Jun 30, 2019, 05:55 PM
flyin' fool
goldguy's Avatar
Just Another Delightful Delta?
Not really!
It's a 24 incher at 3.3 ounces RTF with a wing loading of 2.3 ounce per square foot, so a real ripper. Powered by a Racestar BR1306/3100kv spinning a 4.1X4.1 prop on 2S 300 at 42 watts in it hauls. I spent less than two hours turning it out and it flew perfect right off the bench. Maiden it in light wind and then the wind came up for some real fun.
Delightful? YES!!
Jun 30, 2019, 06:23 PM
IMO ( In My Opinion ) →
balsa or carbon's Avatar
Simply Delightful Delta !
Jun 30, 2019, 06:39 PM
Rough Landing
rainyday101's Avatar
What foam or foamboard did you use? If foamboard, paper on or off?
Post some plans and this will end up being a 500+ page thread!
By the way, those Racestar motors from Bangood are a bargain and real performers.
Jun 30, 2019, 09:26 PM
flyin' fool
goldguy's Avatar
From Carolina Pad, no paper, just paint on one side, it's called Ucreate Board. Bought it at a $$tore here.
Jun 30, 2019, 09:27 PM
flyin' fool
goldguy's Avatar
I plan on a plan as soon as I find my pencil ………………..
Jun 30, 2019, 09:59 PM
Rough Landing
Have not seen that at out $Tree stores.
Can't wait to see those plans!
Jun 30, 2019, 11:21 PM
flyin' fool
goldguy's Avatar
All you really need to build, more than I started with …………...
note: .............. The triangle is cut, then the nose chopped off to mount the motor and the bottom spine shape/size is optional.
This was actually a prototype to check out it's ' flyability' and the plan was to build a keeper using EPP.
I bashed it around pretty good today in a hay field and it took it all. So, staying with the cheapo foam as it's easier to build and no CF stiffeners required. Cheep too, less than a dollar to build. Humm, think I'll build a few more.
This wee one flies all the delta aerobatic you can throw at it, including backwards flight and harrier landings. Being a delta that's easy. Because of it's low wing loading you can slow it right down and grease it in for an inverted landing no problem. Just a fun little simple elevon only for maximum fun.
This is definitely an improvement over my Park Lark. Must be the different delta math. Maybe? https://www.rcgroups.com/forums/show...ht=Park%20Lark
Jun 30, 2019, 11:26 PM
flyin' fool
goldguy's Avatar
The motor is 0:0 and the reflex is about 2mm. Tune to taste.
Jul 01, 2019, 12:16 AM
Rough Landing
Thanks for the plan. What size servos did you use?
Jul 01, 2019, 12:52 AM
flyin' fool
goldguy's Avatar
3.7 gram. Although any 5ish gram should work.
I thought it earned a few extra stripes after today's success. I also change the Velcro to accommodate 2S 520 packs as well.
Jul 01, 2019, 07:51 AM
Rough Landing
On the bottom of the plane, is that a single reinforcing strip running from nose to tip?
Jul 01, 2019, 08:45 AM
Rough Landing
Originally Posted by goldguy
From Corolina Pad, no paper, just paint on one side, it's called Ucreate Board. Bought it at a $$tore here.
Walmart sells this foam. 22x28 4 pack of sheets for around $3.
Correction, went to Walmart and it was poster board NOT foam board.
Jul 01, 2019, 09:12 AM
Sokol
JureZ's Avatar
took the liberty of adding two dimensions, please verify that it is correct.
corrected my root cord mistake
Jul 01, 2019, 09:15 AM
flyin' fool
goldguy's Avatar
One layer full length, one about 3" long to support the ply motor mount.
Jul 01, 2019, 09:18 AM
flyin' fool
goldguy's Avatar
……………. and a bit of tape.
Discussion Smoothies !!!!!!!!.......I just discovered these tasty delights.......yes i know.... rockyboy2 Life, The Universe, and Politics 18 Aug 26, 2017 10:03 PM
Discussion Just friggin' delightful dll932 Life, The Universe, and Politics 3 Feb 16, 2011 08:11 PM
Discussion Just another delta Edmonds Foamies (Scratchbuilt) 15 Feb 24, 2009 11:16 PM
Double Delta Day Delightful sr71fan Foamies (Kits) 4 Mar 29, 2005 07:42 AM
not just another walmart glider conversion.......DELTA!!!! corndog Foamies (Kits) 14 May 21, 2004 07:14 PM
