Feb 16, 2020, 03:51 PM
120sr/200srx/230s/300cfx/200qx
targetingxmod's Avatar
ProBoat Recoil 26" on 3s going 44kmh @ February 2020 Video #2 (3 min 58 sec)
Feb 21, 2020, 07:23 AM
-Made today a personal best with a 3s lipo and the 2300kv motor... 58kmh! My best last one was 57kmh! :P
Prop used was a 3 Blade 42mm 1.4pitch.
One thing i notice is that this boat liked this prop much better then the 40mm version of it! :P
OR could be being an outrunner i had put to much timing on the esc... yeah i changed 2 variables.. lol
BUT it's so solid... and barrely hot on LVC...i think i can gear higher and higher means less heat? I am puzzled! :P Maybe i am entering the right size for combo! It will needs lot of testing... videos cooking!
Feb 21, 2020, 09:01 AM
Jansvast's Avatar
Why not feed it some 4s? Too much heat?
Feb 21, 2020, 11:42 AM
"stock" outrunner 2300kv won't work on 4s!
ESC & motor don't like 4s....
I already run 5s and 6s with a 1600kv outrunner...but it burn on 6s! There are videos a few pages ago...
I will use inrruners...but need for them to arrive! :P
Feb 21, 2020, 11:43 AM
ProBoat Recoil 26" on 3s going 58kmh @ February 2020 Video #1 42mm 3 Blade CNC 1.4pitch (5 min 32 sec)
Feb 21, 2020, 12:32 PM
Jansvast's Avatar
Oh, i thought you were still runninn a different motor. guess i just cant keep up with your motor apetite
Jan
Mar 07, 2020, 01:00 PM
Todays runs...
-53kmh on 5000mah 3s graphene with 3 Blade 1.4 pitch 42mm prop....
-55kmh on 3000mah 3s graphene with 3 Blade 1.4 pitch 42mm prop...
Mar 07, 2020, 02:18 PM
ProBoat Recoil 26" on 3s going 53kmh @ February 2020 Video #1 (4 min 23 sec)
-53kmh video...
Mar 07, 2020, 06:05 PM
ProBoat Recoil 26" on 3s going 55kmh @ March 2020 Video #2 (3 min 15 sec)
-55kmh video...
Mar 07, 2020, 08:34 PM
THUNDERBOAT's Avatar
It's nice to see a RC boat that's Fast and durable that can take all of the flogging it receives and still keep running as if it's saying Camon Bring It On.❗This boat appears to be one of those extremely resilient to any punishment that is dished out to it & keeps the fun factor going. It is great to see there are a some setups like this that are far less delicate in nature & appear to bring you the best of both worlds in RC land. I find that to be quite impressive.
Mar 09, 2020, 03:23 PM
Hihihi! :P
-Two dead "guys" on the left...
From left to right:
-Stock 2100kv motor died on 4s (Outrunner)
-Garrt 1600kv died on 6s (Outrunner)
-4050 2300kv, the one new to test now!
-TP Power 1900kv ... the final BOSS! :P
Going to use the Blue 4050 inrunner next time it sees water! Got my water jackets! :P All of them are 40mm diameter motors! :P ... My SonicWake 36 has a stock 36 diameter motor!!
-As for the TPPower CM it will wait till this new one burn on 5s! :P
Here are it's specs, from the blue 4050 motor: (40mm diameter, 50mm long) I choosed it because it's the closest's to size to the stock motor to still have same handling!!
Specifications
Model: SKF-4050/4Y
RPM/V: 2324
No-load Current (7.4V): 2.1A
Max. Amps: 52A
Max. Volt(V): 21.5
Power (W): 1120
Motor Diameter: 40mm
Motor Length: 50mm
Shaft Diameter: 5.0mm
Shaft Length: 18mm
Weight: 239g
Mounting Hole Size: M3, pitch 25mm
Mar 10, 2020, 08:33 AM
-See the extra water intake?
-Changed the timing on ESC from Outrunner's high...15
-7.5 timing!
Can't wait to see water!
Mar 10, 2020, 09:40 AM
It would be great to buy a boat like this one "Out of the box" that is ready to run! And here I thought this boat was all stock when I first seen it run. Shows how dumb I am with all these new fangled gadgets.
Mar 10, 2020, 10:23 AM
Y wind motors 10 - 15 degrees.
Mar 10, 2020, 01:46 PM
Are you sure? Isn't that to high for an inrunner?
I learned some years ago...that outrunner's like high timing...like +15 and inrunners with no heat around the 7.
Can be the case for Delta "D" motor's for 7 and "Y" for 15?
Would like to know why you said that... think google can also explain, but others opinions are appreciated! Thanks!
Discussion My ProBoat Recoil 17....my first boat (pictures & videos thread) targetingxmod Racing Boats - Electric 55 Mar 12, 2020 05:35 PM
Discussion Recoil 26, my first boat Aqualungs Racing Boats - Electric 42 Aug 11, 2018 04:11 PM
News ProBoat Recoil 26" RTR Deep-V Jason Cole Dock Talk 34 Nov 29, 2016 01:44 PM
Discussion More Upgrades on my ProBoat Blackjack 26 (Video added 6/14) tlh101 Racing Boats - Electric 3 Jun 14, 2016 02:29 PM
Discussion Proboat Recoil 26" RTR rcdrivertim Racing Boats - Electric 5 Apr 13, 2016 07:01 PM
