Jun 16, 2019, 02:29 PM
ful- range FASST micro Rx for 1s
I haven't been on here in years and haven't kept up well, and I didn't find an answer searching. I hope this isn't an annoyingly common topic:
I have an 18" 30 gram "bush" plane flying great with an FrSky Rx on 1s, but I have to fly in tight circles around me till I get dizzy, or else the plane goes out of range and flies away. It's all balsa sheet so when it comes down it's fine, but obviously I want better. The FrSky Rx has good range on my 2s planes but this plane/esc/motor/prop are designed for 1s.
I'd like a 1-2 gram 4 channel microRx with decent outdoor range that'll work on a 1 cell lipo with my FASST Futaba T6EX Tx. Cost is relevant but not critical.
Does anything readily come to mind?
TIA.
Edit: pardon the typo in the title ;-)
Jun 23, 2019, 06:45 PM
sirpercy's Avatar
This is not FASST, but S-FHSS compatible. I have this in a couple of planes that I fly in a park, at considerable distance. I have never lost range.
https://microaces.myshopify.com/coll...micro-receiver
I also have several of these in 3d foamies. Again , never had an issue. It is not a 1s receiver though. It says it will work from 3.5 volts, but I doubt it. It is a great 2s receiver.
https://hobbyking.com/en_us/orangerx...-and-sbus.html
Jun 24, 2019, 09:36 AM
Thanks for the response.
I figured the F3P forum would have a lead on the best stuff available but I'm coming to terms with the idea that there may not be an exact match for what I want. When I [finally] converted from 72 mHz to 2.4 gHz, I went with FASST stuff, so it'd be a pain to switch everything again to FHSS or DSM.
The first receiver linked isn't FASST compatible, and the second one can't run on a single cell .
I removed the wrap and sockets from a micro FASST Rx, soldered the servo leads, and got it down to 2.4g, so for now I'm living with a 1.5 gram penalty *shrug*.
I'd use a "brick" but can't find a FASST one and they seem to all have brushed escs.
New Product $10 FrSky XM 1g 16CH SBUS Micro Rx & $16 FrSky XM+ 1.6g Full Range 16CH SBUS Micro Rx lmpuIse Micro Multirotor Drones 118 Jun 19, 2018 03:04 PM
New Product FrSky XM 1g 16CH SBUS Micro Rx & FrSky XM+ 1.6g SBUS 16CH Full Range Micro Rx lmpuIse Radios 0 Dec 02, 2016 11:55 AM
Discussion Rx-f802 frsky RX range and suitability for gliders nigelsheffield Radios 38 Oct 16, 2015 11:24 AM
Help! Orange RX Fasst compatible range issue Johnsmith122 Radios 8 Oct 15, 2012 11:20 AM
Discussion Is it possable to build a ful fuse micro 3d balsa plane 3Daddict 3D Flying 13 Nov 17, 2010 09:50 AM
