New Turnigy Plush-32 Series ESC's
The new Turnigy Plush-32 series ESC has the same solid, high-quality that hobbyists have come to expect from Turnigy but it has been improved with even more features that are sure to be a winner for any devoted hobbyist.
A new generation of Turnigy ESCs is here!
The new Turnigy Plush-32 series ESC has the same solid, high-quality that hobbyists have come to expect from Turnigy but it has been improved with even more features that are sure to be a winner for any devoted hobbyist. The new energy saving range comes with a 32-bit ARM controller to make it quicker and more responsive to your every input and is suitable for most motors on the market, giving you the flexibility of choice.
Donít forget to include a Plush-32 programming card to make life easy. No more listing to the beeps and guessing when to move your throttle, the programming card changes settings with the press of a button and its easy to read LEDís lets you know exactly how your ESC is programmed.
Check out the new Turnigy Plush-32 ESC's Here
Jun 07, 2019, 10:34 AM
DFS#000178
Rampage's Avatar
I ordered 2 of the 30 amp for a project I'm working on. I liked that they had a 4 amp SBEC while most other 30s have a 2 amp. That was the selling point for me
Jun 07, 2019, 02:28 PM
I like their light weight, reasonable price to.
My still working 17 years old CC Phoenix 25 A ESC has same Weight, 25gr, as Plush-32
30A but only 2-3S , 2A BEC and Cost $79
then. :-(
Thanks to the great cheap labor Of Chinese people ;-)
Jun 07, 2019, 05:26 PM
DFS#000178
Rampage's Avatar
Yeah I still have a pair of those old Phoenix 25s that I run with 890kv Park 450s. They lived in my EFlite P-38 for years and now they live in an EFlite Cub 450 and a Mini Pulse XT. My then-LHS gave them to me after I had a pair of EFlite 30-amp Pro ESCs burn up (as in literally catch fire) on the bench while building that P-38.
They've been great ESCs but honestly I'd rather pay $16 for these than $80 for those and get double the BEC power.
I got my Plush-32s this afternoon. I'll post some pictures this evening.
Jun 07, 2019, 10:20 PM
Bagpipes spoken here
Pipemajor's Avatar
https://www.rcgroups.com/forums/show...gy-32-bit-ESCs
Jun 07, 2019, 11:43 PM
DFS#000178
Rampage's Avatar
Slightly lighter than advertised. 24.5g is 0.864oz. Weighs in at 0.85oz.
I'm happy with that.
ESC is very small. I figured it'd be bigger.
Jun 09, 2019, 05:01 AM
Programming card
Does it need a new different programmer card?
E.G. is the "Plush 32" programming card compatible with the one for the old versions?
N.B. What do we call the old versions? Plush V1? Plush 8bit?
Jun 17, 2019, 06:02 PM
Yes I need to know this too.
Can I use my existing programming card, or do I have to buy the new one?
Jun 19, 2019, 12:06 AM
Pictures of 80A model
I got the 80A version, here's some pictures and info I've gathered from it.
Soldering quality is great, and the joints are all nearly perfect, if a little lean on the solder
Came with only 14 awg wires witch is really weak for 80A. fortunately there's some easily accessible pads to solder on your own wires.
You can see 18 mosfets underneath the heat spreader, however looking at the side there seems to be another 6 on the other side of the board with a small shim of aluminum on top of them. googling the numbers of them, the best I could come up with is that these are PH2230DLSX witch for some reason there is no datasheet, or any details about them at all that I can find. All I can really do is guess based on the part number and the other similar mosfets from this manufacturer is that they probably are rated for 30V and probably have an RdsON of around 3mOhm. So with what seems like 4 of them paralleled per half bridge, they should handle 80A
Another thing that's nice is nothing on the bottom side protrudes higher than the mosfets, so you can stick on as big as a heat sink as you like if you're so inclined
As for the main micro controller, its an STM32F051K66 and it has connecting pads to pins 12, 13, 31, & 32. if anyone finds this information usefull then good, cause I sure have no Idea what to do with it.
I've also included a picture of my slightly modified one.
Jun 30, 2019, 11:42 AM
Hi all. I’m trying a 20 amp on my current build. It’s making the motor stutter and attempts to run reversed at startup. If I flip the prop in the correct direction then apply power, it will start smoothly. No problem using any other ESC. Any ideas??
Jun 30, 2019, 03:11 PM
Pipemajor's Avatar
Flew my 40A Plush-32 yesterday in a TuffWing 32 pusher wing. Propdrive NTM 28-36 2200KV motor pulling an APC 7-4e prop. Previous ESC was a generic HobbbyKing 50A. Two servo elevon setup with analog HXT-900 servos. RX is a basic Spektrum AR400 DSMx.
Weather was pretty hot (88 degrees) and humid but light winds. I didn't notice any difference in response but I did get one brief sag at WOT. Throttled down but subsequent WOT passes went without a hitch. Static powermeter reading shows 34.8 - 35.2 amps at WOT. Battery was a Turnigy 3S 2200mAh 25-35C and has a couple of years on it.
I also bought the 32 bit programming card but flew with the default settings.
Jul 05, 2019, 03:54 PM
Nuthin
Xereaux's Avatar
Plush 32 bit esc. I have the 12a and 20a. The only thing you can set with the Tx is a basic brake setting of on/off. Brake percentage can be set with the programmer.
This pic is the only programming info in the included manual.
Jul 11, 2019, 07:38 PM
Originally Posted by tonytek
Hi all. Iím trying a 20 amp on my current build. Itís making the motor stutter and attempts to run reversed at startup. If I flip the prop in the correct direction then apply power, it will start smoothly. No problem using any other ESC. Any ideas??
I've been using a 20A version also, on a HK CF2812 with no issues. Did you set the throttle limits first?
Jul 14, 2019, 10:01 AM
Pipemajor's Avatar
Additional flights on the Tuffwing with the 40A Plush-32 Turnigy. Weather is getting warmer and more humid and I've been pushing it harder with longer WOT runs. As mentioned, the LiPO is showing its age but coming down, the NTM motor is pretty warm as is the LiPO but the Plush-32 is barely warm.
I'm thinking this series is a pretty good value.
Discussion Turnigy 60a Plush ESC's. Overkill? at3whee Multirotor Drone Electronics 8 Oct 12, 2012 03:21 PM
Discussion ''ESC'' turnigy basic,plush,blue series windfou Aerial Photography 10 Mar 12, 2012 11:01 PM
Question Anyone have any Turnigy Plush 10a ESC's they wanna sell Z06 Tony Multirotor Drone Talk 2 May 12, 2011 11:38 PM
Discussion Turnigy 40A Esc's - Plush or Sentry? sgomes Power Systems 3 May 09, 2010 01:01 AM
Discussion Is it possible to convert TURNIGY Plush 30A ESC's from PWM to TWI/I2C control benbois DIY Electronics 0 Dec 17, 2008 12:56 PM
