This thread is privately moderated by UnknownForces RC, who may elect to delete unwanted replies.
Jun 24, 2019, 03:05 AM
Growler X1 1/6 2WD electric desert buggy(8s)
Growler X1 1/6 2WD electric desert buggy(8s) (0 min 34 sec)
Features:
1. A Pivoted and movable front shock mount. By minimizing interference with suspensing arms, and maximizing Shock travel , this design greatly improve the handling capability on rough terrace, at the same time improve tractions by always applying pressure on both wheels.
2. With a “C” shape shock stay base design, combine with the roll-cage and chassis kick-up angle, it forms a close loop which greatly improve structural crash absorbing capability, the elastic structure can reduce the chance of deforming upon front-end crashes.
3. The front towing loop together with the front bumper provide an effective initial collapsing area, greatly reduce the chances of damaging the front part of the chassis upon crashes.
4. Steering posts are designed to seperate with the front end kick-up plate, minimizing the damage of the steering components upon front-end crashes.
5. Lay-down steering servo design offer better torque efficiency, minimize power and range lost.
6. Motor heat-sink made from cold-extrusion materials, provides greater flexibility on machining, hence a 100% increase in size compare with older generation’s heat sink.
7. Re-position of the motor cooling fan . This new locations maximize air-flow hence improve cooling efficiency in general , at the same time reduce the risk of debris damaging the fan blade.
8. Quick-release thread-less hex wheel adapter. Eliminating damage to threads causing difficulties of wheel removing.
9. With a U-shape design chassis, the structural strength are much stronger, at the same time protect the batteries box from side impact.
10. Full roll-cage design, greatly improve protection and durability.
11. The realistic “Luggage carrier”on top of our roll-cage provide additional protection on a roll-over. It will acts as a carrier handle when carrying your buggy.
12. The roll-cage provide mounting area for montion cameras, sounds simulator, additional electric equipments boxes or light control boxes etc. Holes are pre-drill makes fitting these additional equipments a bliss.
13. Scale authentic lights system, make night-driving a lot more enjoyable.
14. Fully enclosed receiver box, provide better protection towards water and muddy conditions. With a transparent viewing windows underneath to aid routine maintenance work.
15. Fully enclosed with reinforcement strip batteries box. Improve structural strength and offer additional protection to your valuable batteries.
16. Leading-edge crash protection design: Suspension arms.
Specifiction:
Wheelbase : 480mm
Front Tire Track :395mm
Rear Tire Track : 395mm
Distance From the Ground :70mm
Roller Weight: Around 11kg(without electronic)
Max Speed:90KM
Max External dimension: L730*W440*H290 (include spare wheel and tow hook)
Accessories:
ESC :200A (ZTW PRO 200A /HOBBYWING MAX5 200A)
Brushless motor (standard) : 5.5kw 680KV(designed by our company and OEM by well-known motormaker )
Battery: Battery in series , max capacity 16000mAh)
Servo: Compatible 1:5 rc car(insert holes : 17.5mm*75mm)
Radio: 3rd channel (Noble NB4, remote control distance 500M )
Gyro: Suggest use gyro with radio
Wheel: Universal BAJA 5B full series tires
(front wheel :170mm*60mm, rear wheel: 170mm*80mm, 6 angle coupling: 24mm)
