Jun 29, 2019, 05:11 AM
MGeo's Avatar
Mini-HowTo
Dshot ESC Protocol on STM32F4 using Arduino
After much studying of Betaflight code drivers, I've finally managed to get DMA based Dshot digital ESC protocol up and running on an STM32F411RE. This was a long journey for me to learn enough about STM32s and DMA transfers to get it working. So I'll post my minimum viable test code here in case others are searching for the same.
This demo was built and tested using this STM32 HAL based Arduino core https://github.com/stm32duino/Arduino_Core_STM32
Dshot is the digital interface protocol for electronic speed controllers now commonly found on higher performance quadcopters and multi-rotor drones. https://oscarliang.com/dshot/. This test demo was set up for Dshot600 timing.
Test output of 4 channels (TIM3 CCR1 and CCR2, TIM4 CCR1 and CCR2) was decoded with a Saleae logic probe and this protocol analyzer https://gitlab.com/tracernz/logic-dshot
The test code loads 4 separate dma buffers to store the individual TIMx channel CCRn bit values. Transfers are enabled in a timed loop, and disabled in each DMA stream transfer complete interrupt. Here is the minimum sketch that generated the output lower down in this post:
Code:
#include "stm32yyxx_ll.h"
#define USE_DSHOT
#define USE_DSHOT_DMAR
#define MAX_SUPPORTED_MOTORS 8
#define MOTOR_BIT_0           7
#define MOTOR_BIT_1           14
#define MOTOR_BITLENGTH       19
#define DSHOT_DMA_BUFFER_SIZE   18 /* resolution + frame reset (2us) */
uint32_t dmaBufferT3CH1[DSHOT_DMA_BUFFER_SIZE];
uint32_t dmaBufferT3CH2[DSHOT_DMA_BUFFER_SIZE];
uint32_t dmaBufferT4CH1[DSHOT_DMA_BUFFER_SIZE];
uint32_t dmaBufferT4CH2[DSHOT_DMA_BUFFER_SIZE];
// IO pin identification
// make sure that ioTag_t can't be assigned into IO_t without warning
typedef uint8_t ioTag_t;       // packet tag to specify IO pin
typedef void* IO_t;            // type specifying IO pin. Currently ioRec_t pointer, but this may change
typedef uint8_t ioConfig_t;  // packed IO configuration
// DEF_TIM(TIM3, CH1, PB4,  TIM_USE_MOTOR,  0, 0), // S1_OUT
// DEF_TIM(TIM3, CH2, PB5,  TIM_USE_MOTOR,  0, 0), // S2_OUT
// DEF_TIM(TIM4, CH1, PB6,  TIM_USE_MOTOR,  0, 0), // S3_OUT
// DEF_TIM(TIM4, CH2, PB7,  TIM_USE_MOTOR,  0, 0), // S4_OUT
int cnt = 0;
int32_t Timer1;
int32_t Timer2;
int32_t Timer3;
int32_t Timer4;
#define testLoop1_Pin PB6
#define testLoop1_Port GPIOB
#define testLoop1_PinNum LL_GPIO_PIN_6
#define testLoop2_Pin PB7
#define testLoop2_Port GPIOB
#define testLoop2_PinNum LL_GPIO_PIN_7
// STM32F411 Reference Manual RM0383 pp.170
