Even though the build hasn't started, I have been doing a lot of thinking.
The model is designed for rudder/elevator control. However, I am leaning toward adding ailerons. I will have to see how much space is available in the wings for the servos. I don't think the elliptical shape of the Spitfire wing will lend itself to a central servo with control horns. Will be using an .049 for power. For covering, I am planning to use Parklite, or similar. I am needing Light Blue, Cream, and Brown. Was able to find Light Blue at Brodak [Sky Blue], and Tower Hobbies has Parklite in Brown and Cream. For markings, I am planning to use Callie Graphics. They have a set of markings for a US North Africa Spitfire: https://callie-graphics.com/collecti...buckeye-down-2 |
Went my local PostNet, and for $5 got a copy of the plans. This way, I don't cut up the original.
Also got in the Sky Blue covering and a pilot from Brodak.
The Sky Blue is a tad darker than I had hoped, but will do ok. |
Long time ago I converted a 28" Guillows Spit. I used an old Postage Stamp Cox to make the wind.
Raced around the Goal posts at the local High School. Lesson learned about ailerons on an elliptical wing ... keep them to the outside. The more you have to the Root they act as Flaps and makes an unstable ride. I did mine single servo with push / pull cable set up. Also did the same thing with a Shinden. Can't remember who I gave that to. Needed repairs. It spent a few weeks in a poison oak patch. |
Ok, getting my build area set, and my parts sorted out. Wing in the upper box, and fuselage in the lower box.
All the wood is hand labeled. Just wonderful.
Starting on the lower spar. Interestingly enough, it has to be tapered.
Throwing on some ribs. Had to do a little sanding for fit.
Upper spar.
Thread Tools | |
Similar Threads | |||||
Build Log | 1/2A Eugley Stick from Arkansas [Manzano Laser/Pat Tritle] | crawf56 | 1/2A Planes | 244 | Aug 11, 2019 09:05 PM |
Build Log | Classic 1/2a design(s) from plans | raycamel | 1/2A Planes | 31 | Jun 15, 2017 09:45 PM |
Build Log | Cox Cobra 1/2A Free Flight Heli from Arkansas | crawf56 | 1/2A Planes | 77 | May 01, 2017 11:57 PM |
Gallery | RCM Basic Trainer 1/2a (RCM Plan from 1978) | mukaghigonetto | 1/2A Planes | 4 | Nov 23, 2015 08:48 PM |
Discussion | Marutaka 1/2A Spitfire Mk 1 conversion | YEAP CHIN POH | Scale Kit/Scratch Built | 44 | Jun 07, 2010 03:58 AM |
