Jun 27, 2019, 05:34 AM
3D-printed Honda HA-420 HondaJet
Hi guys! I just want to share with your my new work.
The client set a difficult task for me: to create a meter-wide model of the Honda HA-420 HondaJet for the sales office. To do this, I had scanned a small original metal model from the HONDA factory. Thus, I had obtained a 3D model in order to increase it proportionally and create a meter-wide model. I had printed parts of the final model on the 3D printer Hercules Strong 2017 and Picaso Designer X. For this I used ABS plastic from REC. I had processed all the seams on the model with solvents and stitched it up with a Myriwell RP100B 3D pen. After that, I processed the model with sandpaper and painted.
Also during the process we put a complete wiring system into the model.
I made a stand for the model on a SolidCraft CNC-6090 milling machine using 25 mm MDF, and then painted it.
What do you think about my work? Any comments?
Jun 27, 2019, 05:43 AM
atreis's Avatar
Beautiful work. I've always liked the look of the Honda jets.
Jun 27, 2019, 12:08 PM
rajazo's Avatar
Impressive model. The finish is spectacular , shines like a piano!
One question... did you make any post process at the scanned 3d model? If not , what is the 3d scanner that you use?
Jun 27, 2019, 01:05 PM
Team of ONE....or...Team Me
DeadTom's Avatar
Very beautiful work, the model shines like a diamond.
Jun 27, 2019, 03:38 PM
Lynxman's Avatar
Nice model. It would be cool to make it a flyable printable plane.
Jun 27, 2019, 04:13 PM
Khan's Avatar
Awesome work ! You can be proud of it !
Is that your regular line of work ? Do you have other projects like this ?
That metal model, was it the wind tunnel mock-up ?
Jul 11, 2019, 09:17 AM
Thanks a lot! Me too!
Jul 11, 2019, 09:19 AM
Hi! I scanned the model with a RangeVision PRO 5M 3D scanner, then scaled and prepared for printing a digital model in Simplify3D.
Jul 11, 2019, 09:21 AM
Thanks!
Jul 11, 2019, 09:24 AM
Found two scans
Discussion Honda Ha-420 Jet FlyBoyTha1 Pusher Prop Jet Models 2 Jan 20, 2015 05:06 PM
Discussion Honda/jet-HA-420 panolaboy Scale Kit/Scratch Built 10 Jan 20, 2015 05:06 PM
Discussion Nitro Planes Honda HA-420 Jet 3rd Flight FlyBoyTha1 Pusher Prop Jet Models 4 Dec 24, 2008 10:42 PM
