Jun 21, 2019, 12:25 PM
Originally Posted by birdofplay
IS the Prop on BACKWARDS ?
very low efficiency from backward facing props.
A Pic would help in our quest for a solution here.
I'm pretty sure the prop is on the right way, it does pull forward slightly and I've measured the thrust with scales.
Jun 21, 2019, 12:27 PM
Originally Posted by EvanM
Here is a quick test to verify the low trust, when you hold the wing nose up and run the throttle up to a point where it is weightless, that is the 1:1 thrust ratio (hopefully about 3/4 throttle). If you get to full throttle before it is weightless, that will confirm the low thrust value.
Also, please confirm that the prop is 6 inches from tip to tip. I agree a picture or two at this point would help.
I've just posted some pictures, I also put the wing nose down on some scales, zerod them and then put it to full thrust. That's where I got the 200 grams figure. That method should be somewhat accurate.
Jun 21, 2019, 12:43 PM
EvanM's Avatar
Prop is backwards.
Jun 21, 2019, 12:57 PM
Prop is backwards.
I think you are right, I thought the writing was meant to face away from the motor?
Jun 21, 2019, 02:31 PM
EvanM's Avatar
Markings go in the direction of flight. A common mistake that I have made myself on multiple occasions. How is the thrust now?
Jun 21, 2019, 02:54 PM
Retired CAD guy
birdofplay's Avatar
Obviously WRONG prop direction, sorry !
13K posts vs 9 wins every time ! ;>}
You will be amazed at the difference !
Jun 21, 2019, 04:49 PM
The only reason I didn't check is because I thought it would reverse the thrust for some reason. Newb error.
Jun 21, 2019, 04:53 PM
It's almost too powerful. Thanks for your help anyhow.
Apr 17, 2021, 06:19 AM
AR Wing 900 - correct CG??
Hi all,
I also have an AR Wing 900 and am currently balancing the CG. Must say that this is very tricky: move a millimeter inside the CG mark and the plane tilts immediately - with the good old finger method I do not get along here! How did you manage it? Slightly nose-heavy or rather tail-heavy?
Apr 17, 2021, 10:38 AM
I weighted mine so it is slightly nose heavy. I do this for all my wings.
Discussion My Icon A5 won't take off from water djacob7 Foamies (Scratchbuilt) 83 Nov 04, 2019 04:41 AM
Discussion Mailden flight: my quad won't take off! Gico Beginner Multirotor Drones 34 Feb 17, 2016 08:19 AM
Discussion Syma 8C won't take off/Fly?? Mauimacman Multirotor Drone Talk 4 Feb 01, 2016 12:40 AM
Discussion AeroSky 550 hexacopter won't take off...... spotter1 Beginner Multirotor Drones 4 Oct 26, 2015 07:31 PM
Discussion Flamewheel F450 All Motors losing power won't take off Brightlight Beginner Multirotor Drones 3 Oct 23, 2015 11:19 AM
