Jun 10, 2019, 02:39 PM
Romushok's Avatar
Mini-HowTo
Jumper T16 hardware hacks
Folks,
Since a not too long time I'm an owner of Jumper T16 Tx. I like this Tx, and would like to make it better. Some time ago i have find Taranis hardware hacks thread by Julez and have discover a lot of things to do, it was really useful for me. Now I would like to start thread with same purposes - to help Jumper T16 users transform their radios to something more, that it's now. Welcome here to all those can contribuit his own ideas.
Jun 10, 2019, 03:14 PM
Romushok's Avatar
So, after install 800x480 HD display next step - install hall sensors gimbals. First at all - find a donor.
Description:
I desolder 12pin mini JST from old Turnigy 9X board for cut it at half and use as gimbal adaptors. Than solder single core wires, bridged vcc and gnd for a pots.
Description:
Than solder adaptors to a board.
Description: Name: IMG_20190605_104841.jpg
Description:
Now a bit of cutting-drilling-milling-reviling work... Disassemble a gimbal.
Description: Name: IMG_20190605_110858.jpg
Description:
Cut out plastic for 3mm ca under a sensor place.
Description: Name: IMG_20190605_113000.jpg
Description:
Well, now about alu baseplates. They becames in something like this.
Description: Name: IMG_20160812_1141511.jpg
Description:
I've use one plate for find exact holes positions and then use it as an template for drilling other one, screwed they together. In fact, one baseplate has enlarged and irregular holes - it was a pioneer...
Maiden baseplates, now possible cut out new screw holes on plastic. Stock screws are ugly enought and I decide to use servo 2x10 screws with a flanged head.
Description:
You must obtain something like this. Placing gimbal unit on baseplate you'll find where cut it, they have male-female coupling.
Description: Name: IMG_20190608_101150.jpg
Description:
I've add a pair of O-rings to close free spaces between gimbals and housing. Seats of gimbals onto case aren't modyfied, so i can any time back to stock gimbals.
Description:
Mid part of case need be cutted in side of 2-springed gimbal. I fly mode1, so for me left side. From throttle gimbal i've pull out unspringed steel brace and cut out all unused plastic.
Description: Name: IMG_20160812_113952.jpg
Description:
OK, from flight mode buttons need be cutted two external lower outgrowth.
Description: Name: IMG_20190606_110710.jpg
Description:
Some afterwords... Guys, it's work not for anyone. You are need to have certain level as allmademan. Valuate well your skills before begin a work. For those braves, who will decide to do it, i can council to have some calmant medicine under hand. I use a beer, for me works well.
Good luck!
Jun 10, 2019, 03:15 PM
Romushok's Avatar
Reserved
Jun 10, 2019, 07:03 PM
1000MIGLIA City - Italy
rosnik's Avatar
great work Roman!
Congrats :-)
Jun 10, 2019, 11:05 PM
Romushok's Avatar
Originally Posted by rosnik
great work Roman!
Congrats :-)
Danke shönn
Yesterday, 02:56 AM
Romushok's Avatar
Flight mode buttons backlit mod
For those who do not like the illumination of the neighboring buttons of flight modes, I propose a simple refinement.
The light enters the button through separate light receivers located above the buttons. Initially the ends of the light receivers are dull and scatter a large amount of light.
Description: Name: IMG_20190608_112236.jpg
Description:
Light receivers are located at a distance of 2mm above the LEDs, and this gives illumination to adjacent buttons.
Description:
I polished the ends of the light receivers (carefully, do not melt the plastic) and put on them pieces of a heat shrinkable tube with a diameter of 3mm and a length of 3mm.
Description: Name: IMG_20190608_111839.jpg
Description: Name: IMG_20190608_1129371.jpg
Description:
It became much better.
T16 buttons backlit mod (0 min 53 sec)
Yesterday, 03:17 PM
rosnik's Avatar
just joke lights.
Yesterday, 11:42 PM
Romushok's Avatar
RF power increase
Let's see how you can increase the output power of the RF module. For this we need a RF amplifier and voltage regulator.
Description:
I cut off all the excess from the amplifier and set the regulator to 5V.
Description: Name: IMG_20190615_130012.jpg
Description:
As a result, we have almost doubled the output power - from 80 mW to 150 mW.
Before
Description: Before
After
Description: After
Amplifier goes pretty warm, so i add a heat sink.
Description:
Today, 01:54 AM
Happy FPV flyer
Kilrah's Avatar
Your signal must be extremely dirty at the output since you're exceeding the amp's max output (that is the same as the radio's own rated output in the first place, so no improvement) and there is no filtering.
Range might actually be lower that way (plus polluting the spectrum).
New Product Jumper T16 2.4G 16CH OpenTX Multi-protocol Radio rotorsupport Radios 1662 Yesterday 11:46 PM
New Product Jumper T16 2.4G 16CH Open Source Multi-protocol Radio Transmitter w/ JP4-in-1 BG-Wilson Radios 10 May 30, 2019 09:06 AM
New Product Jumper T16 2.4G 16CH Open Source Multi-protocol Radio Transmitter w/ JP4-in-1 RF Modu BG-Wilson Multirotor Drone Talk 17 Mar 22, 2019 08:56 PM
New Product Jumper T16 2.4G 16CH Open Source Multi-protocol Radio Transmitter Compatible OpenTX alex_nikiforov Banggood.com 1 Mar 22, 2019 01:12 AM
