Jun 08, 2019, 08:45 PM
ErcoupeEd's Avatar
Help!
Original set of 1/4 scale Lanier Laser 200 plans or a copy of
Hi fellas,
I purchased a 1/4 scale Lanier Laser 200 fuselage only.
It had been crashed by its previous owner and only the foam core wings
were damaged.
So I purchased a new set of foam wings for it.
However the previous owner didn't have the plans. He apparently bought it after it had been built.
I need a set of plans for the size and placement of the ailerons, and locating the CG.
I am preparing to sheet the wings and recover the fuselage.
Planning on hanging a Zenoah G38 on it for power.
It has a 72 inch wingspan.
I will gladly pay for a set of plans or a copy.
I am editing this to include a picture of what I have.
I was told it was a Lanier Laser 200 when I bought it.
It doesn't seem to match up to Lanier plans.
No sheeting aft of the cockpit, only sheeted forward of the cockpit
Only longerons aft of the cockpit, no ABS turtle deck.
So is it a modified Lanier Laser 200?
72 inch wingspan foam wings with alumimum carry through spar.
Or did someone else kit this airplane?
Or wasit scratchbuilt?
Any help would be appreciated
Ed
PM me or drop me an email to [email protected]
Jun 09, 2019, 06:16 PM
koppterX's Avatar
A g38 is not the right engine. It’s a boat anchor. If you want to go gas a DLE 30 would be a good choice. I had one with a webra 1.2 which was glow. A good starting point on the CG is about 1/2 inch or so in front of the high point of the airfoil,
Jun 09, 2019, 07:16 PM
ErcoupeEd's Avatar
[QUOTE=koppterX;42051663]A g38 is not the right engine. Itís a boat anchor. If you want to go gas a DLE 30 would be a good choice. I had one with a webra 1.2 which was glow. A good starting point on the CG is about 1/2 inch or so in front of the high point of the airfoil,[/QUOTE
On this?
Jan 24, 2020, 11:36 AM
Did you ever find a set of plans?
I just pick up a kit at a swap meet and need a set as well.
If anyone has a set available to email or sell please PM me at [email protected]
Jan 27, 2020, 05:54 PM
ErcoupeEd's Avatar
NHOkie,
I am going to try asking Hemikiller here on RCG and ask him if he may have any files he can print out.
Ihave done business with him in the past
and his work is always top shelf quality.
He may or may not have them.
Regards, Ed
Feb 01, 2020, 06:21 PM
San Antonio TX.
sensei's Avatar
Feb 03, 2020, 08:29 PM
Hi Ed, were you able to get ahold of hemikiller.
Feb 05, 2020, 07:17 AM
-insert witty saying here-
Hemikiller's Avatar
I don't have the 1/4 scale, only the 1/3. If you find someone with a set, I can make copies for you.
Feb 10, 2020, 06:30 PM
ErcoupeEd's Avatar
Hi Dennis,
I just now saw your post
So far no luck.
May just finish it up as is, sheet the wings I have and find a power source. I have a couple of Bennett Built G26s, may just use one of them
Regards,
Ed
Discussion Old 1/3 scale lanier laser 200 Manual/Build Instructions NEEDED! Mudnyrey Scale Fuel Planes 5 Jan 01, 2016 12:48 PM
Discussion Terry Moore 1/4 scale Laser 200 blunight The Builders Workshop 10 Jul 05, 2015 08:43 PM
Discussion whats it worth,lanier 1/3 scale laser 200 kit freefall2907 Giant Scale Airplanes 4 Sep 16, 2014 09:59 PM
Lanier Laser 200 1/4 Scale Kit flytwin Fuel Plane Talk 0 Nov 06, 2005 11:42 AM
