Jun 16, 2019, 10:16 AM
localfiend's Avatar
27" Northern Pike - 0.3mm Nozzle
After way too long, I've just decided to upload the STL's for the 27" version of the Northern Pike.
Here's the thingiverse link:
https://www.thingiverse.com/thing:3694993
Figured I'd start a new thread specifically for this version, as the other was getting to be rather large and hard to wade through. If I can recover the lost files on my dead backup drive, I'll eventually try and post g-codes.
So quick specs:
Around 360 grams printed weight, and probably 560 grams AUW.
For electronics, you could technically use the same as on the full size pike (except servos), which might be a little nuts. A bit more reasonable setup would be a 2204 2300kv motor, 20-30A ESC, 2x HXT500 servos, and a 1300mah 3s-4s battery.
Dry your filament! Even if it came from the factory vacuum bagged, I haven't found a brand yet that didn't benifit from additional drying. I imagine most of the PETG out there is manufactured in a wet environment, and must not always get sealed in a timely fashion.
Also, a quality .3mm nozzle. For my Prusa printes genuine e3d nozzles gave me the same quality on the small plane, as a .4mm did for the full size one. I tried a couple cheap nozzle with horrible results.
Jun 17, 2019, 05:18 AM
thanks i have an ander 3 that would be ok just have 0.4 nozzle
Jun 17, 2019, 08:50 AM
localfiend's Avatar
This thing will have to be printed with a layer width of not more that .32mm or it will be too heavy, and you'll likely run into slicing problems if you try.
So, to use a .4mm nozzle, you'll still need to change the width, which will probably be a pain to tune for (I'd anticipate stringing being an issue). Guess it depends on if you want to spend money on a .3mm nozzle (they're cheap) or on wasted plastic and time tuning.
But who knows, maybe the tuning wouldn't be that bad. I have not tried.
Discussion 36" Northern Pike - 3D Printed Cuda Clone (It Flies & STL's Posted!) localfiend 3D Printed Planes 686 Sep 16, 2019 10:21 PM
Contest Northern California F3F Race 5/27/18 curdman Multi Task F3X 1 May 16, 2018 11:54 AM
Cool Northern California BASIC Bootcamp: 27 July 2013 Whirly-Girl Competition Aerobatics 0 Jul 22, 2013 02:26 AM
6-27's video around Northern Va typicalaimster Aerial Photography 1 Jun 29, 2005 01:13 AM
Zoom / Shogun Pinions 2.0 / 2.3mm now available ... born2net Mini Helis 12 Jul 09, 2004 12:20 PM
