Jun 25, 2019, 06:54 PM
New Product
Exceed RC Rock Climbing Truck 1/10 Scale Max Volt 4WD Electric Remote Control RTR
1/10 Exceed RC Max Volt Crawler 4WD Truck Overview (2 min 26 sec)
https://www.nitrorcx.com/51c923-maxv...truck-red.html
NitroRCX has entered the scale RC market with the 1/10th Max Volt. It features scale wheels, tires and an a truck-inspired body. Not only is it a good looking crawler but it's also built to perform. It'll come with a proportional 2.4GHz radio system with throttle and steering control.
The radio features a pistol-grip design with 2 channel functionality, servo reversing, steering and throttle dual rates, steering and throttle exponential adjustments, and even channel mixing. The radio prevents frequency conflicts automatically and changes channels if there is any interference. You'll have professional-level control in one easy ready to run package.
Equiped with a full-time 4X4 drivetrain with fully locked differentials ensuring maximum traction and reliability to get over the roughest of terrain. The multi-link independent suspension allows you to setup the crawler how you like it and comes with oil-filled composite shocks. The powerful 540-size motor and ESC provides smooth control at all speeds Features an anodized C channel ladder chassis frame and rock sliders to add to it's scale look.
The waterproof electronics will handle all-weather and all-terrain that you throw at them. Features full ball-bearing to minimize drag and power lost and features 12mm hex wheel hubs allowing you to change out the wheels and tires if you wish to. Comes with a high-torque, metal-geared steering servo for precision maneuverability. A 7.2V 2000mAh Ni-MH battery and charger included in the package and all you need to provide is AA batteries for the transmitter.
Spec:
Length: 505mm
Width: 228mm
Height: 245mm
Wheelbase:313-315mm
Wheel Track: 192mm
Wheels: 118*45mm
Gear Ratio: 1:37
Servo: 15KG
Motor: RC540-8020
ESC: HW40A
Battery: Ni-MH 7.2V 2000mAh
Radio System: 2.4G
Weight:2.9KG
Waterproof ESC/Servo/Receiver
Package Include:
7.2V 2000mAh Ni-MH Rechargeable Battery
Wall Battery Charger
2.4Ghz Pistol Grip Radio Remote Controller Transmitter
Instruction Manual
Required to run
4x AA batteries
Note: 2 to 3s lipo capable (changing jumper is required)
