Jun 12, 2019, 04:48 AM
Merch's Avatar
New Product
AGF ARX-482R 2.4Ghz 4CH Vertical Type FHSS Compatible Receiver for Rock Crawler Truck
https://www.banggood.com/AGF-ARX-482R-2_4Ghz-4CH-Vertical-Type-FHSS-Compatible-Receiver-for-Rock-Crawler-Truck-Rc-Car-p-1500064.html
Description:
Item Brand:AGF
Item Number:ARX-482R
Item Name: 2.4Ghz 4CH Vertical Type FHSS Compatible Receiver
Material:ABS and electronic components
Color:Black
Product Size:23.6*18.4*28.4mm
Product Weight:About 7.3g
Packaging Weight:Approx 46g
Fit For:
Rock Crawler,Truck,Rc Car
Specification
Operating Voltage:3.5V~8.4V
No. Of Channels:4CH
PWM Mode:Normal/ SHR/ SSR
Compatibility
Compatible with SANWA FH3/FH4T remote control system.
Suitable for remote control M12, M11X, EXZES X, MT-4, GEMINI X, MT-S, MT-4S, M12S, M17.
Feature
1) Bidirectional communication system, monitor the receiver voltage by transmitter in real time;
2) Compatible stabilizing voltage, operating voltage can up to 1-2s lipo, sudden low voltage won’t be
out of control;
3) High sensitivity built-in antenna, full 4CH output + BAT port suitable for all kinds of remote control cars, simulation rock crawlers.
4) L-shape design, small size to save more space for rc car.
Bind Procedure
1) Turn on the transmitter, get to the SYSTEM menu and select BIND;
2) Pressing the "SET" button of receiver and power on, the LED on the receiver will flash slowly. Press and hold the “SET” button for 2 seconds then release, the LED on the receiver will keep flashing slowly;
3) Select BIND menu in the transmitter and press ENTER while the LED on the receiver is flashing slowly. The LED will be off immediately.
4) Press ENTER again on the transmitter, the LED will be solid, indicating binding process is successful;
5) Please repeat the above procedure if binding is failed.
LED Status
Blue LED Status
Soild Receiving Signals
Blink Binding Mode
OFF No Signal Reception
Package included:
1x Receiver
New Product 2.4Ghz 4CH T-Shaped FHSS Compatible Receiver AGFRC Car Talk 1 Feb 19, 2019 03:55 AM
Discussion 2.4Ghz A-FHSS Compatible 4CH Micro Receiver  florida Radios 4 Mar 04, 2015 01:16 PM
Discussion 2.4Ghz A-FHSS Compatible 4CH Micro Receiver  florida Radios 0 Feb 28, 2015 09:14 PM