extern "C" void DMA1_Stream0_IRQHandler(void) {
  //LL_GPIO_SetOutputPin(testLoop1_Port, testLoop1_PinNum);
  if (LL_DMA_IsActiveFlag_TC0(DMA1)) {
    LL_DMA_DisableStream(DMA1, LL_DMA_STREAM_0);
    LL_TIM_DisableDMAReq_CC1(TIM4);
    LL_DMA_ClearFlag_TC0(DMA1);
  //LL_GPIO_ResetOutputPin(testLoop1_Port, testLoop1_PinNum);
extern "C" void DMA1_Stream3_IRQHandler(void) {
  if (LL_DMA_IsActiveFlag_TC3(DMA1)) {
    LL_DMA_DisableStream(DMA1, LL_DMA_STREAM_3);
    LL_TIM_DisableDMAReq_CC2(TIM4);
    LL_DMA_ClearFlag_TC3(DMA1);
extern "C" void DMA1_Stream4_IRQHandler(void) {
  if (LL_DMA_IsActiveFlag_TC4(DMA1)) {
    LL_DMA_DisableStream(DMA1, LL_DMA_STREAM_4);
    LL_TIM_DisableDMAReq_CC1(TIM3);
    LL_DMA_ClearFlag_TC4(DMA1);
extern "C" void DMA1_Stream5_IRQHandler(void) {
  //LL_GPIO_SetOutputPin(testLoop2_Port, testLoop2_PinNum);
  if (LL_DMA_IsActiveFlag_TC5(DMA1)) {
    LL_DMA_DisableStream(DMA1, LL_DMA_STREAM_5);
    LL_TIM_DisableDMAReq_CC2(TIM3);
    LL_DMA_ClearFlag_TC5(DMA1);
  //LL_GPIO_ResetOutputPin(testLoop2_Port, testLoop2_PinNum);
void setup() {
  Serial.begin(115200);
  Serial.print("Initializing...");
  Serial.print(HAL_RCC_GetHCLKFreq());
  Serial.println();
  pinMode(LED_BUILTIN, OUTPUT);
  digitalWrite(LED_BUILTIN, HIGH);
  digitalWrite(LED_BUILTIN, LOW);
  DWT_Delay_Init();
  pwmDshotMotorHardwareConfig();
void loop() {
  uint16_t packet1, packet2, packet3, packet4;
  uint8_t bufferSize1, bufferSize2, bufferSize3, bufferSize4;
  packet1 = prepareDshotPacket( (cnt & 0b11111111111) , false);
  bufferSize1 = loadDmaBufferDshot((uint32_t *)dmaBufferT3CH1, 1, packet1);
  LL_DMA_SetDataLength(DMA1, LL_DMA_STREAM_4, bufferSize1);
  packet2 = prepareDshotPacket( ((cnt+1) & 0b11111111111) , false);
  bufferSize2 = loadDmaBufferDshot((uint32_t *)dmaBufferT3CH2, 1, packet2);
  LL_DMA_SetDataLength(DMA1, LL_DMA_STREAM_5, bufferSize2);
  packet3 = prepareDshotPacket( ((cnt+2) & 0b11111111111) , false);
  bufferSize3 = loadDmaBufferDshot((uint32_t *)dmaBufferT4CH1, 1, packet3);
  LL_DMA_SetDataLength(DMA1, LL_DMA_STREAM_0, bufferSize3);
  packet4 = prepareDshotPacket( ((cnt+3) & 0b11111111111) , false);
  bufferSize4 = loadDmaBufferDshot((uint32_t *)dmaBufferT4CH2, 1, packet4);
  LL_DMA_SetDataLength(DMA1, LL_DMA_STREAM_3, bufferSize4);
  LL_DMA_EnableStream(DMA1, LL_DMA_STREAM_4);
  LL_DMA_EnableStream(DMA1, LL_DMA_STREAM_5);
  LL_DMA_EnableStream(DMA1, LL_DMA_STREAM_0);
  LL_DMA_EnableStream(DMA1, LL_DMA_STREAM_3);
  //TIM_SetCounter(dmaMotorTimers[i].timer, 0);
  LL_TIM_SetCounter(TIM3, 0);
  LL_TIM_SetCounter(TIM4, 0);
