Jun 05, 2019, 05:08 AM
New Product
Geprc CinePro 4K FPV Racing Drone With F7 Dual Gyro 2-6S 35A BLheli_32 Caddx Tarsier
Geprc CinePro 4K FPV Racing Drone With F7 Dual Gyro 2-6S 35A BLheli_32 Caddx Tarsier Dual Lens Cam BNF
Frsky R-XSR Version $265 with coupon 3X1VP5RI
Frsky XM+ Version $255 with coupon 3X1VLWKN
Specification
Frame: GEP-CX2(Improved version,Including Guards)
Weight: Around 125g(without battery)
Camera: Caddx Tarsier 4K 1200TVL
Motor: GEP-GR1105 5000KV(4S lipo battery is Best)
Propeller: EMAX AVAN 2Inch or DalProp Q2035 4-blade
STABLE PRO F722 DUAL Gyro ICM20689 Version:
Flight Controller:
Model: STABLE PRO F7 35A
MCU: STM32F722RET6
IMU: 2x ICM20689(SPI)
BlackBox: 32Mb onboard Flash
OSD: BetaFlight OSD w/ AT7456E chip
Firmware target: EXF722DUAL
Integrated LC Filter
Size: 26x26mm board, 20mm mounting holes (M2)
ESC BLheli_32 2-6S 4in1:
MCU: STM32F051
Constant: 35Amps
Burst: 45Amps
Mounting Holes: 20*20mm,M2
Supports Dshot1200,Proshot,Oneshot,Multishot
Current meter: Yes
Target: GEPRC-BL32-4IN1
5.8g 500mW VTX:
Input voltage: 5V
Channel: 48
Power transmission: 0mW(Pit mode)/25mW/100mW/200mW/400mW/500mW
Connector type: MMCX Connector
Traditional button
IRC Tramp protocol
You might need the following equipment to fly
Remote control: You can choose: Frsky X9d or something like that
Goggle: Such as FatShak V2 or something like that
Battery: The recommends using the 4S 450mAh 650mAh battery.
Jun 05, 2019, 05:42 AM
Quad Erat Demonstrandum
scousethief's Avatar
You are posting the same products as I have already posted .............
Jul 09, 2019, 05:19 PM
smackfpv's Avatar
the original post was here!
https://www.rcgroups.com/forums/show...ersion-PNP-BNF
Discussion GEPRC CinePro 4K HD 3-4S FPV Racing Drone Basic / Advanced Version PNP/BNF alex_nikiforov Banggood.com 19 Sep 14, 2019 09:23 AM
New Product Geprc CinePro 4K FPV Racing Drone With F7 Dual Gyro 2-6S 35A BLheli_32 Caddx Tarsier scousethief Vendor Talk 0 May 28, 2019 06:05 AM
New Product Caddx Tarsier 4K/30FPS Dual IENS WIFI FPV Racing Drone Camera With Super WDR Hardware scousethief Vendor Talk 0 May 28, 2019 04:41 AM
New Product Iflight CineBee 4K 2-3S 107mm Whoop FPV Racing Drone Caddx Tarsier Cam BNF - Flysky R scousethief Vendor Talk 0 May 23, 2019 09:18 AM
New Product Geprc Stable Pro F7 Stack Dual Gyro F7 Flight Controller & 35A BLheli_32 4in1 ESC & 5 alex_nikiforov Banggood.com 0 May 06, 2019 06:11 AM
