Jun 20, 2019, 08:02 AM
Merch's Avatar
ToolkitRC M6 DC 150W 10A LCD 2-6S Lipo Battery Smart Balance Charger Discharger
https://www.banggood.com/ToolkitRC-M6-DC-150W-10A-LCD-2-6S-Lipo-Battery-Smart-Balance-Charger-Discharger-With-Voltage-Servo-Checker-Receiver-Signal-Tester-Quick-Charger-Function-p-1512836.html
Specification:
Input Voltage: DC 7-28V
Output Voltage: 1-28V
Charge Current: 0.1-10A
Discharge Current: 0.1-2A(Recycling mode)
0.1-10A(Internal consumption mode)
Max Charge Capacity: 150W
Max Discharge Capacity: 20W
Supported Batt. Type:LiFe/Lilon/LiPo/LiHv (1-6S)
NiMH/Cd(1-16S)
Pb(1-10S)
Weight: 80g
Feature:
1.The M6 charger come with LCD Display
2.Charge, discharge and balance management support Lipo 8S, LiHV 8s,LiFe 8S, NiMh 20s ,Pb 12S battery
3.Can measure PWM / PPM / SBUS / DBUS and other signal values
4.Can measure battery voltage, battery internal resistance, ESC watt meter
5.Can output PWM / PPM / xBUS standard signal, constant current constant voltage source.
Packaging Included:
1X ToolkitRC M6 Charger
Jun 27, 2019, 07:06 AM
How much is Balance Current?
Jun 28, 2019, 07:29 AM
Merch's Avatar
Sorry i don't understand what you mean by this it's max is 6s at 10amps.
Jul 15, 2019, 06:13 AM
Obsessive Compulsive
CptanPanic's Avatar
I wonder if they fixed the calibration issues that the M8 had?
Jul 21, 2019, 10:04 PM
Merch's Avatar
Need to wait for reviews to find out.
Jul 29, 2019, 08:38 AM
IŽa m unfortunate M8 owner to, waiting to know too if it was fixed this problem!
Jul 30, 2019, 10:04 PM
Merch's Avatar
ToolkitRC M6 150W lipo charger - it is SMALL :) - SHOW & TELL (23 min 4 sec)
Aug 16, 2019, 02:42 PM
Will this balance charge?
Aug 19, 2019, 08:14 PM
Merch's Avatar
Yes.
Aug 28, 2019, 09:35 PM
Merch's Avatar
ToolkitRC M6 MINI 150W 10A Smart Battery Charger with XT60 Charger Board for 2-6S
ToolkitRC M6 MINI 150W 10A Smart Battery Charger with XT60 Charger Board for 2-6S Lipo Battery
Specification of Toolkitrc M6:
USB Output: 5V 2.1A
NiMH/Cd(1-16S)
Pb(1-10S)
Weight: 80g
Feature of Toolkitrc M6:
2.Charge, discharge and balance management support Lipo, LiHV ,LiFe,Lion 1-6S, NiMh 1-16s ,Pb 1-12S battery
3.Can measure battery voltage, battery internal resistance, balance
4.Can measure PWM / PPM / SBUS / DBUS and other signal values accuracy 1s.
5.Can output PWM / PPM / SBUS standard signal, accuracy 1s.
6.Customizable 1-28V constant voltage,1-10A constant current.
7.Compatible with iOS and android mobile device.
8.Charge the drone battery,active and charge.
9.USB [email protected] Output,for mobile phone devices.
10.Udisk firmware upgarde.(Slave device).
11.Multi-language support.
12.TFT 1.8"Full color LCD.
13.150w 10A Charging capacity.
14.0.1a to 10A Discharge/Storage mode with Energy recycle function (high amp discharge and storage when using a battery as the power source.
15.PWM Signal generating function for servo testing.
16.User controlled Power Supply mode with adjustable voltage and amperage output.
17.Cell balancing and IR testing mode.
18.Easy Firmware update, charger acts like USB drive then just copy and past firmware file.
Description of charger board:
Item Name: Amass XT60 Para Board
Compatible for iSDT D2 Q6 SC-608 SC-620 Charger
Balance Cells: 2s~6s
Plug: XT60
Packaging Included:
1x Amass XT60 Plug Parallel Charging Board
Sep 09, 2019, 01:21 AM
Merch's Avatar
PERFECT FOR BEGINNERS!! Toolkit M6 review. (6 min 44 sec)
New Product The sample test: ToolkitRC M8 DC 300W 15A Battery Balance Charger Discharger for 2-8S BG-Wilson Batteries and Chargers 28 Yesterday 06:54 AM
New Product Ultra Power UP610 200W 10A DC Pocket Smart Lipo Battery Balance Charger Discharger smg24 Batteries and Chargers 0 Dec 18, 2017 06:22 AM
