Jun 10, 2019, 05:47 AM
Merch's Avatar
New Product
ROBSG BLS2206S 25KG Brushless Waterproof Metal Gear Digital Servo For 1/8 1/10 RC Car
https://www.banggood.com/ROBSG-BLS2206S-25KG-Brushless-Waterproof-Metal-Gear-Digital-Servo-For-18-110-RC-Car-600-700-Class-RC-Helicopter-p-1497442.html
DESCRIPTION:
Brand: ROBSG
Product: BLS2206S Digital Servo
Gear: Steel gear
Spline: 25T
Motor: Brushless motor
Bearing: 2BB
Dead band: 2μs default
Waterproof: Yes
Operating Voltage: DC5.0~8.4V
Working frequence: 1520μs/330hz
FEATURE:
-High performance, standard,Multivoltage digital servo
-High-precision 7075 aluminium gear
-Long-life potentiometer
-Full CNC aluminium case
-High quality brushless motor
-Dual ball bearing
-Waterproof
-Suit for 1/8, 1/10 fuel car, 600-700 class helicopter CCPM
SPECIFICATIONS:
Operating Speed (5.0V): 0.09sec/60 degrees
Operating Speed (6.0V): 0.07sec/60 degrees
Operating Speed (7.4V): 0.06sec/60 degrees
Operating Speed (8.4V): 0.05sec/60 degrees
Stall Torque (5.0V): 17.7kg.cm (245.86oz/in)
Stall Torque (6.0V): 19.8kg.cm (275.02oz/in)
Stall Torque (7.4V): 22kg.cm (305.58oz/in)
Stall Torque (8.4V): 25kg.cm (347.25oz/in)
Dimensions: 40X20X40.9mm /1.56X0.78X1.6in
Weight: 69g (2.43oz)
Connector Wire Length: 300mm (11.8in)
Package:
1* ROBSG BLS2206S Digital Servo
Jun 10, 2019, 05:49 AM
Merch's Avatar
ROBSG RHS3115 20KG Coreless Metal Gear Digital Servo For RC Robot
https://www.banggood.com/ROBSG-RHS3115-20KG-Coreless-Metal-Gear-Digital-Servo-For-RC-Robot-p-1497441.html
DESCRIPTION:
Brand: ROBSG
Product: RHS3115 Digital Servo
Operating Voltage: DC6.0~7.4V
Motor: Coreless
Operating Speed (7.4V): 0.16sec/60 degrees
Stall Torque (6.6V): 20 kg·cm (277.6 oz·in)
Dimensions: 40X20X40.5mm /1.57X0.78X1.59inch
Weight:69g (2.32oz)
Package:
1* ROBSG RHS3115 Digital Servo
Jun 10, 2019, 05:51 AM
Merch's Avatar
ROBSG RHS8025S 25KG Brushless Metal Gear Dual Ball Bearing Digital Servo For 1/8 1/10
https://www.banggood.com/ROBSG-RHS8025S-25KG-Brushless-Metal-Gear-Dual-Ball-Bearing-Digital-Servo-For-18-110-RC-Car-600-700-RC-Helicopter-p-1497443.html
FULL CNC bruhless motor servo 25kg.cm, digital, metal gears standard servos Suitable for RC Car Helicopter
DESCRIPTION:
Brand: ROBSG
Product: RHS8025S Digital Servo
Gear: Steel Gear
Spline: 25T
Bearing: 2BB
Dead Band: 2μs default
Waterproof: Yes
Working Frequence: 1520μs/330hz
SPECIFICATIONS:
FEATURE:
- High performance, standard,Multivoltage digital servo
- High-precision 7075 aluminium gear
- Long-life potentiometer
- Full CNC aluminium case
- High quality brushless motor
- Dual ball bearing
- Waterproof
- Suitable for 1/8, 1/10 fuel car, 600-700 class helicopter CCPM
Package:
1* ROBSG RHS8025S Digital Servo
Jun 10, 2019, 05:53 AM
Merch's Avatar
ROBSG HS3112 12KG Coreless Waterproof Metal Gear Digital Servo For 1:10 RC Car
https://www.banggood.com/ROBSG-HS3112-12KG-Coreless-Waterproof-Metal-Gear-Digital-Servo-For-110-RC-Car-p-1497445.html
Description:
Brand: ROBSG
Product: HS3112 Digital Servo
Operation Voltage Range: 4.8V~6.0V
Torque: 10kg/ [email protected] 4.8V, 12kg.cm/[email protected]
Motor type: Coreless
Dead Band Width: 1US
Circle: >15000 times/idle load
Ball Bearing: Double Ball Bearing
Operation Temperature Range: -20C°~ +60C°
Size(mm): 40.8*20.2*26.1mm
Application: Car model; Fixed-wing aircraft; Helicopter; Robot
Package:
1* ROBSG HS3112 Digital Servo
Jun 10, 2019, 05:56 AM
Merch's Avatar
ROBSG HS3225 25KG Coreless Waterproof Metal Gear Digital Servo For RC Helicopter Car
https://www.banggood.com/ROBSG-HS3225-25KG-Coreless-Waterproof-Metal-Gear-Digital-Servo-For-RC-Helicopter-Car-Robot-p-1497448.html
Description:
Brand: ROBSG
Product: HS3225 Digital Servo
Operation Voltage Range: 6.0V~7.4V
Torque: 25kg/ [email protected] 6.0V, 27kg.cm/[email protected]
Motor Type: Coreless
Size(mm): 40*20*39mm
Package:
1* ROBSG HS3225 Digital Servo
