This thread is privately moderated by MIKEYOUR, who may elect to delete unwanted replies.
Jun 20, 2019, 12:33 PM
Trader Rating: 343
"Thats right Iceman"
$175.00 USD
Will not ship
Sold
CMPro Ventus-2HX RC Scale Glider
The CMPro Ventus is well-designed to make building and flying a lot of fun, it features:
High precision fiberglass fuselage with fine painting that perfectly reflects the nice appearance of Ventus.
Nicely covered wing panel built by quality balsawood, a decal set is included which you can personalize the design.
Wing tips in order to reduce the tendency to stall and enhance scale feelings.
Removable tailplane for easy transportation.
Clear navy blue canopy with cockpit.
An air-brake that efficiently raises control of the plane and makes landing an easy thing to do! The design is also aimed to make assembly as simple as possible. A steering set is included to help setting up the air-brake and make it easy to use.
A retract system that makes the Ventus suitable for different flying locations. The retract is easy to use and is linked with the hatch door for scale features.
A 8mm-hole is pre-drilled at the nose for towing on runways. The construction inside fuselage is already prepared for tractors and thus no further conversion is needed.
CMPro Ventus-2HX RC Scale Glider ARF
A high quality euro style sailplane, equipped with retract landing wheel and hatch door, amazing prefabricated fibreglass fuse and balsar covered wings, plus a unique and interesting air-brake system.
This is a very well built and detailed model, suitable for even the fussiest of glider pilots. It''s air-brakes and sturdy V2 landing gear system makes for easy landings.
Specifications:
Wingspan: 2600mm
Length: 1190mm
ARF Weight: 1130g
Wing Loading: 39~42g/dm2
Airfoil: HX83-Nase 3 modify
Wing Area: 29dm/2
Radio Req.: 3-6Ch (4-7 servos)
Latest blog entry: the essence of rc
Build Log CMPro Ventus 2HX ARF jason H Scale Sailplanes 871 Oct 26, 2017 07:44 PM
Sold CMP Ventus 2HX Glider ARF NIB 2600mm Wingspan Sgt Ski Aircraft - Sailplanes (FS/W) 1 May 24, 2014 01:16 PM
Sold CMPro Ventus 2hx Glider LPU caliber305 Aircraft - Sailplanes (FS/W) 6 Nov 15, 2013 11:28 PM
Sold CmPro Ventus 2hx with lots of extras Steve Hanes Aircraft - Sailplanes (FS/W) 0 Oct 18, 2013 11:18 AM
Discussion Ventus-2HX RC Scale Glider ARF Sofa King Sailplane Talk 3 Mar 22, 2009 10:43 AM
