Jun 12, 2019, 06:31 AM
Merch's Avatar
New Product
DJI Robomaster S1 STEAM DIY 4WD Brushless HD FPV APP Control Intelligent Educational
https://www.banggood.com/DJI-Robomaster-S1-STEAM-DIY-4WD-Brushless-HD-FPV-APP-Control-Intelligent-Educational-Robot-With-AI-Modules-Support-Scratch-3_0-Python-Program-p-1500246.html
Description:
Brand: DJI
Item: Robomaster S1
Product: Smart RC Robot
Battery: 2400Mah Rechargable Lipo Battery
APP, Manual, other information: Click here
Specifiction:
Camera
FOV:120
Max Still Photo Resolution: 25601440
Max Video Resolution: FHD: 1080/30fps / HD: 720/30fps
Max Video Bitrate: 16 Mbps
Photo Format: JPEG
Video Format: MP4
Sensor: CMOS 1/4″; Effective pixels: 5 MP
Operating Temperature Range: -10 to 40 C (14 to 104 F)
Narrow Infrared Units:
Effective Range [1]: 6 m (in indoor lighting conditions)
Effective Area: Varies from 10to 40
Effective area decreases as distance from the target increases.
Wide Infrared Units:
Effective Range [1]: 3 m (in indoor lighting conditions)
Effective Width: 360 (in indoor lighting conditions)
Hit Detector:
Detection Requirements: For the Hit Detector to be activated, the following conditions must be met: Gel bead diameter ≥ 6mm, launching speed ≥20m/s, and the angle between the hit direction and hit detector plane is no less than 45.
Maximum Detection Frequency: 15 Hz
DJI Robomaster S1:
Weight: Approx. 3.3 kg
Dimensions: 320240270 mm (length width height)
Chassis Speed Range:
0-3.5 m/s (forward)
0-2.5 m/s (backward)
0-2.8 m/s (sideways)
Max Chassis Rotational Speed: 600/s
M3508I Brushless Motor:
Max Rotational Speed: 1000 rpm
Max Torque: 0.25N*m
Max Output Power: 19 W
Driver: FOC
Control Method: Closed-loop speed control
Protection: Overvoltage/Overtemperature/Soft-start/Short-circuit/Chip and sensor anomaly detection
Control:
Controllable Launching Frequency: 1-8/s
Max Launching Frequency: 10/s
Initial Launching Speed: Approx. 26 m/s
Average Load: Approx. 430
Gimbal:
Controllable Range: Pitch: -20 to +35/ Yaw: 250
Mechanical Range: Pitch: -24 to +41 / Yaw: 270
Max Rotational Speed: 540/s
Vibration Control (on the flat surface): 0.02
Intelligent Controller:
Latency (depending on environmental conditions and mobile device):
Connection via Wi-Fi: 80-100ms /Connection via Router: 100-120ms
(unobstructed, free of interference)
Live View Quality: 720p/30fps
Max Live View Bitrate: 6 Mbps
Operating Frequency: 2.4 GHz, 5.1 GHz, 5.8 GHz
Operating Mode: Connection via Wi-Fi, Connection via Router
Max Transmission Distance (unobstructed, free of interference):
①Connection via Wi-Fi:
FCC, 2.4 GHz 140 m, 5.8 GHz 90 m
CE, 2.4 GHz 140 m, 5.8 GHz 70 m
SRRC, 2.4 GHz 130 m, 5.8 GHz 130 m
MIC, 2.4 GHz 140 m
②Connection via Router:
FCC, 2.4 GHz 180 m, 5.8 GHz 300 m
CE, 2.4 GHz 180 m, 5.1 GHz 100 m
SRRC, 2.4 GHz 180 m, 5.8 GHz 300 m
MIC, 2.4 GHz 170 m, 5.1 GHz 180 m
Transmission Power (EIRP):
①2.400-2.4835 GHz
FCC: ≤30 dBm
SRRC: ≤20 dBm
MIC: ≤20 dBm
②5.170-5.25 GHz
FCC: ≤30 dBm
SRRC: ≤23 dBm
MIC: ≤23 dBm
③5.725-5.850 GHz
FCC: ≤30dBm
SRRC: ≤30dBm
Transmission Standard: IEEE802.11a/b/g/n
Intelligent Battery:
Capacity: 2400 mAh
Nominal Charging Voltage: 10.8 V
Maximum Charging Voltage: 12.6 V
Battery Type: LiPo 3S
Energy: 25.92 Wh
Weight: 169 g
Charging Temperature Range: 5 to 40 C (41 to 104 F)
Maximum Charging Power: 29 W
Battery Life in Use: 35 minutes (measured at a constant speed of 2 m/s on a flat surface)
Battery Life on Standby: Approx. 100 minutes
Charger:
Input: 100-240 V, 50-60Hz, 1A
Output Port: 12.6 V=0.8A or 12.6 V=2.2A
Voltage: 12.6 V
Rated Voltage: 28 W
Gel Bead:
Diameter: 5.9-6.8 mm [2]
Weight: 0.12-0.17 g [2]
App:
App: RoboMaster
iOS: 9.0 or later
Android: Android 5.0 or later
Router:
Recommended Routers:
TP-Link TL-WDR8600; TP-Link TL-WDR5640 (China)
TP-Link Archer C7; NETGEAR X6S (International)
Supported SD Cards: capacity up to 64GB
Recommended outdoor power supply solution for routers: Laptop Power Bank (match the input power of the router)
Jun 13, 2019, 04:15 AM
Merch's Avatar
FPV Robot — DJI Robomaster S1 (11 min 8 sec)
Sep 07, 2019, 02:44 PM
Merch's Avatar
DJI'S AI ROBOT - DJI Robomaster S1 (18 min 16 sec)
New Product Elanview Cicada S FPV With 16MP HD Camera Mobile Phone APP Controller RC Quadcopter Whitehouse Multirotor Drone Talk 1 May 17, 2016 09:15 PM
Discussion SelfieBot for education. DIY remotely-controlled robot. GF_Robots Robotics 0 May 01, 2016 04:10 AM
Discussion SelfieBot for education. DIY remotely-controlled robot. GF_Robots DIY Electronics 0 May 01, 2016 04:09 AM
Discussion DJI Phantom 4 5.8G FPV HD 12MP Camera APP / 2.4G Control @ GearBest US warehouse ApexpredatorGT Multirotor Drone Talk 2 Apr 21, 2016 10:00 PM
