This thread is privately moderated by rcheli168, who may elect to delete unwanted replies.
Jun 19, 2019, 04:32 AM
New Product
Emax Tinyhawk Indoor FPV Racing Drone RTF F4 4in1 3A 15000KV 37CH 25mW 600TVL VTX 1S
Features
- 75mm Indoor racing drone
- 08025 brushless motor with durable ball bearing for increase flight and low maintenance
- Durable polypropylene plastic frame with propeller guards
- Motor beeper function. Find your tinyhawk after a crash
- Speeds up to 56kph
- Up to 4 minutes flight time on single battery
- Fast F4 Processor for smooth stable flight characteristics
- MPU6000 gyro for vibration free operations
- Unique inverted motor design to keep CG as low as possible to fit in the smallest of spaces
- 25mw VTX and 600tvl Camera included for fun FPV flight via FPV style goggles
- Smart Audio function to change VTX channel via your transmitter
- OSD settings control to customize flight feel
- Pre-tuned from factory with expert pilots and new pilots in mind. 3 rate profile settings for all types of flying feel
- Plug in type motors for easy maintenance
- 1s High Voltage (HV) 450mah lipo included
- Frsky compatible D8 receiver built in to FC
- Custom carbon fiber themed carrying case
Recommend parts (Not Included):
Frame kit: Click 75mm Polypropylene Frame Kit
Motor: Click Tinyhawk 08025 Brushless Motor 15000KV
Propeller: Click Tinyhawk Avan Propeller
Battery: Click Tinyhawk 1S 80C/160C HV 450mah Lipo Battery
LED LED Strip Light : Click 1M 2.5mm LED Non-Waterproof 60 LED Strip Light
Product Details
Model: Tinyhawk BNFversion
1 diagonal wheelbase (without paddle): 75mm
Maximum size of the aircraft (without antenna, cable tie): 125mm
Propeller: Avan Tinyhawk Paddle
Aircraft weight (without battery): 27.5g
Master: F4 (MATEKF411 firmware)
4 in 1 3A ESC
EMAX Tiny receiver (compatible with Frsky remote control D8 mode)
Motor: TH08025 15000KV
Camera: 600TVL CMOS camera
Figure: 20MW adjustable frequency 37CH
Main PCB
Flight Controller: F4 (MATEKF411 firmware)
ESCs: 4in1 3A
Receiver: EMAX Tiny receiver (Compatible with Frsky D8 mode)
Motor
Stator: 8mm x 2.5mm (08025)
KV: 15000kv
Weight: 2.5g
Bearing Size: Φ1.5*Φ4*2mm
Shaft Diameter: Φ1.5mm
Propeller
Diameter: 40mm
Blades: 3
Pitch: 23mm
Weight: 0.5 g
Camera and VTX
VTX Power: 25mw
Channels: 37CH
Camera Properties: 600TVL CMOS
Battery
Voltage: 1s 4.35v HV
Capacity: 450 mAh
Discharge rating: 80c/160c
Goggles
EMAX Transporter Goggles Specifications:
Maximum appearance size 14015390(mm)
Weight (without battery) 398g
Resolution 480272
Battery 1 cell 18650 lipo battery
Transmitter
EMAX E6 Transmitter Specifications:
Maximum appearance size 18121380(mm)
Weight (without battery) 211g
Number of channels 6 Channels
Transmission frequency 2.4GHz ISM Band(2400MHz~2483.5MHz)
Output Power 22dbm
Modulation GFSK
Item Packing
RTF Version:
1 x Tinyhawk FPV Racing Drone
1 x Light weight soft carry case, with carbon fiber look
1 x USB High Voltage capable 4 port USB Charger
1 x 1s High Voltage (HV) 450mah lipo battery
1 x FPV Goggles
1 x Transmitter
1 x USB Cable for charging goggle, radio
1 x Parts Bag
1 x Phillips screwdriver
2 x 18650 Battery already pre-installed
1 Set spare AVAN Tinyhawk 3 blade propellers.
Cool Emax Tinyhawk S 75mm 1-2S Indoor Micro FPV Racing Drone GeekBuying Geekbuying.com 1 Jun 06, 2019 05:29 AM
New Product Emax Tinyhawk Indoor FPV Racing Drone BNF F4 4in1 3A 15000KV 37CH 25mW 600TVL VTX 1S smg24 Banggood.com 1 Nov 03, 2018 07:26 AM
New Product HB65 65mm 1S Micro Brushless RC FPV Racing Drone BNF F3 OSD 5A Dshot 25mW 48CH 600TVL Merch Micro Multirotor Drones 4 Jun 20, 2018 08:20 PM
New Product HB64 64mm 1S Brushless RC FPV Racing Drone BNF W/ F3 OSD 5A Dshot 25mW 48CH 600TVL FS smg24 Banggood.com 0 Jan 03, 2018 05:57 AM
