Jun 19, 2019, 06:08 PM
Balsa Supply issues in the US
I order balsa in bulk for my laser cutting operation
It seems that my suppliers are having difficlty getting good wood?
This is resulting in long delivery times to their customers.
Anybody else have an input on this?
I am told that the wind turbines are sucking up all the good wood for the turbine blades
Bob
Jun 19, 2019, 06:30 PM
Summit Model Aeronautics
Steve85's Avatar
I too order in bulk, from Bud Nosen. Lately, thinner sheets like 1/16" all seem to have a twist in them, they won't lie flat. I don't know if this is due to lower quality wood, inadequate drying before sawing or poor storage conditions once sawn, but much of it has been unusable for modelling. That said, I haven't noticed longer lead times for delivery.
Steve
Jun 19, 2019, 08:48 PM
Bob
Current excuse IMO
Years ago it was AirX balsa cores for Sailboats (subsequently proven as a Bad idea)
Then it was lining for Supertanker Oil holds. Lotsa wood used there.. No longer part of the designs though.
Current Turbine blades pre-emption claim is IMO sketchy .. as they simply don't use anywhere near Oil tanker required quantities of Balsa.
More plausibly it's a fresh twist on upping price points.
Jun 20, 2019, 09:25 AM
smithdoor's Avatar
You may try AliExpress
It can take 4 to 8 weeks to keep the cost of shipping down.
You will a retailer will use any reason to increase prices.
Try this at time I was buying ball bearing 6203 for $0.48 each I found same bearing at pep boys for $5.99 and at OSH for $10.99.
Today ever retailer is using the new T taxes
But if still buying this ball bearing the new T tax would increase my cost buy only $0.12 BUT the retailer would raise there price by 25%
Bottom line just a way for retailers to have cover story to increase prices
https://m.aliexpress.com/wholesale/b...835&gclid=null
Dave
Bob
Jun 21, 2019, 01:30 PM
I fly, therefore, I crash!!!
SteveT.'s Avatar
Have you tried any of these other suppliers..
Specialized Balsa
National Balsa
AC supply
Midwest Products
Balsa Wood Inc.
Balsa Central
Sig MFG.
Balsa Wood shop
And if you want plywood, Aircraft Plywood MFG sells plywood, in both 'standard' aircraft grade birch plywood, (phenolic based adhesive) and laser cuttable aircraft grade birch plywood that had a melamine based adhesive that is designed to be easier to cut with a laser. If you contact Jerome at Aircraft plywood, he will send you samples of this plywood. I have purchased the 1/16' and am going to purchase some 1/8". He makes it in 4'X8' sheets, but will cut down to 2'X4' sheets for cost saving on shipment. Both the 1/16" and 1/8" sheets are $105.00 per sheet plus shipping. (two sheets of 1/16" cost about $250.00 shipped, but that will give you a lot of wood.
SteveT.
Jun 22, 2019, 09:20 AM
The Junk Man
I have had very good luck ordering through Balsa Wood Inc. http://www.balsawoodinc.com/balsawoodproducts
Tom
Jun 25, 2019, 10:16 AM
Barney Fife, Vigilante
tom43004's Avatar
The initial push for turbine blade seemed to be real. I'm only aware of one of the manufacturers, but they have switched to a rohacell-like foam. Not sure about the rest...
Jun 25, 2019, 02:42 PM
smithdoor's Avatar
Odd place to use balsa wood. The drafman must a model bulder
Dave
Bob
Careful! China issues SIX WARNINGS to US Navy in South China Sea SKYPILEIT Life, The Universe, and Politics 15 Aug 12, 2018 03:23 PM
Discussion can someone recommend a good source of balsa plywood in us? RS2K Scale Kit/Scratch Built 4 Oct 02, 2014 07:44 PM
Discussion Battery Issue...Reversed polarity? Charger Issue? Power supply issue? IDK ! Help!! H20up2 Batteries and Chargers 4 Jun 09, 2010 09:42 PM
Discussion The patriotic issue of US oil supplies. Treetop Life, The Universe, and Politics 155 Aug 19, 2008 03:55 PM
Who supplies the Bandit in the US hbielich Electric Sailplanes 2 Feb 10, 2004 04:20 PM
