Jun 20, 2019, 07:37 PM
I'm a pilot, 100 yrs too late
Thermalin's Avatar
Question
Small Z-Bends Needed
I have a pair of standard size Z - Bend pliers for the normal plastic\resin control horns but need smaller Sized Z's for a park type flier with thin ply control horns. What'st the best way to do this?
I've got needle nose type pliers the nose on those is to thick.
I have hemostats that while thinner in the nose aren't strong enough to hold during the bend.
I tried putting them in the vise but things get cumbersome real fast.
There must be a way to do this out there or I may just resort to these, but I dont know the diameter of the wire in the kit. I may just order a pack of each .32, .47, .62
http://www.dubro.com/collections/con...z-link-for-062
Jun 20, 2019, 07:49 PM
IMO ( In My Opinion ) →
balsa or carbon's Avatar
E/Z links are great for control horns , E/Z connectors are great for servo arms .
https://www.dubro.com/collections/co...-e-z-connector
Dubro has larger sizes .
Jun 20, 2019, 07:55 PM
Thermalin's Avatar
ok... so I'll go with what I thought...
Anything i need to do to keep that pressured fit screw from coming loose against the pushrod on the EZ Connector
Jun 20, 2019, 08:15 PM
Build, crash...repeat
AleRRon's Avatar
The EZ links work great for thin wire pushrods. The EZ Connectors don’t come loose but if you’re worried I guess you can use a little threadlocker.
Jun 20, 2019, 08:17 PM
You can use some thread lock on the screw on top if you want . The nylon snap washer or metal push-on washer on the bottom stays on well ..... in normal use : there's really no force that will pull them off .
Jun 20, 2019, 10:39 PM
treefinder
springer's Avatar
You can make a "modified Z bend" as tight as you want:
(2 min 29 sec)
Jun 20, 2019, 11:13 PM
flyin' fool
goldguy's Avatar
Or …………….. https://www.google.ca/search?source=...=1561090331303
Jun 21, 2019, 08:58 AM
Retired CAD guy
birdofplay's Avatar
Search the net using ...
Z-Bend Pliers
Jun 21, 2019, 06:17 PM
OR ?? Use bamboo toothpicks as control horns and Heat shrink tubing as the connector hinge. No more need for difficult bends
Jun 21, 2019, 08:56 PM
Thermalin's Avatar
Ahhh this second video is what I had seen before but forgotten how to do...
Thanks!
Thermalin's Avatar
I don't think that will hold up on the Polaris... apparently she moves at approx 60 wot though I plan to not fly that fast.
Jun 21, 2019, 08:57 PM
Thermalin's Avatar
Originally Posted by goldguy
Thanks for this one too !
Jun 23, 2019, 06:02 AM
gpw
gpw
“There’s no place like Foam”
gpw's Avatar
Springer , thanks , we’ve used that method for many years now and never had a failure … some planes very fast …
Latest blog entry: Lost plans
Jun 23, 2019, 08:23 AM
treefinder
springer's Avatar
I probably learned it from you! So many guys asked about it, and it is way easier to show than tell, figured the vid was worth it.
Jun 23, 2019, 09:22 AM
pull up -- PULL UP!!!
It's not obvious to me that the tool makes a better bend than needle nose pliers. And is just another thing for me to lose track of. And doesn't make a particularly narrow bend so not sure it's applicable to the OPs request. But it is kinda neat.
I've seen the side-bend Z before but never saw much need for it. But I hadn't thought it through. I usually use Z on one end and EZ on the other, but the other day I wanted to remove a pushrod only to realize it was trapped by a guide, the servo was recessed, and I couldn't remove the rod without tearing something up.
Occurs to me a double side-bend Z would release both ends without removing or disengaging the guide. Would probably be most reliable if I made them mirror image. Bend CW to disengage one end and CCW to disengage the other. Have to give that a try.
Discussion Z-bend & L-bend samwei1950 Electric Plane Talk 7 Feb 08, 2014 11:11 PM
Discussion Ways to make small z-bends gemmy876 Indoor Pattern/F3P 13 Sep 30, 2008 02:54 PM
Question Making small Z bends PGR The Builders Workshop 13 Nov 13, 2004 02:33 PM
E-Z Connectors or Z-Bends on Ascent ??? Cal Electric Sailplanes 5 Oct 31, 2004 12:45 AM
Which do you prefer, E-Z connectors or z-bends ??? Cal Parkflyers 26 Oct 21, 2004 04:00 PM
