Aug 01, 2019, 03:26 AM
Hi Csizpeti
I'm familiar with this VTX. I'd message Bonafidepirate and HelloNello and get their thoughts on this particular unit.
I've personally used the following with the FC and had no problems.
RMRC - 1.3GHz 200mW Transmitter - INTL VERSION
RMRC - 1.3GHz 400mW Transmitter - INTL VERSION
Perhaps huahuaFPV can shed some light on this alternate version of the FC with 12V?
Cheers
Jase
Aug 01, 2019, 03:33 AM
Thanks Jase,
I guess the 12v out is exsiting on mine too, only the wire lead is missing, so If somebody can tell me how can I install an additional wire, that would be perfect.
Originally Posted by jwtfpv
Hi Csizpeti
Cheers
Jase
Aug 01, 2019, 05:13 AM
Help!
My unit text is in Chinese so I'm having great trouble setting it up in my Z84.
When it's powered up I get 4 options (Ithink?) but of course I don't understand them
When the 3 position switch is toggled I get a screen showing the channels and figures representing the range of each channel I'm using.
When the switch is toggled further I can see Chinese txt changing above but obviously I can't understand it
Further toggling brings me back to the OSD which is showing a choice of only two selectable flight modes of which one is MANUAL mode and the other is a stabilized mode of some sort ??
Also when the throttle is applied it isn't proportional just 0-max?
I obviously need to hook up to my PC , download the latest firmware and load it to the FC to hopefully change the language , only this is where I always have trouble
Sorry for being so thick but unfortunately I don't have any I.T experts around here to ask advice from
Aug 01, 2019, 05:20 AM
P.s
I meant to say- Could someone consider uploading a nice , clear set up video to YouTube to enable folk such as myself who lack computer know how, to get this fantastic looking system up and working-PLEASE
I'm sure it'll help boost sales too
Aug 01, 2019, 06:17 AM
Hi Csizpeti
Have you considered using a Low Dropout Linear Regulator to power your VTX?
LM2940CT-12
Cheers
Jase
Aug 01, 2019, 06:27 AM
Hi drambuidhe
Let's start at the beginning.
  1. Connect the flight controller up as per the Quick Start Guide (#1 Files).
  2. Connect flight battery.
  3. Check monitor for start up screen to determine firmware version (will only appear for approximately five seconds).
Cheers
Jase
Aug 01, 2019, 06:34 AM
Hi,
Thanks, most probably this will solve my issue!
THANKS
Peter
Hi Csizpeti
LM2940CT-12
Cheers
Jase
Aug 01, 2019, 08:36 AM
HI
you can updata new version V6.0
Download upgrade software and drivers and install:install CP210x USB to UART Bridge driver.
https://github.com/HelloLeFei/SN_L/releases
Connect via USB:Select correct com ID.
Upgrade SN_L
Step1: power off FC at first
Step2: load firmware and flash,
Step3: Before the end of the countdown, power on FC
tomorrow, I will upload a video to youtube
Aug 01, 2019, 08:44 AM
Hi drambuidhe
Cheers
Jase
you are very nice, thankyou for your Quick Start Guide
Aug 01, 2019, 04:28 PM
No problem.
Aug 02, 2019, 12:08 AM
RocketMouse's Avatar
yes , I am one of the members
Hi!
This looks like very nice AP! But do you plan to make AAT for bigger 1.2 antennas? And preferably 360 one, not 180?
Can be current aat adopted to work with 360 Diy rotation mechanism?
Aug 02, 2019, 12:14 AM
Originally Posted by RocketMouse
Hi!
only support 180-270 servo.
Aug 02, 2019, 12:16 AM
upgrade Tutorial about SNL
HI
This is an upgrade tutorial!!!!
Aug 02, 2019, 12:20 AM
I see.
And what about a bigger one?
Aug 02, 2019, 12:25 AM
I see.
There is no plan yet, I think the 17DB antenna is OK
Discussion SN Sparrow Flight Controller ralfrcgroups FPV Equipment 95 Aug 27, 2019 03:47 AM