Jun 10, 2019, 05:58 AM
Merch's Avatar
ROBSG HS1106S 7KG Coreless Metal Gear Digital Servo For 450 Class RC Helicopter
https://www.banggood.com/ROBSG-HS1106S-7KG-Coreless-Metal-Gear-Digital-Servo-For-450-Class-RC-Helicopter-p-1497447.html
Description:
Brand: ROBSG
Item: HS1106S Digital Servo
Gear: Full metal
Spline: Exclusive
Motor: Coreless motor
Bearing: 2BB
Dead band: 2us default
Waterproof: No
Specifictions:
Operating Speed (5.0V): 0.10sec/60 degrees at no load
Operating Speed (6.0V): 0.08sec/60 degrees at no load
Operating Speed (7.4V): 0.06sec/60 degrees at no load
Operating Speed (8.4V): 0.05sec/60 degrees at no load
Stall Torque (5.0V): 6.0 kg.cm (102.78 oz/in)
Stall Torque (6.0V): 7.4 kg.cm (102.78 oz/in)
Stall Torque (7.4V): 9.5 kg.cm (131.95 oz/in)
Stall Torque (8.4V): 10.5 kg.cm (131.95 oz/in)
Potentiometer Drive: Direct Drive
Dimensions: 32X12X27.2 mm /0.91 X0.47X1.07 in
Weight: 20.3 g (0.72oz)
Connector Wire Length: JR220 mm (8.58in)
Features:
- Programmable high performance matal gears(copper+titanium) mini digital servo- High quality coreless motor
- Full CNC aluminium hulls and structure
- Dual ball bearings
- Suitable for 450 class helicopter tail and swashplate
Package:
1* ROBSG HS1106S Digital Servo
Jun 10, 2019, 06:01 AM
Merch's Avatar
ROBSG HS3220 20KG Coreless Waterproof Metal Gear Digtial Servo For RC Models
https://www.banggood.com/ROBSG-HS3220-20KG-Coreless-Waterproof-Metal-Gear-Digtial-Servo-For-RC-Models-p-1497449.html
Description:
Brand: ROBSG
Product: HS3220 Digital Servo
Torque: 20 kg/ [email protected] 6.0V, 22kg.cm/[email protected]
Package:
1* ROBSG HS3220 Digital Servo
Jun 11, 2019, 01:23 AM
Merch's Avatar
ROBSG HS5065 65KG Coreless Waterproof Metal Gear Digital Servo With Metal Servo Arm
https://www.banggood.com/ROBSG-HS5065-65KG-Coreless-Waterproof-Metal-Gear-Digital-Servo-With-Metal-Servo-Arm-For-RC-Boat-Car-Airplane-p-1498094.html
HS5065 65Kg Digital Servo features HV high torque, metal gear, fast heat dissipation, sensitivity and responsiveness, which with high quality and performance is tailored for RC hobbyist to provide different experience and delight.
Specifications:
Brand: ROBSG
Item Name: HS5065HV Digital Servo
Operating Voltage: 6.0V-7.4V
Operating Speed (6.0V): 0.15sec / 60 degree
Operating Speed (7.4V): 0.13sec / 60 degree
Stall Torque (6.0V): 51kg.cm
Stall Torque (7.4V): 65kg.cm
Stall Current: 10.0A (6.0V) / 13.4V (7.4V)
Running Current (At no load): 120mA (6.0V)
Running Current (At no load): 150mA (7.4V)
Idle Current (At stopped): 20mA (6.0V / 7.4V)
Connector Wire: About 300mm
Gear Type: Metal
Size: 66 * 30 * 56mm
Weight: 229g
Ideal choice for RC Car Boat Airplane HPI Rovan Km Baja 5B 5T
Package Information:
Package size: 6.8 * 6.8* 4.3cm / 2.68 * 2.68 * 1.7in
Package weight: 225g / 7.94oz
Package List:
1 * ROBSG HS5065HV Digital Servo
1 * Spare Parts Set
Jun 19, 2019, 06:18 AM
Merch's Avatar
ROBSG HS3230 30KG 25T Coreless Waterproof Metal Gear Digital Servo For RC Models
https://www.banggood.com/ROBSG-HS3230-30KG-25T-Coreless-Waterproof-Metal-Gear-Digital-Servo-For-RC-Models-p-1510899.html
Description:
Brand: ROBSG
Item: HS3230 Digital Servo
Operating Speed (6.0V): 0.13sec/60 degrees
Operating Speed (7.4V): 0.11sec/60 degrees
Stall Torque (6.0V): 30kg.cm (239.05oz/in)
Stall Torque (7.4V): 32kg.cm (294.75oz/in)
Working Frequence: 1500μs/330hz
Teeth: 25T
Bearing: 2BB
Waterproof: Yes
Connector Wire Length: JR320 mm (12.6in)
Weight: 89g (2.19oz)
Dimensions: 40.2X20X41mm /1.58X0.79X1.61 in
Features:
- High performance programmable digital high voltage standard servo
- High-precision Taiwan-made aluminium gears with hard anodizing
- Middle CNC aluminium case
- Waterproof
Package:
1* ROBSG HS3230 Digital Servo
Question Atomik 70 Amp 2S to 3S Waterproof Brushless ESC for Metal Mulisha 1:8 RC Truck carn157 Electric Power Cars 0 Dec 25, 2012 11:15 PM
