New Product
MINI CROSSWIND 1600 - more than a downsized giant
With all Crosswind homework done, this is a surprisingly capable, versatile and agile platform.
Two nose canopies, two belly plates included in a standard retail kit, lots of improvements, tons of lift, excellent stability. Plus, it doesn't even have to be disassembled to be taken to the field in a regular sedan. (but yes it can be disassembled if the need comes). More in the comments. |
Reason: grammar schmammar
What’s in the box?
Besides the obvious foam parts you fill find a few plastic bags there: 7 numbered, and 1 without a number. Here is what these bags contain. BAG 1 – Tail and Wing fixtures Left to right, top to bottom: 4 Small Lock Holders, and 4 bigger ones (white dots matter!); 2 Aluminum Snaphooks; 4 Steel Springs, small screws (in a separate bag); 2 Nylon Washers, and 2 bolts; 2 Plastic Horizontal Stabilizer Holders, fuselage parts with swings (swings attached) 2 Plastic Horizontal Stabilizer Holders, control surface parts (swings not attached) BAG 2 – Nacelle and Nose Tip 2 Rounded Rectangle Ply Nacelle Motor Mounts; 1 Ply Nose Tip Motor Mount (for VTOL version, but installing it in a regular plane is also possible); Screws in a separate bag BAG 3 – Wooden and Plastic Fixtures 4 Plastic Lock Hooks; 1 Autopilot Shelf; 2 Plastic Nose Hatch Rim Guards; 1 Nose Tip Shelf; 1 Battery Shelf with slots for Velcro Straps BAG 4 – Wing Fixtures 4 Aluminum Snaphooks; 2 Sets of Electric Connectors; 4 Steel Enforcers; 4 Steel Springs; 4 Lock Holders (triangular marks matter!); small screws BAG 5 – Radio and Servo Cradles 2 Aileron Servo Cradles; 2 Aileron Servo Cradle Covers; small screws in a separate bag; Rlink (or similar sized RCRx) Cradle with Cover BAG 6 – Electric Cables Power and Servo Cables* _____ * Every setup is different and depends on individual pilot’s needs. Therefore this set of cables is not supposed to cover all needs for all electric connections in all possible setups. You may, and most likely will need to purchase more cables locally. BAG 7 – Servo Fixtures and Hinges 1 Back Hatch Lock with Lock Holder; Hinges for Ailerons, HS, and Rudder; Servo Adjustable Heads with small bolts; Servo Horns with screws; Servo Rods (longer ones for aileron and horizontal stabilizer; shorter one for rudder) UNNUMBERED BAG Laminated Paper Strip with round stickers to cover technical openings in the wings (for regular airplane configuration. for VTOL configuration these openings are used to fix the motor bars); GPS cradle Cover; 2 Hatch Lock Snappers; 2 Plastic Wing Fixtures (wing side); 2 Velcro Straps for holding the battery (more to follow) |
Looks good. Ordered one.
Would like to see some comparison shots next to a normal crosswind and a mytwindream. Looks like the fuse is almost the same width and height as the MTD (which would be huge for a 1600mm wingspan). Flight video from the test plane with OSD? |
Comparison with other aircraft:
![]() ![]() ![]() ![]() Looks like it's still a fair bit bigger than the mini talon which for many is the benchmark in the "mini" category. Hopefully the efficiency is similar. Will be interesting to see the popularity of this plane vs the Sonicmodel Binary. |
Where did you order one from? Im very interested in this. |
A few hints on assembling the tail (before MFD comes down with manual)
Although it is pretty intuitive for anyone who has had an experience assembling more than one plane, MFD are working on the manual.
Before they are done with it, I snatched some of the pictures they are going to use in the manual and decided to post some hints for those who receive their orders before the downloadable manual is ready. |
Myflydream.com
The price has gone up $10 since I ordered which is crazy because it's already an expensive plane! Espeically for a "mini" plane. Mini Talon is around $65USD delivered. Mini Crosswind is over $200USD delivered. |
[US$179.99 31% OFF]E-DO Model 1500mm Wingspan Cessna EPO Twin Motor FPV RC Airplane Glider PNP RC Parts from Toys Hobbies and Robot on banggood.com
https://banggood.app.link/116FcOQRkX this is pnp , include landing gear - 190$ include shiping ![]() ![]() ![]() ![]() |
I also ordered last week. Only got the paypal email...no response to my email...silence....Is this going to ship, or do I have to open a Paypal Dispute?
Thread Tools | |
Similar Threads | |||||
Discussion | inav 1.8 throttle set less than 1100, motors jump to 1600+ | Gamarra | Multirotor Drone Electronics | 1 | Apr 24, 2018 01:05 PM |
Discussion | Less.........the new More , Downsizing .........Keep , sell , give away or garbage . | rockyboy2 | Life, The Universe, and Politics | 4 | Dec 18, 2017 11:31 AM |
Are Vtail's more effected by crosswind than R/E? | fdisk | Electric Sailplanes | 1 | Jan 19, 2003 02:05 PM | |
More Fun than a Mini-Z Car. | DNA | Life, The Universe, and Politics | 5 | Sep 23, 2002 11:36 AM |