  //TIM_DMACmd(dmaMotorTimers[i].timer, dmaMotorTimers[i].timerDmaSources, ENABLE);
  LL_TIM_EnableDMAReq_CC1(TIM3);
  LL_TIM_EnableDMAReq_CC2(TIM3);
  LL_TIM_EnableDMAReq_CC1(TIM4);
  LL_TIM_EnableDMAReq_CC2(TIM4);
  digitalWrite(LED_BUILTIN, HIGH);    // turn the LED on (HIGH is the voltage level)
  DWT_Delay_us(12);                   // wait for fraction of a second
  digitalWrite(LED_BUILTIN, LOW);     // turn the LED off by making the voltage LOW
  cnt++;
  if (cnt > 2047) {
    cnt = 0;
#define MHZ_TO_HZ(x) ((x) * 1000000)
#define MOTOR_DSHOT1200_HZ    MHZ_TO_HZ(24)
#define MOTOR_DSHOT600_HZ     MHZ_TO_HZ(12)
#define MOTOR_DSHOT300_HZ     MHZ_TO_HZ(6)
#define MOTOR_DSHOT150_HZ     MHZ_TO_HZ(3)
void pwmDshotMotorHardwareConfig(void) {
  LL_GPIO_InitTypeDef GPIO_InitStruct;
  // GPIO peripheral clock enable
  //LL_AHB1_GRP1_EnableClock(LL_AHB1_GRP1_PERIPH_GPIOA);
  LL_AHB1_GRP1_EnableClock(LL_AHB1_GRP1_PERIPH_GPIOB);
  // TIM3 GPIO Configuration
  GPIO_InitStruct.Pin = LL_GPIO_PIN_4 | LL_GPIO_PIN_5 | LL_GPIO_PIN_6 | LL_GPIO_PIN_7;
  GPIO_InitStruct.Mode = LL_GPIO_MODE_ALTERNATE;
  GPIO_InitStruct.Speed = LL_GPIO_SPEED_FREQ_LOW;
  GPIO_InitStruct.OutputType = LL_GPIO_OUTPUT_PUSHPULL;
  GPIO_InitStruct.Pull = LL_GPIO_PULL_NO;
  GPIO_InitStruct.Alternate = LL_GPIO_AF_2;
  LL_GPIO_Init(GPIOB, &GPIO_InitStruct);
  // TIM3 peripheral clock enable
  LL_APB1_GRP1_EnableClock(LL_APB1_GRP1_PERIPH_TIM3);
  LL_TIM_DisableCounter(TIM3);
  // TIM4 peripheral clock enable
  LL_APB1_GRP1_EnableClock(LL_APB1_GRP1_PERIPH_TIM4);
  LL_TIM_DisableCounter(TIM4);
  LL_TIM_InitTypeDef TIM_TimeBaseStructure;
  LL_TIM_StructInit(&TIM_TimeBaseStructure);
  TIM_TimeBaseStructure.Prescaler = (uint16_t)(((float) 100000000 / MOTOR_DSHOT600_HZ + 0.01f) - 1);
  TIM_TimeBaseStructure.Autoreload = MOTOR_BITLENGTH;
  TIM_TimeBaseStructure.ClockDivision = LL_TIM_CLOCKDIVISION_DIV1;
  TIM_TimeBaseStructure.RepetitionCounter = 0;
  TIM_TimeBaseStructure.CounterMode = LL_TIM_COUNTERMODE_UP;
  LL_TIM_Init(TIM3, &TIM_TimeBaseStructure);
  LL_TIM_Init(TIM4, &TIM_TimeBaseStructure);
  LL_TIM_OC_InitTypeDef TIM_OCInitStructure;
  LL_TIM_OC_StructInit(&TIM_OCInitStructure);
  TIM_OCInitStructure.OCMode = LL_TIM_OCMODE_PWM1;
  TIM_OCInitStructure.OCState = LL_TIM_OCSTATE_ENABLE;
  TIM_OCInitStructure.OCIdleState = LL_TIM_OCIDLESTATE_HIGH;
  TIM_OCInitStructure.OCPolarity =  LL_TIM_OCPOLARITY_HIGH;
  TIM_OCInitStructure.CompareValue = 0;
  // Init TIM3 and TIM4 output compare channels
  LL_TIM_OC_Init(TIM3, LL_TIM_CHANNEL_CH1, &TIM_OCInitStructure);
