Aug 18, 2019, 11:39 AM
J40
J40
Airplanus Erectus
Throttled Norvel .061 for the Win!
Aug 18, 2019, 08:10 PM
crawf56's Avatar
Getting the Dubro mini pushrods ready. Using a little JB Weld to attach the spring/threads.
Aug 18, 2019, 08:11 PM
crawf56's Avatar
Elevator & rudder servos in the fuselage.
Aug 19, 2019, 10:04 PM
crawf56's Avatar
Working on the elevator.
The plans show an interleaving tape (did I say that right?). However, I plan to use conventional hinges.
Edit: "interweaving". Some days I wake up dumber than usual.
Aug 20, 2019, 09:41 AM
J40
J40
Airplanus Erectus
I like it a lot! Looking forward to seeing it finished crawf.
Aug 20, 2019, 09:38 PM
crawf56's Avatar
Hinges on the elevator.
Aug 21, 2019, 10:30 PM
crawf56's Avatar
Hinges installed on elevator. Using drilled holes & toothpicks.
Aug 23, 2019, 09:31 PM
crawf56's Avatar
Putting the tailfeathers on.
Aug 23, 2019, 09:36 PM
crawf56's Avatar
Put water on 1/16" balsa, then used wrap on it to get the balsa to conform to a 4-1/2" dia. tube. This will give the balsa some 'curviness', to conform to the turtle deck.
The wrap start coming loose, so I put tape to help hold it.
Aug 24, 2019, 12:57 AM
Wondering if you are going to put the "Leno" chin on your North Africa Spit.
It's looking great BTW.
Aug 24, 2019, 06:47 AM
J40
J40
Airplanus Erectus
Moving right along crawf! I see an Fighter airplane!!!
Aug 24, 2019, 07:43 AM
Nitro User
1/2A Nut's Avatar
So need a pilot eh what, rally rally chaps..
Aug 24, 2019, 08:11 AM
It's "Tally Ho Chaps"
Aug 24, 2019, 08:34 AM
crawf56's Avatar
skaliwag is referring to an air filter that was added to North Africa Spitfires, causing the bottom of the cowl to stick out. (The "Leno" chin is a pretty good description.)
At this time, I am not planning on adding that detail. But it does bug me that I am not adding it.....
Aug 24, 2019, 08:57 AM
EB-66C Team Member
xplaneguy's Avatar
Approaching the finish line. Nice work, Gary!
Build Log 1/2A Eugley Stick from Arkansas [Manzano Laser/Pat Tritle] crawf56 1/2A Planes 244 Aug 11, 2019 09:05 PM
Build Log Classic 1/2a design(s) from plans raycamel 1/2A Planes 31 Jun 15, 2017 09:45 PM
Build Log Cox Cobra 1/2A Free Flight Heli from Arkansas crawf56 1/2A Planes 77 May 01, 2017 11:57 PM
Gallery RCM Basic Trainer 1/2a (RCM Plan from 1978) mukaghigonetto 1/2A Planes 4 Nov 23, 2015 08:48 PM
Discussion Marutaka 1/2A Spitfire Mk 1 conversion YEAP CHIN POH Scale Kit/Scratch Built 44 Jun 07, 2010 03:58 AM
