Sep 15, 2019, 05:32 PM
Lithium Member
Herb's Avatar
Thanks guys
Sep 15, 2019, 10:56 PM
Classic jets rule
AIR SALLY's Avatar
Looks awesome Herb .....of course all your planes look like works of art.
Sep 17, 2019, 12:22 PM
Lithium Member
Herb's Avatar
Thanks Rodger
Might try the FMS 90mm inrunner fan in this one at some point ...
https://www.rcgroups.com/forums/show...0#post42571271
Sep 17, 2019, 12:25 PM
Lithium Member
Herb's Avatar
A few more pics of the He-162 at the field,
Sep 17, 2019, 12:32 PM
Lithium Member
Herb's Avatar
The He-162 is still a work in progress regarding it's flight characteristics
* After six good flights I settled on a throttle-to-elevator mix of ~4%
* Flap-to-elevator mix is up to 9% (it needs quite a bit of down elevator when the flaps are deployed)
* CG moved back a couple of mm, will try some more at some point.
Visibility is still a bit of an issue turning on final, might need a yellow ring on the intake.
Still working on a better way to secure the battery ... and re-balance the fan, I think the green epoxy factory weight inside the rotor must have flown off.
Sep 17, 2019, 12:45 PM
juanjulian's Avatar
Fan to noisy but pod could be working like a resonance box.
Glue some foam squares to it to absorb sound vobrations.
Nice paint job.
Pro Hoarder
turbonut's Avatar
You have done a great job ..And RBC ..it looks super!
The fan is most likely not getting clean air..it would be pretty turbulent coming off the canopy
Latest blog entry: In flight
Sep 17, 2019, 01:59 PM
Lithium Member
Herb's Avatar
Thanks ! Yes RBC did a great job on this one ...
Yes dirty turbulent air could also be an issue, but I think on this one the spun aluminum spinner for some reason is not centered on the rotor, even tried different WeMo spinners. Next flights w/o spinner. Overall the noise does decrease though when it picks up speed
Regarding resonances, yes that's also an issue since both the lightweight hollow pod and the hollow fuse resonate, my nacelle is already stuffed full with cotton balls ...
Sep 19, 2019, 11:27 AM
Lithium Member
Herb's Avatar
After five flights, it was time to improve on the battery tray setup ... was not sure initially if my current batts would give a sensible CG.
Now with the additional velcro strap it should be a lot more secure (first flights were all more or less flying ovals & fine tune the mixes ).
Sep 19, 2019, 11:34 AM
Lithium Member
Herb's Avatar
The RBC plan gives a CG of ~58mm ... Re-calculating it here for the RBC kit gives a range of 45mm to 65mm ... The Neutral Point (NP) is computed at ~94mm.
The RBC plan CG worked well for the maiden (with plenty of elevator throw, just in case), but I think it can go back a few mm's.
Sep 19, 2019, 11:41 AM
Lithium Member
Herb's Avatar
Here is a less than perfect (scratch built) Heinkel He-162 maiden
glattCAD He-162 M1/4, EDF Prototype: First and final Flight (0 min 19 sec)
Sep 19, 2019, 11:54 AM
Lynxman's Avatar
58mm on the 1100 mm RBC size model puts the CG at the same spot as the CG I calculated for my 1:4,5 scale 1580 mm He-162 (83 mm CG). The landing gear moves the cg a few mm, so I balance mine within a few mm of that spot with gear both up and down.
I designed it with the efflux pointing up 2, which eliminated throttle/pitch coupling.
My He-162 in flight
Sep 19, 2019, 12:06 PM
Lithium Member
Herb's Avatar
Some minor cockpit work, just to dress it up a bit ... The pilot is a VQ model one I had lying around.
Sep 24, 2019, 12:07 AM
Lithium Member
Herb's Avatar
Simple mylar wipes installed on all the surfaces, to close the hinge gap on the bottom, from the top live hinge (used special hinge gap tape a few years ago),
Sep 24, 2019, 12:20 AM
Lithium Member
Herb's Avatar
A couple of frames taken from the new video Unfortunately my good camera man has not been around (yet) ...
New Product second Heinkel He-162 Salamander pulsery2k1 Foamy EDFs 2 Nov 23, 2008 02:48 PM
New Product Andy Chen: Any news on your Heinkel He 162 Salamander EDF? Smokescreen38 Foamy EDFs 34 Sep 29, 2008 01:26 PM
Discussion Kavan Heinkel He-162 Salamander Fallout Electric Plane Talk 15 Apr 11, 2007 08:39 AM
Electric Jet Factory Heinkel He-162 Salamander The Max-Q Electric Ducted Fan Jet Talk 13 Apr 01, 2007 11:02 AM
Heinkel He-162 Salamander?? spitfirem9 Electric Ducted Fan Jet Talk 3 Nov 04, 2005 06:25 PM