  LL_TIM_OC_Init(TIM3, LL_TIM_CHANNEL_CH2, &TIM_OCInitStructure);
  LL_TIM_OC_Init(TIM4, LL_TIM_CHANNEL_CH1, &TIM_OCInitStructure);
  LL_TIM_OC_Init(TIM4, LL_TIM_CHANNEL_CH2, &TIM_OCInitStructure);
  // TIM3 and TIM4 OC enable preload
  LL_TIM_OC_EnablePreload(TIM3, LL_TIM_CHANNEL_CH1);
  LL_TIM_OC_EnablePreload(TIM3, LL_TIM_CHANNEL_CH2);
  LL_TIM_OC_EnablePreload(TIM4, LL_TIM_CHANNEL_CH1);
  LL_TIM_OC_EnablePreload(TIM4, LL_TIM_CHANNEL_CH2);
  // TIM3 and TIM4 OC enable channel
  LL_TIM_CC_EnableChannel(TIM3, LL_TIM_CHANNEL_CH1);
  LL_TIM_CC_EnableChannel(TIM3, LL_TIM_CHANNEL_CH2);
  LL_TIM_CC_EnableChannel(TIM4, LL_TIM_CHANNEL_CH1);
  LL_TIM_CC_EnableChannel(TIM4, LL_TIM_CHANNEL_CH2);
  LL_TIM_EnableAllOutputs(TIM3);
  LL_TIM_EnableARRPreload(TIM3);
  LL_TIM_EnableCounter(TIM3);
  LL_TIM_EnableAllOutputs(TIM4);
  LL_TIM_EnableARRPreload(TIM4);
  LL_TIM_EnableCounter(TIM4);
  //---DMA-------------------------------------
  LL_DMA_DeInit(DMA1, LL_DMA_STREAM_4);
  LL_DMA_DeInit(DMA1, LL_DMA_STREAM_5);
  LL_DMA_DeInit(DMA1, LL_DMA_STREAM_0);
  LL_DMA_DeInit(DMA1, LL_DMA_STREAM_3);
  LL_DMA_InitTypeDef DMA_InitStructure;
  // DMA controller clock enable
  LL_AHB1_GRP1_EnableClock(LL_AHB1_GRP1_PERIPH_DMA1);
  NVIC_SetPriority(DMA1_Stream4_IRQn, NVIC_EncodePriority(NVIC_GetPriorityGrouping(),0, 0));
  NVIC_EnableIRQ(DMA1_Stream4_IRQn);
  NVIC_SetPriority(DMA1_Stream5_IRQn, NVIC_EncodePriority(NVIC_GetPriorityGrouping(),0, 0));
  NVIC_EnableIRQ(DMA1_Stream5_IRQn);
  NVIC_SetPriority(DMA1_Stream0_IRQn, NVIC_EncodePriority(NVIC_GetPriorityGrouping(),0, 0));
  NVIC_EnableIRQ(DMA1_Stream0_IRQn);
  NVIC_SetPriority(DMA1_Stream3_IRQn, NVIC_EncodePriority(NVIC_GetPriorityGrouping(),0, 0));
  NVIC_EnableIRQ(DMA1_Stream3_IRQn);
  //-DMA TIM3 CCR1-----------
  LL_DMA_StructInit(&DMA_InitStructure);
  DMA_InitStructure.Channel = LL_DMA_CHANNEL_5;
  DMA_InitStructure.MemoryOrM2MDstAddress = (uint32_t)dmaBufferT3CH1;
  DMA_InitStructure.Direction = LL_DMA_DIRECTION_MEMORY_TO_PERIPH;
  DMA_InitStructure.FIFOMode = LL_DMA_FIFOMODE_ENABLE;
  DMA_InitStructure.FIFOThreshold = LL_DMA_FIFOTHRESHOLD_1_4;
  DMA_InitStructure.MemBurst = LL_DMA_MBURST_SINGLE;
  DMA_InitStructure.PeriphBurst = LL_DMA_PBURST_SINGLE;
  DMA_InitStructure.PeriphOrM2MSrcAddress = (uint32_t)&TIM3->CCR1;
  DMA_InitStructure.NbData = DSHOT_DMA_BUFFER_SIZE;
  DMA_InitStructure.PeriphOrM2MSrcIncMode = LL_DMA_PERIPH_NOINCREMENT;
  DMA_InitStructure.MemoryOrM2MDstIncMode = LL_DMA_MEMORY_INCREMENT;
  DMA_InitStructure.PeriphOrM2MSrcDataSize = LL_DMA_PDATAALIGN_WORD;
  DMA_InitStructure.MemoryOrM2MDstDataSize = LL_DMA_MDATAALIGN_WORD;
