Sep 09, 2019, 11:14 AM
Steve Merrill's Avatar
I started the wing yesterday, as I need to purchase some nyrod material before finishing the fuse.
Here's my question: Should I build in some washout on the wing? This is a pattern plane, and I want it to fly as such. I build in washout in almost all of my planes, not sure if I should on this build. what do you guys think?
Sep 09, 2019, 11:19 AM
Wanted for breaking Ohm's Law
Dennis Sumner's Avatar
Steve,
I would think it will be fine to build stock. When I built my New Era III a few years ago, I built stock and it flies nice.
Latest blog entry: RC Throw Gauge
Sep 09, 2019, 11:43 AM
A man with a plan
Balsaworkbench's Avatar
How do you fly your pattern planes? Do you do a fair amount of inverted flying?
Sep 09, 2019, 12:38 PM
Thanks Denny. That's what I'm thinking as well.
Balsa- Not really then much inverted...
Sep 09, 2019, 01:01 PM
A man with a plan
I don't think washout would do any harm if you don't fly inverted much.
Sep 09, 2019, 04:15 PM
Pro Hoarder
turbonut's Avatar
It a big straight wing with lots of lift..You wont need washout
Latest blog entry: In flight
Sep 11, 2019, 03:10 PM
And You're Not
Yeah, I ran a piped 40 in this 20 sized plane, standard servos were all we had back then, so I'm sure it was a bit on the heavy side for this airframe. Built them both stock, never had any issues.
Sep 11, 2019, 04:44 PM
Thanks guys. Stock it is. Hereís some pics. Slow going because I cut out all ribs on my Dremel jig saw, than sand to shape on my Delta disc sander. Each rib is different size. But iím in no hurry
Sep 11, 2019, 07:23 PM
slow_flier's Avatar
Looks good so far Steve.
It's always been my practice to build the first attempt at the model as designed. Later versions may incorporate changes as practice requires. There have only been a couple of cases where I've built the same plane twice and the changes were usually minimal.
The most dramatic I can think of was an RCM Trainer 60 where I added 1" to the fuel tank compartment and took out the dihedral. The resulting model flew well and I used it in club pattern contests.
Tom K
Sep 22, 2019, 11:43 AM
Wing progress. After sheeting the top, I removed the tabs on the ribs to sheet the bottom with 1/16th sheeting. My first attempt warped the TE because I used 3 shims under TE spaced about 6 inches apart. So I tore off the TE sheeting and this time used a long piece of 1/2Ēbalsa the full length of wing. Much better.
Sep 29, 2019, 11:33 AM
Glueing the wing panels together. 1 1/4Ē each tip. Per plans. Sanding jig I made to get the angle correct
Sep 29, 2019, 01:34 PM
Nice progress.
Always interested to learn how different builders attack and solve building problems. Nice sanding tool....
Sep 29, 2019, 02:03 PM
Dennis, it works, but I think it would work better if the sandpaper moved, not the wing. Will have to modify, make some sort of track for the sanding block to ride back and forth
Just got done gluing up the wing with 30min epoxy. Now to let it cure and watch the Bears
Sep 29, 2019, 05:45 PM
First mock ups are important
Oct 13, 2019, 02:53 PM
Update..... got the wing joined and glassed. Added aileron torque rods and forgot about them when I added the wing bolt block in the fuse....itís been a awhile since I had a one servo wing. Will need to relieve
Discussion Hammer .20 toad007 Classic Pattern Flying 35 Nov 24, 2017 06:29 PM
Discussion The Hammer .60 size OR Hammer .20 bacplus Classic Pattern Flying 11 Jun 23, 2016 06:05 PM
Alert End of Year Sale, IQ Hammer Turbines - Vogelsang Aeroscale MattyMatt2 Jet Turbines 0 Nov 11, 2015 11:21 PM
Video hammer V3 mini 5" Sixchannel Multirotor Drone Talk 0 Sep 13, 2015 11:41 AM
Discussion Davey Systems Hammers (20 & 40) HHK Sport Planes 9 Jul 27, 2009 09:44 PM
