Jun 28, 2019, 02:05 AM
Low budget fun
Beaver_XT's Avatar
My pleasure. Hit me up again if you have any further questions.
Jul 06, 2019, 05:46 PM
Hey Beaver,
So I have installed the Kyosho front oneway differential and PN Racing swing arms (with Kyosho stock bearings). The install seemed to go fine but now it has broken in, I have an issue. The front right side works perfectly, but the front left side doesnít. The front left side stops at the same time as the rear tires, but the right side will still roll. Something is wrong, but I donít know if itís the swing arm, or one of the bearings?
I want to have a game plan before I take the car apart again, but I donít know what I should be looking for? Any tips are appreciated.
Sent from my iPhone using Tapatalk
Jul 07, 2019, 01:28 AM
Low budget fun
Beaver_XT's Avatar
It's common for both wheels to not stop at the same time but at least they should roll forward.
Check wheel tightness first. The you can drop some oil in to the swing arm joint, clean it before putting it back. And drop some oil in to one way tube too.
Jul 07, 2019, 11:04 AM
I made sure to drop some lube in the oneway diff. tube and made sure the bearings were cleaned and oiled prior to installing. I did notice that one of the swing arms was a little stiff, it did not want to rotate freely in its socket. I tried to oil the swing arm joint but it did not make much of a difference. Do you think a stiff swing arm would hinder the the wheel rotation?
Should I order a new set of swing arms, or do you think the the current arm will break in over time and start to move freely?
Jul 07, 2019, 02:17 PM
Low budget fun
Beaver_XT's Avatar
Stiff swing arm can cause the wheel to not spin freely and shake but if you oiled it then it should be free enough to spin.
Try moving the one way by hand and see if there's any difference between 2 sides.
Jul 08, 2019, 03:00 PM
Hey Beaver,
There is definitely a difference between the two sides when rotating by hand. The left side feels like it has some resistance, where as the right side will spin freely. I have tried to loosen the wheel nuts, but that did not make a difference.
I am thinking I will switch the front swing arms with my rear swing arms, since I have a solid rear axel. It shouldnít matter since the rear solid axel will make the two rear swing arms & tires rotate at the same rate right? Or is there something I am missing?
Jul 09, 2019, 01:09 AM
Low budget fun
Beaver_XT's Avatar
Exactly what you thought. Stiff arm won't matter at the rear.
Jul 09, 2019, 12:56 PM
Thanks again man, I really appreciate you taking the time to reply! It has been extremely helpful to bounce my ideas off you, it gives me some piece of mind that you agree since I have very little experience with RC. This is the first time I have ever upgraded a car myself.
I will switch the swing arms, front and back, and report back with my results.
Jul 21, 2019, 04:21 PM
Success! I got the oneway differential working and Iím still using the original set of PN swing arms. Turns out I just needed to clean the swing arms and reoil everything. The stiff swing arm seems to have worn in, and I just needed to clean out the debris. Both wheels are spinning very freely, and the oneway diff is working perfectly.
I made this video documenting my process of figuring out what was wrong. I recently started a YouTube channel dedicated my Mini-Z, I only have a few videos but I upload a new video every week. I plan to make a bunch more videos about Mini-z AWD, in particular the MA-020s since there are very few videos about this car.
Diagnosing Front Oneway Differential Issue & Fix Mini-Z AWD MA-020s (20 min 51 sec)
Jul 22, 2019, 03:20 PM
Low budget fun
Beaver_XT's Avatar
Following to see what you will do with this car.
I'm still waiting for MA030 though. Hopefully they will make a normal version and not EVO only.
Discussion Any good starters for .020 - .010 engines? smallengines1284 1/2A Planes 39 Dec 18, 2017 12:00 AM
Discussion .010 or .020 ??? beil1994 1/2A Planes 32 Aug 23, 2017 05:51 PM
Discussion Mini Z MA-020S Opinions Michael_92 Micro Cars 41 Jan 08, 2017 04:28 AM
Help! Switched power on Mini-Z MA-020S jfalesi DIY Electronics 1 Oct 25, 2016 07:02 PM
