This thread is privately moderated by Carmen Chen, who may elect to delete unwanted replies.
Jun 11, 2019, 09:14 PM
Flytec V007 RC Fishing Bait Boat Toys With Yaw Automatic Correction Positioning
Feature:
1. ABS engineering material is molded from the main body of the hull
2. Fixed speed driving
The Fixed speed driving function is integrated into controller, so that the bait boat can go straight at a constant speed, and the operation is simple, saving time and labor;
3. Yaw automatic correction
It has an automatic balance adjustment system, which can effectively control the driving direction of the boat and keep driving straightto avoid excessive yaw due to wind and waves;
4. Long distance strong signal receiving system
Remote controller can be achieved the signal without blocking in the range of 400-500 meters, without fear of signal interference;
5. Double motor and three blades propeller design
The boat features a powerful dual-motor design that provides sufficient power, and is equipped with a three-bladed propeller to increase the pushing power in the water for better driving speed and experience.
6. Independent double bait silo, hook and line attach design
The independent double baiting silo design can support 1.5 kg loading, and can be controlled at a fixed point to throw the bait. At the same time, the side of the bait box is equipped with a hole, which can attach the hook and line .That can prevent the fishing line from being entangled.
7. Waterproof grass double motor design
Powerful dual-motor design with waterproof cover design to prevent interference from propellers.
8. Low battery warning
Different battery levels will be reminded by the color of the indicator light. The low-power warning function can effectively prevent the boat from driving too far and can not return when run out of battery;
9. Remote control one-hand control design
The remote control is designed to be small and easy to operate with one hand;
10. Large capacity battery, long battery life
It is equipped with a 5800mAh large-capacity lithium battery, which is fast charging and the boat has 3-4 hours control time. The built-in protection board effectively improves the safety of use and prolongs the battery life;
11.LED searchlight
12. Strong wind resistance
Specification :
Material: Plastic
Power Source: battery
Charging Voltage: 7.4V 5800 mAh
Controller Battery: 4 x 1.5AA Battery(not included)
Plugs Type: USB
Charging Time: 1-2hours
Action Time: 4hours
Remote Distance: About 400-500m
Dimensions: 54*26.5*18.5cm
Package:
boat *1, remote controller *1, charger *1, charger *1, manual *1, battery *1 ( built-in hull), antenna
You can got the Fishing boat from the link: https://www.alibaba.com/product-deta...333c71d2BCT51H
Welcome to discuss more questions about RC Hobby with us. ([email protected])
New Product Flytec V500 50cm Fishing Bait RC Boat 500M Remote Fish Finder 5.4km/h Double Motor Merch Banggood.com 0 Apr 16, 2019 02:37 AM
Cool Flytec 2011-5 Intelligent Fishing Bait RC Boat with Double Motors GeekBuying Geekbuying.com 0 Apr 05, 2019 03:21 AM
