Sep 20, 2019, 09:06 PM
Galand's Avatar
No.
Sep 23, 2019, 02:01 PM
sportflyer
ESC BEC/signal wire colors
I wish that Turnigy had kept the BEC /signal wires same as servo wire colors for example Red/Black/Any other color for signal instead of 2 leads same color for +/- and a different lead color for signal.
Sep 24, 2019, 12:34 PM
FPV'r
ror1's Avatar
plush 32 30A
I had a new plush 32 30A ESC where the BEC stopped working after a few flights.
It failed to work after several tries.
With the BEC output zero the ESC could still control the motor.
Then all of a sudden after trying to get it to work on a servo tester, it started working.
Now I can not get it to fail but there is no way I will use it again.
I am trying to return for refund or replacement at HobbyKing.
Sep 25, 2019, 06:01 PM
sportflyer
Rimfire 28 motor timing
Can someone tell me what is the proper setting for timing for this motor ? I have it set as auto in the ESC ( Turnigy Plush 32 , 60 A) , Default ESC setting was 18 Degrees. Tks
Sep 25, 2019, 06:14 PM
FPV'r
ror1's Avatar
what 28 do to have?
I think 60a ESC is huge overkill looking at max current of the power 28 series.
most likely default is fine
Sep 25, 2019, 09:05 PM
FPV'r
ror1's Avatar
HK have replaced the defective unit very quickly...
good service and support..
Oct 11, 2019, 06:06 PM
[QUOTE=tonytek;42199819]Hi all. Im trying a 20 amp on my current build. Its making the motor stutter and attempts to run reversed at startup. If I flip the prop in the correct direction then apply power, it will start smoothly. No problem using any other ESC. Any ideas??[/QUOTE
Hey all,
I have purchased two of these Turnigy Plush-32 series escs and connected it to a Turnigy G25 motor. I am having the same stuttering issues as tonytek. I tried every timing setting with the program card and the stuttering is still there. I tried changing the "Startup Power" settings-no change. I inspected all my soldering joints-all look good. As with tonytek, if the prop is spinning while power is applied there is no stutter.
I connected a different motor with and without a prop-the motor stuttered both with and without a prop but worse with a prop.
I then connected the other esc to the Turnigy G25 motor-that esc behaves exactly the same way as the previous esc.
I am at a loss-any help is appreciated. Tonytek have you resolved the issue? I don't want to fly with these escs.
Ted
Oct 11, 2019, 06:41 PM
FPV'r
ror1's Avatar
[QUOTE=turfsurfer;42929097]
Hey all,
Ted
return for warranty replacement..
Oct 11, 2019, 06:51 PM
homo ludens modellisticus
Ron van Sommeren's Avatar
See
Motor stuttering? Won't run? Read before asking. - RCG
Prettig weekend Ron
• Without a watt-meter you are in the dark ... until something starts to glow, or blow •
e-flight calculatorswatt-metershigh power motor tips&tricksCumulus MFC
Oct 11, 2019, 07:01 PM
Originally Posted by Ron van Sommeren
See
Prettig weekend Ron
e-flight calculators watt-meters high power motor tips&tricks Cumulus MFC
Ron,
Thanks for that link-I tried most of what applied. With two motors and two escs and good soldering joints all doing the same thing, I don't know what I can do except for exploratory surgery. I don't want to void the warranty. I will try an old Plush 40a esc and see what happens.
Thanks again,
Ted
Oct 11, 2019, 07:08 PM
Just tried a old 60a Plush esc-works fine. I wonder if there is a way to update the firmware?
Oct 20, 2019, 09:40 AM
Beeping every 5s
Plush32 40amp default settings except brake on at 50%. Throttles fine but soon as I cut throttle the ESC has single beep every 5 seconds.
I cant figure out whats causing this. Any suggestions?
Thanks.
Oct 20, 2019, 10:36 AM
Galand's Avatar
Thanks.
I had that also when coming back from a flight.
My guess is that the ESC detected a too low voltage.
Oct 22, 2019, 02:43 PM
Me again,
I never found a solution to the stuttering ESCs. After a lot of back and forth with Hobbyking, they gave me a refund and did not have to send the ESCs back to them. They never gave me a root cause for the failure.
The problem is, as I explained to them, is now I lost trust in the Series-32 ESCs and will be very unlikely to purchase them in the future. This is a shame because I had very good luck with them in the past.
So if anyone has any new info., I would appreciate if you would reply. This is much about curiosity as anything else. It is just strange that this happened with 2 different ESCs with 2 different motors, going over my soldering joints and trying different settings. BTW, there is no way to update the firmware as per Hobbyking.
Ted
Last edited by turfsurfer; Oct 22, 2019 at 02:48 PM. Reason: punctuation and addition
Oct 22, 2019, 02:48 PM
FPV'r
ror1's Avatar
Originally Posted by turfsurfer
Me again,
I never found a solution to the stuttering ESCs. After a lot of back and forth with Hobbyking they gave me a refund and did not have to send the ESCs back to them. They never gave me a root cause for the failure.
Ted
The Plush brand seemed ok but the Plush 32 is new to me.
Also on HK you can no longer leave comments about a product unless it is a good comment otherwise it gets censored.
Discussion Turnigy 60a Plush ESC's. Overkill? at3whee Multirotor Drone Electronics 8 Oct 12, 2012 03:21 PM
Discussion ''ESC'' turnigy basic,plush,blue series windfou Aerial Photography 10 Mar 12, 2012 11:01 PM
Question Anyone have any Turnigy Plush 10a ESC's they wanna sell Z06 Tony Multirotor Drone Talk 2 May 12, 2011 11:38 PM
Discussion Turnigy 40A Esc's - Plush or Sentry? sgomes Power Systems 3 May 09, 2010 01:01 AM
Discussion Is it possible to convert TURNIGY Plush 30A ESC's from PWM to TWI/I2C control benbois DIY Electronics 0 Dec 17, 2008 12:56 PM
