Jun 24, 2019, 07:52 PM
Smyk's Avatar
Taranis X9E
Any one installed Jim's Module in tray Taranis X9E
MPX Evo module should work
MPX M- Link works I believe
Jun 24, 2019, 08:32 PM
Doesn't the X9E have a JR module port?
Jun 25, 2019, 06:04 AM
Looking at an image of the back of the transmitter at Aloft Hobbies, it looks like it does not have a module bay....
Jun 25, 2019, 11:50 AM
Copy & Paste from item description ......
Are you heavily invested in another RF system? No worries, the Taranis E actually has a normal JR style module built inside that will accept modules for other transmitting protocols. In the model setup you simply tell the system if you are using the module bay, and shut down the internal FrSky module. Now you can use your Futaba, Spektrum, JR, and other receivers if you have a transmitter module that fits in a JR style module bay. (Note, you will need to remove the antenna from the module and screw on an antenna pigtail to mount the module antenna outside of the radio case.
Jun 25, 2019, 10:29 PM
Thanks for that info! I thought it was a standard JR module used in all of the FrSky transmitters.
Discussion Frsky Taranis x9e vs x9d plus Rcnewbie89 Radios 6 May 31, 2016 04:37 PM
Question How do I get a Taranis X9E to display telemetry from a Pixhawk? Oldgazer Radios 8 May 26, 2016 06:57 PM
Discussion FrSky Taranis X9E Transmitter looks like antique lolsunny Multirotor Drone Talk 4 Oct 12, 2015 03:50 AM
Discussion FrSky X9E - Tray Radio - Taranis Rotozuk Radios 1245 Aug 20, 2015 12:21 PM
