Jul 02, 2019, 02:05 AM
japim's Avatar
Originally Posted by steelfaith1
Number of Top Solid Layers in S3D is 0. Bottom Layers are 0. Perimeter Shells are 1.
So, no wonder there is a hole. Will try to print again by changing the Top Solid Layers to 2.
Thanks for the help Jampim.
Change it to 4.
Jul 02, 2019, 06:22 AM
Lynxman's Avatar
Use the variable settings wizard and add top layers to the layers around that area only.
Jul 02, 2019, 11:31 AM
Originally Posted by japim
Change it to 4.
Glad I read this before I started that print. I set the Top Layer to only 1. Changing to 4 Top Layers on Wing 2 per and will see if that closes up the holes. Thanks a bunch for your help. Saved me 4 or 5 hours on that print job.
Jul 02, 2019, 11:35 AM
That's some good information that I did not know. Never used the Wizard before, so will give it a try. Thanks a bunch.
Jul 02, 2019, 04:41 PM
Thanks for the help everyone….got a perfect print, no blemishes at all around the hole area. Took the advice and used 4 Top Layers.
Jul 03, 2019, 04:11 PM
5546dug's Avatar
little off topic
I know it is a little off but do any of you here have the stl files for the 63 " model of the 3dlabprint edge 540?
if you want to sell pm me
thanks doug
Jul 04, 2019, 03:24 PM
Originally Posted by bigbobed
Don't expect any help.
Just received my 2nd response from 3DLabprint. It does take them a while but they do eventually respond.
"The sure bonds are designed to leave some gap for the CA glue.
As for the cowling, this spot is a bit problematic, as this needs the layer height to be lowered and some top layers as well to fill in the gaps.
The Šonka cowling is not affected by this issue.
Petr Šťásek
Support"
Jul 04, 2019, 03:42 PM
Awsome 2.5D Pilot.
bigbobed's Avatar
Petr Šťásek
Support"
I just printed the surebonds and am not happy. Too loose in the slots. I increased the width and did a test print and th new width is fine but it leaves gaps on each end. So I'll do some more redesign. You don't need much room to wick in thin ca. Hate to have a bunch of blemishes on the surface.
Jul 05, 2019, 10:14 PM
Been using thick gorilla superglue and hitting it with aerosol kicker. Fills the gap pretty good, up to the surface.
Jul 06, 2019, 11:48 AM
Awsome 2.5D Pilot.
bigbobed's Avatar
I changed the x,y,z parameters to the following and got nice fitting wedges.
24.0 15.74 2.0 and printed with a 100% first layer.
Jul 06, 2019, 05:58 PM
Thanks for those numbers....will try reprinting and chunking the other ones. Was going to mess around with the scale, so thanks for taking care of that.
Printing the canopy now so after it will get to the sure bonds.
Jul 08, 2019, 07:30 AM
Awsome 2.5D Pilot.
bigbobed's Avatar
Anyone figured out what to do about a landing gear?
Jul 08, 2019, 10:48 AM
I ordered the carbon fiber one they recommended off of ebay…..around 25 bucks.
Jul 08, 2019, 10:57 AM
Awsome 2.5D Pilot.
bigbobed's Avatar
Link? The one in the guide points to one on Hobby King which is out of stock.
Jul 08, 2019, 01:21 PM
MorganTech
This one matches up the pair that I purchased from HK for the 73" Edge.
https://www.ebay.com/itm/Carbon-Fibe...sAAOSwOkhb18vc
Discussion 3DLabPrint Edge 540 64" Cory80 3D Printed Planes 34 Jun 28, 2019 02:22 PM
Discussion problems with the spinner for the 3DlabPrint models klausnolte 3D Printed Planes 3 Mar 01, 2018 04:09 AM
Discussion pilot rc 73" edge 540 going electric help Hallcrasher 3D Flying 6 Oct 22, 2017 02:11 PM
Discussion Wild Hare 73" edge 540 cg and control throws jwmachon Fuel Plane Talk 3 Mar 05, 2017 07:12 PM
Edge 540 73" wingspan video and pix Splash Scale Kit/Scratch Built 8 May 13, 2005 04:11 PM
