazon.com/Pacon-Foam-Bo...ef_=ast_sto_dp
https://www.amazon.com/Pacon-Super-V...ef_=ast_sto_dp
Oct 10, 2019, 09:37 AM
I suspect there's more to it than just finding that brand. There could be multiple U-Create foamboard products and they might differ significantly.
As an example, if one just reads the descriptions, Adams Readiboard (Dollar Tree) sounds similar to Elmer's Posterboard (WalMart). But I use both and they are very different in density and weight. I have to design specifically for each because they're not interchangeable.
I don't know how you can choose a posterboard without actually buying it and doing your own tests and measurements.
FWIW
Readiboard = .19g/sq-in
Elmer's = .38 g/sq-in
U-Create = ???
Oct 10, 2019, 01:15 PM
Originally Posted by rcflydad
Hi,
When I tried that, with shipping and tax, that came up to $73.54 for 10 sheets of 20x30 of 3/16" (4.7mm) material
Last month, for $95.46 including shipping, I got 16 sheets of Grade A and 8 sheets of Grade B 24x48 1/4" (6mm) Model Plane Foam from Springer. For $22 more than the JoAnn price, I got over 4x the material (in total square inches). Although I haven't yet begun to build with it, I am very impressed with the quality of what I got from MPF/Springer.
Oct 10, 2019, 09:49 PM
flyin' fool
goldguy's Avatar
Too bad our dollar is in the dump against the almighty Yankee buck and that shipping costs are 'out of sight' to go north past the 49th.
Oct 10, 2019, 10:08 PM
While one can argue that many foams might be superior, I haven't found anything that justifies a huge cost increase over Dollar Tree Foam. Here's my latest delta using a single ply of DTF even though it's a 1000mm wingspan. But it does use a carbon exoskeleton.
And yes GG, this IS an equilateral triangle. Three 1m carbon tubes secured by a heavy cord for a bulletproof triangular frame.
Oct 10, 2019, 11:30 PM
flyin' fool
goldguy's Avatar
. and a tractor too.
Oct 10, 2019, 11:31 PM
flyin' fool
goldguy's Avatar
Been playin' around with this ..
Oct 10, 2019, 11:34 PM
flyin' fool
goldguy's Avatar
But, it doesn't quite cut the mustard for some reason. Probably that extra ounce.
So, choppin' out a 'Superflea type' platform in the cheap light stuff.
Discussion Smoothies !!!!!!!!.......I just discovered these tasty delights.......yes i know.... rockyboy2 Life, The Universe, and Politics 18 Aug 26, 2017 10:03 PM
Discussion Just friggin' delightful dll932 Life, The Universe, and Politics 3 Feb 16, 2011 08:11 PM
Discussion Just another delta Edmonds Foamies (Scratchbuilt) 15 Feb 24, 2009 11:16 PM
Double Delta Day Delightful sr71fan Foamies (Kits) 4 Mar 29, 2005 07:42 AM
not just another walmart glider conversion.......DELTA!!!! corndog Foamies (Kits) 14 May 21, 2004 07:14 PM