  DMA_InitStructure.Mode = LL_DMA_MODE_NORMAL;
  DMA_InitStructure.Priority = LL_DMA_PRIORITY_HIGH;
  LL_DMA_Init(DMA1, LL_DMA_STREAM_4, &DMA_InitStructure);
  LL_DMA_EnableIT_TC(DMA1, LL_DMA_STREAM_4);
  //-DMA TIM3 CCR2-----------
  DMA_InitStructure.MemoryOrM2MDstAddress = (uint32_t)dmaBufferT3CH2;
  DMA_InitStructure.PeriphOrM2MSrcAddress = (uint32_t)&TIM3->CCR2;
  LL_DMA_Init(DMA1, LL_DMA_STREAM_5, &DMA_InitStructure);
  LL_DMA_EnableIT_TC(DMA1, LL_DMA_STREAM_5);
  //-DMA TIM4 CCR1-----------
  DMA_InitStructure.Channel = LL_DMA_CHANNEL_2;
  DMA_InitStructure.MemoryOrM2MDstAddress = (uint32_t)dmaBufferT4CH1;
  DMA_InitStructure.PeriphOrM2MSrcAddress = (uint32_t)&TIM4->CCR1;
  LL_DMA_Init(DMA1, LL_DMA_STREAM_0, &DMA_InitStructure);
  LL_DMA_EnableIT_TC(DMA1, LL_DMA_STREAM_0);
  //-DMA TIM4 CCR2-----------
  DMA_InitStructure.MemoryOrM2MDstAddress = (uint32_t)dmaBufferT4CH2;
  DMA_InitStructure.PeriphOrM2MSrcAddress = (uint32_t)&TIM4->CCR2;
  LL_DMA_Init(DMA1, LL_DMA_STREAM_3, &DMA_InitStructure);
  LL_DMA_EnableIT_TC(DMA1, LL_DMA_STREAM_3);
uint16_t prepareDshotPacket(uint16_t value, bool requestTelemetry) {
  uint16_t packet = (value << 1) | (requestTelemetry ? 1 : 0);
  requestTelemetry = false;    // reset telemetry request to make sure it's triggered only once in a row
  // compute checksum
  int csum = 0;
  int csum_data = packet;
  for (int i = 0; i < 3; i++) {
    csum ^=  csum_data;   // xor data by nibbles
    csum_data >>= 4;
  csum &= 0xf;
  // append checksum
  packet = (packet << 4) | csum;
  return packet;
static uint8_t loadDmaBufferDshot(uint32_t *dmaBuffer, int stride, uint16_t packet) {
  for (int i = 0; i < 16; i++) {
    dmaBuffer[i * stride] = (packet & 0x8000) ? MOTOR_BIT_1 : MOTOR_BIT_0;  // MSB first
    packet <<= 1;
  return DSHOT_DMA_BUFFER_SIZE;
Jul 12, 2019, 05:31 PM
MGeo's Avatar
Test setup pic below.
Discussion DJI NAZA/Phantom/A2 CAN bus communication protocol - NazaCanDecoder Arduino library pawelsky Multirotor Drone Electronics 883 Apr 14, 2020 08:41 AM
Discussion DJI NAZA GPS communication protocol - NazaDecoder Arduino library pawelsky Multirotor Drone Electronics 430 Oct 01, 2019 08:37 AM
New Product Dshot - Digital Protocol for Flyduino KISS FCs and ESCs flyduino Multirotor Drone Electronics 400 Jan 16, 2018 08:11 PM
Discussion Note on ESC Inputs (Using Arduino) lordvon Power Systems 2 May 22, 2016 10:51 PM
Poll How often does the used transmitter protocol swing your decision on what to get next? SoloProFan Mini Multirotor Drones 7 Nov 03, 2015 10:41 AM
