This thread is privately moderated by Bella Liu, who may elect to delete unwanted replies.
Jun 28, 2019, 02:05 AM
New Product
ToolkitRC M8 300W 15A Battery Charger, Cell Checker, Servo Tester, Receiver Tester&DC
If you are trying to find all in one with 300W 15A Battery Charger, Cell Checker, Servo Tester, Receiver Tester&DC, here it is !!!
Features
Battery Charger
Cell Checker
Servo Tester
PWM,PPM.SBUS Input/output Receiver & Flight control tester
Viable AMp/volt DC Power supply (Required external DC input)
* be prepared to update the charger as needed to always have the newest features
Specifications
General
Charge, discharge and balance management support LiPo, LiHV, LiFe 1-8S,NiMh 1-20S,PB 1-12S battery.
Charger current:MAX 15A @ 300W
Discharge current:reccycle mode 15A @ 300W Normal: 3A @ 20W
Balance current: 400mA @ 2-8S
Lithium battery cut-off voltage can be set (TVC function)
Measure battery voltage, internal resistance, balance
ESC power meter, together with output voltage and throttle signal
Measure PWM / PPM / xBUS signal values, Accuracy 1ms
Output PWM / PPM / xBUS standard signal, Accuracy 1ms
Customizable 5-30V constant voltage, 1-15A constant current
Charge the drone battery, activate and charge.
Multi-language optional
USB [email protected] Output,for Mobile devices
Udisk firmware upgrade (Slave device)
Charger
Input voltage: 7.0-30.0V @MAX 16A
Type of battery: LiPo/LiHV/LiFe @1-8S, NiMh @1-20S, Pb @1-10S
Balance current: 400mA @2-8S
Charge power: 300W @MAX 15A
Discharge power: 300W @MAX 15A Recycle mode, 12W @ 3A Normal
USB: 2.1A @5.0V or Upgrade
Dimensions: 98x68x35mm
Weight: 142g
LCD: 2.2" 132x64 Pixel,Black and White
Measurement
PWM: 880-2200us @20-400Hz
PPM: 880-2200us*8CH @20-50Hz
SBUS: 880-2200us*16CH @20-100Hz
Voltage: 1.0-5.0V @1-8S
IR: 10-500mR @1-8S
ESC: 300W @Max 15A
Output
Power: 1.0-30.0V @1.0-15A Mode:CC+CV
OverCurrent Cut Off time: 50ms
You can find it here:
Web: www.dtn-tech.com
Email:[email protected]
Tel: +86-15818289223
Datton Electronic Tech. Co.,Ltd
New Product ToolkitRC M8 - Smart 300W Pocket DC Charger kremerFPV Batteries and Chargers 374 Oct 14, 2019 10:46 AM
New Product The sample test: ToolkitRC M8 DC 300W 15A Battery Balance Charger Discharger for 2-8S BG-Wilson Batteries and Chargers 29 Sep 15, 2019 03:28 PM
