Jun 08, 2019, 04:13 PM
hawaiianspork226's Avatar
Build Log
3dlabprint big spitty build
Got new printer running last weekend, new Prusa. Been printing parts ever since, started with the wings.
Just using the pre-canned g-code for the prusa and similar printers. So far so good. Just twaeking settings on the printer as needed. Turned flow up to 105% because it looks like it was under extruding at the beginning of each layer. Using 60c for the bed. 230c seems to work fine for extrusion temp. Parts feel good.
Slight curling on the skinnier parts of the trailing edge
Wing is printed though, I'm pretty happy with it so far.
I have intentions of designing some 3d printed airframes, but figured I should fully understand the design and build philosophy of those who are already really good at it, and hope to measure up to them, eventually.
Started out using 3d solutech white PLA. ran out, tried to order more on Amazon, they were out of stock, so I ordered hatchbox white
Anyhow, first observation is that the solutech white is different than hatchbox white, don't think it matters, but that's why the wing is different "colors". The wing roots are hatchbox, the outboard wings are 3d solutech
Just started fuselage today
-david
Jun 17, 2019, 01:43 PM
Fuselage printed and assembled
Thinking about re-printing some of the wing sections. The trailing edge areas of the wings where the flaps go curled from the print bed a bit...
Also printed the horizontal stabilizer... It printed fine, but it has some distortion, the top and bottom skins on both sides are deformed... Like there needs to be another "spar" or rib right in there... Thinking I might add that and print new ones...
-david
Build Log The Miglet and the Itty Bitty Spitty build. TRISME Slope 49 Sep 08, 2017 08:37 AM
Discussion Big Stable KFm3 Delta [build info & video] nelsoneci Foamies (Scratchbuilt) 25 May 04, 2016 11:43 AM
Discussion Did I make a big mistake by building a wing? uninc4life2010 Flying Wings 15 Feb 02, 2016 09:37 AM
Discussion 200mm Lightweight big prop Build (my first custom quadcopter) Six_Sigma Beginner Multirotor Drones 1 Jan 31, 2016 09:57 AM
